glenno
Log sort bug in 7.2.rc5
Thu Mar 31, 2022 5:37 am
I havent noticed this in versions before 7.2.rc5 on my HAP AC2. The sort by date doesnt work in descending order. There appears to be a logic error thinking that log event 101 is newer than log event 194
holvoetn
Re: Log sort bug in 7.2.rc5
Thu Mar 31, 2022 10:08 am
Are there between event 101 and 194 indications of time change, like NTP or so ?
I hope the event numbering remains chronological, regardless what happens.
I am trying to derive some logic but it doesn't make sense indeed ...
If column Time is used, it should sort correctly whatever there is behind the scenes.
Have you reported this to support@mikrotik.com ?
Adding: are you seeing the same behavior in Winbox ? Could be Webfig specific, that's why I ask.
glenno
Thu Mar 31, 2022 2:53 pm
There are no NTP events. The issue appears to be a logic error with the sorting descending and how it interprets the 24 hour times, ie it can’t handle whether 00-1200hours is newer or older than 1300-23:99 hours.
Sorting any other way works a treat. Sorting by Time ascending works fine etc.
Just reported it here so someone might incorporate a fix into the next build. Didn’t need any support.
rextended
Thu Mar 31, 2022 3:06 pm
Test it on new release:
viewtopic.php?t=184585
holvoetn
Thu Mar 31, 2022 3:07 pm
Support does not read this forum.
Best to report to support@mikrotik.com.
jookraw
Tue Apr 05, 2022 1:55 pm
What happens if you sort by # instead of date?
rextended
Tue Apr 05, 2022 2:33 pm
Users browsing this forum: Fasder and 18 guests
