dakobg
hap ac^2 hardware diff
Thu Mar 24, 2022 3:18 pm
Probably is old topic but
1. What is the deal with RAM size (older vs new one) 128MB vs 256MB ?
2. Why I see IPQ-4019 as wireless on all hap ac^2 (older and new one) ?
3. is that a ROS7 bug (for wireless interface IPQ-4019) ? Or is really IPQ-4019 not IPQ-4018 ?!?!?!?!
new one
                  uptime: 2w1d5h46m49s
                  version: 7.2rc4 (testing)
               build-time: Feb/22/2022 11:37:16
         factory-software: 6.45.9
              free-memory: 63.9MiB
             total-memory: 128.0MiB
                      cpu: ARMv7
                cpu-count: 4
            cpu-frequency: 896MHz
                 cpu-load: 1%
           free-hdd-space: 2040.0KiB
          total-hdd-space: 15.2MiB
  write-sect-since-reboot: 9306
         write-sect-total: 45003
               bad-blocks: 0%
        architecture-name: arm
               board-name: hAP ac^2
                 platform: MikroTik
 /interface/wireless/print
 interface-type=IPQ4019
older
                 uptime: 3d5h2m41s
                  version: 7.2rc3 (testing)
               build-time: Jan/28/2022 14:33:08
         factory-software: 6.41.3
             free-memory: 192.3MiB
             total-memory: 256.0MiB
                      cpu: ARMv7
                cpu-count: 4
            cpu-frequency: 448MHz
                 cpu-load: 0%
           free-hdd-space: 1120.0KiB
  write-sect-since-reboot: 7688
         write-sect-total: 6288434
               bad-blocks: 0%
                 platform: MikroTik
Btw cAP AC with ros 6.49 show the same for wireless interface
mkx
Re: hap ac^2 hardware diff  [SOLVED]
Thu Mar 24, 2022 4:12 pm
1. RBD52G-5HacD2HnD-TC A.K.A. hAP ac² was always specified to have 128MB RAM. However, initial batches came out with 256MB RAM and the rumours go that MT had problem getting 128MB RAM chips so they used 256MB ones.
2. Because IPQ-401x SoC family includes IPQ-4018 and IPQ-4019 .. the later having some more options, but the main components (CPU, ethernet switch, wifi baseband, ...) are identical. As to why ROS displays radio name as 4019 and not 4018 ... your guess is as good as mine. FYI, ethernet switch is identified as "Atheros-8327" ... which is (or used to be) available as discrete chip, but Qualcomm includes the core of it into many of their SoCs.
3. As explained: it's cosmetic ... and it's the same in ROS v6 as well, so nothing new in v7. BTW, /system routerboard displays firmware type as "ipq4000L" ... so it seems pretty generic for a few different devices. Hence naming which is not entirely correct.
anav
Thu Mar 24, 2022 7:59 pm
Interestingly the throughput specs are slightly lower on the hapac3.
In any case if you need the device for wired performance only the hapac2 is better value for the money.
If you need the wifi, I would hazard a guess that the hapac3 will perform better and is for all intensive purposes of the same wired performance.
The stated larger amounts of RAM and flash, in the hapac3 may provide better LOAD capacity but thats just a guess.
Users browsing this forum: Sddaw and 100 guests
