HM4tech
DMZ in mikrotik router
Sun Mar 27, 2022 9:05 pm
Hello guys,
please could anyone know how to configure DMZ configuration in Mikrotik Router , i searched on google and i just found articles for port forwarding.
Thanks in advance .
anav
Re: DMZ in mikrotik router
Mon Mar 28, 2022 7:42 pm
Describe in more detail what you would like to accomplish and a network diagram will help.
mkx
Mon Mar 28, 2022 7:57 pm
As @anav tried to explain, there isn't such thing as DMZ check in RouterOS. It's very much possible to construct one, but as it's custom job, it can be nicely adjusted to requiremenrs.
rextended
Mon Mar 28, 2022 8:26 pm
@anav is allergic to the DMZ (and also I...) :roll:
Guscht
Mon Mar 28, 2022 9:00 pm
A DMZ is basically a isolated VLAN. Its easy to built this...
anav
Mon Mar 28, 2022 10:11 pm
Stunning I might bronze those words....................
But all useless until we understand the requirements and network.
bpwl
Mon Mar 28, 2022 10:44 pm
Not even VLAN ... :D ... "A DMZ is basically an isolated LAN. Its easy to built this... as a physical port or as a VLAN"
Don't connect it to the bridge, direct route setting will be automatic, but do set in the firewall what can pass and what cannot. (Fully depends on requirements)
rextended
Mon Mar 28, 2022 11:07 pm
From "standard" point of view of some routers, a DMZ is a simply "redirect" all (un)wanted traffic, not previously assigned to something, to an IP on SAME SUBNET of the Router LAN, no VLAN involved...
anav
Mon Mar 28, 2022 11:30 pm
DMZ is a military term co-opted by IT folks............. and grossly misrepresented. ;-)
an area, agreed upon between the parties to an armed conflict, which cannot be occupied or used for military purposes by any party to the conflict.
ameer456
Wed Feb 08, 2023 9:36 am
Well, I'm preparing to adjust my routers (after purchasing my second Mikrotik) as follow:
Fiber Modem (bridge) >> Mikrotik 1 "pppoe" (192.168.1.1) >>> Mikrotik 2 (10.0.0.1 "static ip from Mikrotik1: 192.168.1.60")
Currently on fiber modem I just tick DMZ & choose 192.168.1.60 (Mikrotik2), so Mikrotik 2 handle all the firewall.
How can I do that when the Mikrotik 1 will replace the modem?
Users browsing this forum: Kanzler and 30 guests
