rounin
REST API for /interface/lte> monitor lte1 once
Thu Mar 24, 2022 10:38 am
Is there a rest URL that can provide information similar to "/interface/lte> monitor lte1 once" on the terminal? Mainly looking to get SINR/RSSI cell band info.
/rest/interface/lte/monitor says "no such command"
/rest/interface/lte/lte1 only has very basic info, similar to lte iface "General" tab in Winbox.
rounin
Re: REST API for /interface/lte> monitor lte1 once
Fri Mar 25, 2022 1:36 am
Hmm. I also found it in the SNMP mtxrLTEModemEntry OID .1.3.6.1.4.1.14988.1.1.16.1.1, I might do it that way.
mrz
Re: REST API for /interface/lte> monitor lte1 once  [SOLVED]
Fri Mar 25, 2022 9:53 am
You should be using HTTP POST to run specific commands.
rounin
Fri Mar 25, 2022 9:45 pm
Oh that makes sense, that worked. For posterity, this is what i did:
foo@bar:~$ curl -k -u user:pass -X POST https://<ip-address>/rest/interface/lte/monitor -d '{"numbers":0, "duration":1}' -H "content-type: application/json"
Users browsing this forum: eldoncito2019 and 19 guests
