olivier56
one ip use specific gateway
Wed Mar 30, 2022 8:54 pm
I have two wan' 192.192.168.1.254(box) and 192.168.88.1(lte).
I would like the ip of my lan 192.168.2.3 to only use wan 1 (192.168.1.254)
chain=prerouting action=mark-routing new-routing-mark=to-SERVER passthrough=yes src-address=192.168.2.3 log=no log-prefix=""
I do mark routing but each time I have the following error
PR_CONNECT_RESET_ERROR
Échec de la connexion sécurisée
Une erreur est survenue pendant une connexion à www.youtube.com. PR_CONNECT_RESET_ERROR
La page que vous essayez de consulter ne peut pas être affichée car l’authenticité des données reçues ne peut être vérifiée.
Veuillez contacter les propriétaires du site web pour les informer de ce problème.
when I do a tracert on 8.8.8.8 the path is the correct one
Détermination de l’itinéraire vers dns.google [8.8.8.8]
avec un maximum de 30 sauts :
1 <1 ms <1 ms <1 ms 192.168.2.1
2 <1 ms <1 ms <1 ms 192.168.1.254
3 39 ms 38 ms 38 ms 194.149.169.212
4 37 ms 38 ms 38 ms 194.149.166.58
5 39 ms 37 ms 39 ms 72.14.221.62
what is my mistake
thank you
anav
Re: one ip use specific gateway
Wed Mar 30, 2022 9:05 pm
Would need to see your config for a complete assessment but..........
If using vers7,...........
Need an additional route
dst-address=0.0.0.0/0 gwy=wan1-gatewayIP useWAN1
/routing table add name=useWAN1 fib
/routing rule add src-address=192.168.2.3/32 action=lookup-only-in-table table=useWAN1
olivier56
Wed Mar 30, 2022 10:08 pm
hi
routing for 192.168.2.3
0000/0 gateway 192.168.1.254 roiting mark to -server
olivier56
Wed Mar 30, 2022 10:16 pm
hi
thank you work fine.
i don t know , i can use rule for this and not mangle table.
More easy
:D :D :D
olivier56
Wed Mar 30, 2022 10:19 pm
what is "If using vers7,.."
anav
Wed Mar 30, 2022 11:22 pm
Well the rule structure has changed between version 6 series firmware and version 7 series firmware.
The solution provided is geared towards the newer version 7 firmware.
olivier56
Sun Apr 03, 2022 12:48 pm
hi
sorry i upgrade to 7.15
make your code and now not good.
i do something wrong maybe
br
anav
Sun Apr 03, 2022 1:31 pm
Without seeing your config dont know.......
If you had wanted it for vers6, you only needed to ask LOL.
/export file=anynameyouwish
Also print the IP routes page details.
olivier56
Sun Apr 03, 2022 1:42 pm
hi
sorry is my fault.
i have two ethernet in my serveur after upgrade 2019 to 2022 i forgot to switch off 2 ethernet.
work fine now.
:lol: :lol: :lol: :lol:
peracchi
Sat Apr 09, 2022 11:41 pm
Hi, newbie here, trying to use your suggestion but maybe there is something wrong with first command that I still do not figure out.
Using RouterOS v7.2 .
peracchi
Sun Apr 10, 2022 12:07 am
After some trials, I think I found the right commands:
/routing table add fib name=ISP1
/routing rule add action=lookup-only-in-table src-address=10.22.22.33/32 table=ISP1
/ip route add dst-address=0.0.0.0/0 gateway=172.217.162.206 routing-table=ISP1
8)
Users browsing this forum: Javokhir, zalciukaz and 106 guests
