jerdelji
SXT LTE no Signal problem
Wed Mar 30, 2022 9:26 am
Hi All,
I ordered two SXT LTE modems for my customers. The first one workes just fine, when I insert the SIM card and find direction it works. I have a problem with the second one. Same position and the same SIM card and there is no signal. I need Your help to find the solution.
hecatae
Re: SXT LTE no Signal problem
Wed Mar 30, 2022 10:48 pm
Please upgrade RouterOS to the latest long-term version.
Have you opened up the sxt as it looks like the antenna cables are not attached.
holvoetn
Wed Mar 30, 2022 11:38 pm
Quite some improvements have been done for LTE devices, especially as of 7.2rc5.
I have an SXT LTE6 running that version and have no problems whatsoever.
If the device is under warranty, I suggest to first check with the vendor if you will not loose warranty when opening the device.
Maybe best to request replacement.
AidanAus
Mon Apr 04, 2022 8:41 am
I would second this, I know at least with the sq units that the case is 'plastic welded' together so you would have a hard time getting the case back together again if this is the case with the LTE 6 models.
rfc1149
Mon Apr 04, 2022 1:06 pm
I third this! :D
On a serious note though, there is not enough information to diagnose this as the antennas being disconnected.
Opening the case should be a last resort when the most sensible causes have been eliminated.
Users browsing this forum: No registered users and 12 guests
