benoitc
MLAG: when primary is shutdown LACP stops to work
Sat Mar 26, 2022 5:16 pm
I am testing the MLAG feature and I have an issue when primary switch is down. When I launch a reboot, the MLAG is put on pause on the second switchj annd all slave sconnectiosn stops to work.
For this exampel I have put upstream routers and one freebsd machine in LACP. I have 2 VLAN setup for these machines: 102 & the default 1. These vlans have been tagged for the control port:
What do I miss ?
Configuration on switch 2 (primary)
[user@SW-2] /interface/bridge/mlag> print
     bridge: bridge
  peer-port: sfp-sfpplus3
[user@SW-2] /interface/bridge/port> print
Flags: H - HW-OFFLOAD
Columns: INTERFACE, BRIDGE, HW, PVID, PRIORITY, PATH-COST, INTERNAL-PATH-COST, HOR
IZON
#   INTERFACE     BRIDGE  HW   PVID  PRIORITY  PATH-COST  IN  HORIZON
0 H sfp-sfpplus3  bridge  yes    99  0x80             10  10  none
1 H client-bond1  bridge  yes     1  0x80             10  10  none
2 H upstream-r1   bridge  yes     1  0x80             10  10  none
3 H upstream-r2   bridge  yes     1  0x80             10  10  none
[user@SW-2] /interface/bridge/vlan> print
Flags: D - DYNAMIC
Columns: BRIDGE, VLAN-IDS, CURRENT-TAGGED, CURRENT-UNTAGGED
#   BRIDGE  VLAN-IDS  CURRENT-TAGGED  CURRENT-UNTAGGED
0   bridge         1  sfp-sfpplus3    bridge
                                      client-bond1
                                      upstream-r2
                                      upstream-r1
1   bridge       102  client-bond1
                      sfp-sfpplus3
                      upstream-r2
                      upstream-r1
2 D bridge        99                  sfp-sfpplus3
[user@SW-2] /interface/bonding> print
Flags: X - disabled; R - running
 0  R name="client-bond1" mtu=1500 mac-address=48:8F:5A:1A:28:C9 arp=enabled
      arp-timeout=auto slaves=sfp-sfpplus16 mode=802.3ad primary=none
      link-monitoring=mii arp-interval=100ms arp-ip-targets=""
      mii-interval=100ms down-delay=0ms up-delay=0ms lacp-rate=30secs
      transmit-hash-policy=layer-2-and-3 min-links=0 mlag-id=10
 1  R name="upstream-r1" mtu=1500 mac-address=48:8F:5A:1A:28:BA arp=enabled
      arp-timeout=auto slaves=sfp-sfpplus1 mode=802.3ad primary=none
      transmit-hash-policy=layer-2-and-3 min-links=0 mlag-id=100
 2  R name="upstream-r2" mtu=1500 mac-address=48:8F:5A:1A:28:BB arp=enabled
      arp-timeout=auto slaves=sfp-sfpplus2 mode=802.3ad primary=none
      transmit-hash-policy=layer-2-and-3 min-links=0 mlag-id=101
Configuration on switch 1 (secondary)
[user@SW-1] /interface/bridge/mlag> print
     bridge: bridge
[user@SW-1] /interface/bridge/port> print
IZON
[user@SW-1] /interface/bridge/vlan> print
Flags: D - DYNAMIC
0   bridge       102  upstream-r2
                      client-bond1
                      upstream-r1
                      sfp-sfpplus3
1   bridge         1  sfp-sfpplus3    bridge
                                      upstream-r2
                                      client-bond1
                                      upstream-r1
[user@SW-1] /interface/bonding> print
 0  R name="client-bond1" mtu=1500 mac-address=C4:AD:34:F4:7C:45 arp=enabled
 1  R name="upstream-r1" mtu=1500 mac-address=C4:AD:34:F4:7C:36 arp=enabled
 2  R name="upstream-r2" mtu=1500 mac-address=C4:AD:34:F4:7C:37 arp=enabled
benoitc
Re: MLAG: when primary is shutdown LACP stops to work
Sat Mar 26, 2022 6:59 pm
this seems to be related to freebsd asthe interface is automatically up in the routers. But can someone confirm the behaviour is expected (putting on pause the peer port status) ?
so to summarize:
* shutdown/rebooting secondary switch is done without any issue, network stays up
* disconnecting a cable is also working OK
* removing routers works as expected
* shutdown primary router introduces a delay before the connection is up again. I don't why exactly. Maybe a bug in freebsd 13 or a setting to change ?
adcre
Mon Mar 28, 2022 12:49 am
Can you post your interface configuration?
