Rox169
wireguard1: Could not create IPv4 socket
Tue Mar 22, 2022 8:15 pm
what does mean wireguard1: Could not create IPv4 socket?
Thank you
holvoetn
Re: wireguard1: Could not create IPv4 socket
Tue Mar 22, 2022 8:21 pm
Are you using a port which is already been used by another service ?
Rox169
Tue Mar 22, 2022 8:29 pm
probably yes, im trying to find the non blockek port by ISP. Do you suggest any port?
Thank you
holvoetn
Tue Mar 22, 2022 8:33 pm
It's not a blocked port. Because then nothing would happen
It is really a port already in use.
See what other ports you can use.
12321 is default Mikrotik in Help pages, I think.
Anything from 10000 to 65535 can be used.
But it needs to be open, as in: not used by anything else.
Obviously it needs to pass whatever firewall is in between...
Users browsing this forum: No registered users and 15 guests
