eldoncito2019
Activate Script
Tue Mar 29, 2022 11:44 pm
I have the following script and I want it to be activated when I don't have internet and deactivate when I have internet. Thanks for your help.
:global script false;
:do {
/if condition=([/ping 1.1.1.1 count=6] =0) else={:put "if there is internet"}
do={:put "there is no Internet"}
:delay 6;
} while=(!$script)
EL DONCITO.
Jotne
Re: Activate Script  [SOLVED]
Thu Mar 31, 2022 8:27 am
No need to use ping in script.
What you do is to use netwatch.
There you can have a script for up/down information.
Script name: Netwatch
# Netwatch script
# Used as both up and down script
# Created Jotne 2021 v1.5
:local Host $host
/tool netwatch
:local Status [get [find where host="$Host"] status]
:local Comment [get [find where host="$Host"] comment]
:local Interval [get [find where host="$Host"] interval]
:local Since [get [find where host="$Host"] since]
:log info "script=netwatch watch_host=$Host comment=\"$Comment\" status=$Status interval=$Interval since=\"$Since\""
Then add an IP to monitor like this:
/tool netwatch
add down-script=Netwatch host=8.8.8.8 up-script=Netwatch
See more information here: viewtopic.php?p=888800#p888800
eldoncito2019
Re: Activate Script
Thu Mar 31, 2022 8:23 pm
# Netwatch script
:local Host $host
/tool netwatch
/tool netwatch
Thanks for your answer friend, and how do I store it in a file?
rextended
Re: Activate Script
Thu Mar 31, 2022 8:28 pm
Ehm.. what file for what? :shock:
rextended
Re: Activate Script
Thu Mar 31, 2022 8:37 pm
# Netwatch script
:local Host $host
Uh... nice catch @Jotne...
The possibility to use $host inside netwatch is not documented...
Where you find it?
Jotne
Re: Activate Script
Thu Mar 31, 2022 8:44 pm
Not sure where I get it from. May have seen it some place and start using it.
Users browsing this forum: No registered users and 41 guests