I think maybe is related to the vlans and you have same problem that op has on this post:
viewtopic.php?p=917617&hilit=mlag#p903356
Best Regards,
Diego
benoitc
Tue Mar 29, 2022 3:26 pm
Best Regards,
Diego
yeah I think i handled it but I wouldn't be against of another pair of eyes :))
Here are the relevant parts:
/interface bonding
add lacp-rate=1sec mlag-id=10 mode=802.3ad name=client-bond1 slaves=\
sfp-sfpplus16 transmit-hash-policy=layer-2-and-3
add mlag-id=200 mode=802.3ad name=client-bond2 slaves=sfp-sfpplus15 \
add mlag-id=102 mode=802.3ad name=home-bond slaves=sfp-sfpplus5 \
add mlag-id=100 mode=802.3ad name=upstream-r1 slaves=sfp-sfpplus1 \
add mlag-id=101 mode=802.3ad name=upstream-r2 slaves=sfp-sfpplus2 \
set bridge=bridge peer-port=sfp-sfpplus3
add bridge=bridge interface=sfp-sfpplus3 pvid=99
add bridge=bridge interface=client-bond1
add bridge=bridge interface=upstream-r1
add bridge=bridge interface=upstream-r2
add bridge=bridge interface=home-bond
add bridge=bridge interface=client-bond2
interface bridge vlan
add bridge=bridge tagged=\
sfp-sfpplus3,client-bond1,upstream-r1,upstream-r2,home-bond,client-bond2 \
vlan-ids=102
add bridge=bridge tagged=sfp-sfpplus3 vlan-ids=1
upstream-r1,upstream-r2,client-bond1,home-bond,client-bond2 vlan-ids=99
add bridge=bridge tagged=home-bond vlan-ids=101
add bridge=bridge tagged=home-bond vlan-ids=2
add bridge=bridge tagged=home-bond vlan-ids=3
add bridge=bridge tagged=home-bond vlan-ids=4
EdPa
Tue Mar 29, 2022 4:14 pm
Hi benoitc,
How long is the introduced delay? Could it take up to 30 seconds?
When both MLAG switches are up, the secondary switch will change the LACP system-id and it will use the same system-id as the primary. This allows connecting regular LACP clients to two different physical switches while the client thinks it is connected to the same switch. You can monitor the "lacp-system-id" using the "/interface/bonding monitor" command and see how it changes after connecting/disconnecting the primary switch.
When the MLAG connection is lost, both switches will start to work independently. For the primary switch, it does not change anything, because the same LACP system-id is used in both scenarios. However, when the secondary switch loses the MLAG connection, it will change the LACP system-id to local values and perhaps this is the reason why connection delay and packet loss might appear?
Do you know if FreeBSD supports a 1-second LACP rate? In RouterOS, you can set it using "lacp-rate=1sec". Perhaps using a quicker LACP rate will decrease the introduced delay?
Last, you are using the pvid=99 on peer-port, while using the same VLAN in "/interface bridge vlan" menu. Try setting the peer-port to some unused untagged VLAN, e.g. pvid=999.
adcre
Tue Mar 29, 2022 11:39 pm
@EdPa i think is using vlan99 as the example shown in https://help.mikrotik.com/docs/display/ ... Quicksetup
@benoitc can you check if you have vlan filtering on the bridge?
Best Regards,
Diego
benoitc
Wed Mar 30, 2022 2:11 pm
Hi benoitc,
That may be around 30s yes; I will recheck. I noticed also there are some delay on the server due to bird esetting the routes on changes. I need to retest. For the rate, I did't found yet an option for it but stillooking. I will report soon .
As for the vlan it's only usedd for ctl. I have misread the doc and tagged the other devices for it. This is fixed now :) Thanks for the hilight :)
benoitc
Wed Mar 30, 2022 2:12 pm
Best Regards,
Diego
yes it has filtering enabled. . I will do a new test session later today , I will report it son :)
kocifi
Tue May 16, 2023 8:13 pm
Best Regards,
Diego
@benoitc Were you able to resolve it?
Users browsing this forum: alan3664, Amazon [Bot], Bing [Bot], deadmaus911, Google [Bot], itvisionpk and 64 guests
