saahil
RX Attack / UDP with https?
Sat Mar 26, 2022 11:56 am
Hi Support, we are observing continous RX traffic.
Tried all forum scripts and options, its still going one.
screenshot attached
rootemin
Re: RX Attack / UDP with https?
Sat Mar 26, 2022 12:01 pm
Hi
wan interface drop incoming traffic only accept ports you allow
add action=drop chain=input in-interface-list=WAN
tangent
Sat Mar 26, 2022 12:09 pm
Hi Support
This is a user-to-user forum, not official MikroTik support.
screenshot attached
Are you sure it isn’t a QUIC download?
saahil
Sat Mar 26, 2022 12:17 pm
this is core router which has 2 upstream bgp
router os is 6.47.10
if I disable WAN, it will completely drop all traffic [aprox 900Mbps]
tangent
Sat Mar 26, 2022 12:22 pm
Non sequitur. What I’m asking is, how do you know one of your users isn’t simply downloading a big file from this 41 address?
saahil
Sat Mar 26, 2022 12:28 pm
the IP that I am getting this RX traffic are already disabled. This is going on for the last 15-17 hours continous.
And none of my customers have plans bigger than 50Mbps
pe1chl
Sat Mar 26, 2022 12:44 pm
No forum script or option, and no support for your router, will terminate a stream that others send to you.
You need to ask the support for the sending system. Good luck with that!
junbr0
Sat Mar 26, 2022 12:57 pm
you should block it before its enter your router.
call or email your uplink service provider, if that truly ddos or flooding.
anav
Sun Mar 27, 2022 11:55 pm
Without seeing your config, wont care to speculate
saahil
Mon Mar 28, 2022 12:46 pm
I contacted upstream and they advised bgp-community blackhole, they shared with me the bgp community and I have created /32 prefix with the set-bgp-community which is my IP received all the 300Mbps capacity. It also shows on the bgp-advertisements. However when I torch the WAN interface I am still receiving the attack on my /32 IP.
Any other suggestions?
Buckeye
Forum Veteran
Forum Veteran
Mon Mar 28, 2022 1:38 pm
How I survived a DDoS attack youtube video by Jeff Geerling
Users browsing this forum: No registered users and 30 guests
