runbound
all ppp profile  [SOLVED]
Thu Mar 24, 2022 9:35 am
pls help how to print all profile name with starts with the name FIBR
i have a script but it print only 1
:put ([/ppp profile print as-value where name~"FIBR"] ->1->"name")
mrz
Re: all ppp profile
Thu Mar 24, 2022 11:03 am
You are picking one element from an array, instead you should run foreach loop to go through all the elements of an array.
runbound
Re: all ppp profile
Thu Mar 24, 2022 11:11 am
how can u give me an example pls
Jotne
Re: all ppp profile
Thu Mar 24, 2022 2:19 pm
You need to find what you are looking for, then get all the data for the ID that find returns.
print should not be used in script.
:foreach Profile in=[/ppp profile find where name~"FIBR"] do={:put [/ppp profile get $Profile]}
Some more clean setup.
/ppp profile
:foreach Profile in=[find where name~"FIBR"] do={
If you like to try this at command line, you need to wrap it in {} (since its more than one line), so:
/ppp profile
rextended
Re: all ppp profile
Thu Mar 24, 2022 3:36 pm
get.. NAME... :-P
containing "FIBR" (CASE SENSITIVE!!!)
/ppp profile
:foreach profID in=[find where name~"FIBR"] do={
    :put [get $profID name]
starts with "FIBR" (CASE SENSITIVE!!!)
/ppp profile
:foreach profID in=[find where name~"^FIBR"] do={
Notice:
[get $profID name]
or
([get $profID]->"name")
on this case are equivalents, but the first is more readable
Jotne
Re: all ppp profile
Thu Mar 24, 2022 5:33 pm
Hmm
I hoped that this should work, but it does not:
name~"(?i)fibr"
Did try this as well, but does not work.
name~"(\?i)fibr"
rextended
Re: all ppp profile
Thu Mar 24, 2022 6:24 pm
MikroTik use syntax compatible only with POSIX RegEx, but without "Character Classes" and is not present support for other platform RegEx syntax
start with
name~"^[Ff][Ii][Bb][Rr]"
or
name~"^(F|f)(I|i)(B|b)(R|r)"
contain
name~"[Ff][Ii][Bb][Rr]"
or
name~"(F|f)(I|i)(B|b)(R|r)"
Jotne
Re: all ppp profile
Thu Mar 24, 2022 8:03 pm
MT does not handle upper/lower case very good.
Missing toupper/tolower (?i) +++
rextended
Re: all ppp profile
Thu Mar 24, 2022 8:06 pm
missing also RegEx on :find... :(
runbound
Re: all ppp profile
Fri Mar 25, 2022 7:18 am
thanks for the help it works. but how can i send this through sms. not working
/ppp profile
:log warning message=[get $profID name]
:local plan [get $profID name]
:log warning message="send to sms"
/tool sms send phone-number=056698885 message="$plan"
} on-error={:log error message="script failed..."}
rextended
Re: all ppp profile
Fri Mar 25, 2022 2:09 pm
The script you write can not work because :local variables inside "{" are lost at first "}" and if global is used, return only the last profile with "FIBR" inside
You first try on terminal to see if the machine send SMS?
/tool sms send phone-number=056698885 message="test"
Probably you need something like this:
One SMS for each profile containing FIBR
/ppp profile
    :log warning message="send $[get $profID name] to SMS"
    /tool sms send phone-number=056698885 message=[/ppp profile get $profID name]
Only one unique SMS with all profiles that containing FIBR
(single SMS is max 160 characters!!!)
/ppp profile
:local allprofiles ""
    :if ($allprofiles="") do={ :set allprofiles [get $profID name] } else={ :set allprofiles "$allprofiles,$[get $profID name]" }
:log warning message="send $allprofiles to SMS"
/tool sms send phone-number=056698885 message=$allprofiles
runbound
Re: all ppp profile
Fri Mar 25, 2022 3:28 pm
it works. thank u very much sir rextended
lastly how to pick it like for example i want to remove the name FIBR when i recieved the sms
like for example
instead of
FIBR 12 10MBPS
FIBR 15 15MBPS
FIBR 17 17MBPS
they reiceved the message of
12 10MBPS
15 15MBPS
17 17MBPS
rextended
Re: all ppp profile
Fri Mar 25, 2022 4:00 pm
please be more clear, you want remove FIBR on COMMENTed profile, or INSIDE SMS?
runbound
Re: all ppp profile
Fri Mar 25, 2022 4:12 pm
on sms sir
rextended
Re: all ppp profile
Fri Mar 25, 2022 4:20 pm
Removing "FIBR " (and space):
One SMS for each profile containing FIBR and removing "FIBR " on SMS
/ppp profile
    :local profname [get $profID name]
    # 5 is the lenght of prefix FIBR including space
    :set profname [:pick $profname ([:find $profname "FIBR "] + 5) [:len $profname]]
    :log warning message="send $profname to SMS"
    /tool sms send phone-number=056698885 message=$profname
Only one unique SMS with all profiles that containing FIBR and removing "FIBR " on SMS
/ppp profile
    :if ($allprofiles="") do={ :set allprofiles [get $profID name] } else={ :set allprofiles "$allprofiles,$profname" }
runbound
Re: all ppp profile
Tue Jun 14, 2022 6:12 am
thanks sir ,
how about not to include my current profile in sms
example my current profile is 15 15MBPS
12 10MBPS
15 15MBPS (remove this)
17 17MBPS
rextended
Re: all ppp profile
Tue Jun 14, 2022 10:18 am
explain better, and where I can see the current profile?
runbound
Re: all ppp profile
Tue Jun 14, 2022 3:07 pm
if my subscriber have a plan of 5MBPS in ppp secret profile
and text 9. i want reply of my system to my subscriber all profile~FIBR but not included the current plan of my subscriber
:foreach i in=[/tool sms inbox find where message="9"] do={
:local smsPhone [/tool sms inbox get $i phone];
:local old [ :pick $smsPhone 3 14 ]
:if ([/ppp secret find where profile~"FIBR" ipv6-routes="$old" && comment>"-4"]) do={
:local sname [/ppp secret get [find ipv6-routes="$old"] name];
:local profile [/ppp secret get [find ipv6-routes="$old"] profile];
:local prof1 [ :pick $profile 0 4 ];
:local prof2 [ :pick $profile 5 9 ];
:local prof3 [ :pick $profile 10 17 ];
:local allprofiles
/ppp profile
:set profname [:pick $profname ([:find $profname] + 5) [:len $profname]]
:if ($allprofiles="") do={ :set allprofiles [get $profID name] } else={ :set allprofiles "$allprofiles\r\n$profname" }
/tool sms send phone="$old" message="UR CURRENT PLAN is:
$prof1 $prof2 $prof3
PLAN AVAILABLE:$allprofiles
-$identity"
rextended
Re: all ppp profile
Tue Jun 14, 2022 3:41 pm
you can replace
with something like
foreach profID in=[find where name~"FIBR" and name!=$currentprofilename] do={
runbound
Re: all ppp profile
Wed Jun 15, 2022 3:50 am
thank you sir for your help
one more sir
how can i order it from lower to higher price
i received like this
20 20MBPS
10 `10MBPS
30 30MBPS
5 5MBPS
rextended
Re: all ppp profile
Wed Jun 15, 2022 10:09 am
too complex with limited scripting capabilities...
Users browsing this forum: No registered users and 7 guests
