Zaphod42
lte interface disappears beyond 6.42.10
Mon Mar 28, 2022 11:19 pm
I have a ltAP Mini RB921R-2nD-LTm. If I upgrade the firmware beyond 6.42.10 the lte interface disappears and is no longer addressable.
I have tried this up and down the versions available. The firmware-upgrade command for OTAP upgrading the lte firmware was not introduced till 6.44 so I cannot attempt to upgrade the lte individually.
Can anyone help me to get the lte interface back up at a higher firmware version?
hecatae
Re: lte interface disappears beyond 6.42.10
Tue Apr 05, 2022 2:46 am
Which r11e-lte is inside your Ltap mini?
By firmware do you mean routerboard firmware or routers?
rfc1149
Tue Apr 05, 2022 12:37 pm
Software version is different from firmware. It's best to be specific.
Mobile network cards have firmware, routers/AP/switches etc. have software and MikroTik calls the bootloader of the device a RouterBOARD firmware.
You need to provide:
1) Your device's ROS version (and RouterBOARD firmware version, usually forgotten to be upgraded by some)
2) Your mobile network card model (e.g R11e-LTE6) and last known firmware it was running
In some cases, you can try resetting the USB port for the card but I'm guessing this as not all cards present a USB interface.
rextended
Tue Apr 05, 2022 9:59 pm
On MikroTik point of view:
BIOS / BootLoader / Firmware = RouterBOOT
Software / OS = RouterOS
BIOS (yes...) + Software inside the modem = Revision
Example:
Model (RouterBOARD) = SXTR
Factory Firmware = 6.47.10
Current Firmware = 6.48.6
RouterOS = 6.46.8
Model (R11e-xxx) = R11e-4G or R11e-LTE or R11e-LTE6 or R11e-LTE6A or R11e-LTE-US
Revision = R11e-4G_V007 or MikroTik_CP_2.160.000_v020 or R11e-LTE6_V033 or R11e-LTE6A_V002 or R11eL_v16.02.183961
rfc1149
Tue Apr 05, 2022 11:25 pm
Ah thanks, I got misled from https://wiki.mikrotik.com/wiki/Manual:U ... re_Upgrade:
Next step after the RouterOS upgrade is firmware (bootloader) upgrade.
I knew they have that name for the bootloader but I always referred to it as firmware because of that step.
Users browsing this forum: No registered users and 90 guests
