VincentL
[ROS6.x] Generate a random number in a range.
Mon Mar 28, 2022 3:22 pm
I'm jealous about the ROS7 rndnum !
At the moment, I can't upgrade all my routers, so I'm looking for a simple way to generate a random number between a given range.
I found some examples on Internet, but the are really tricky.
Did you have tips to do this easily ?
Regards,
Vincent
Jotne
Re: [ROS6.x] Generate a random number in a range.
Mon Mar 28, 2022 3:39 pm
Just a quick search on this forum and you can find multiple post.
viewtopic.php?f=9&t=56933
viewtopic.php?f=9&t=175453&p=858629
VincentL
Mon Mar 28, 2022 4:45 pm
@Jotne :
Thank you for your links.
I've found the first one, and it's what I've called "tricky" .
I'll have a look to the second, I've have not found previously.
Regards,
Vincent
Users browsing this forum: No registered users and 40 guests
