Hi All
We had a cisco router that died and we have moved most of the config over to a mikrotik RouterOS v6.48.1
The only things not working are the port forwarding/NAT
I tried the following in NAT rules and nothing seems to work. Am I missing something?
Chain - dstnat Src.Address - x.y.z.251 Dst.Address - a.b.c.22 Protocol - 6 (tcp) Src.Port 8933 Dst.Port 3389
Chain - srcnat Src.Address - a.b.c.22 Dst.Address - x.y.z.251 Protocol - 6 (tcp) Src.Port 3389 Dst.Port 9833
I also tried the last comment from below link and that didn't work
viewtopic.php?t=87658
We have the following in cisco (WAN IP - x.y.z.250)
ip nat inside source static tcp a.b.c.22 3389 x.y.z.251 8933 extendable
ip nat inside source static tcp a.b.c.252 8082 x.y.z.252 80 extendable
Any help would be greatly appreciated
