bublikoff
How to passthrough LTE with ipv4 and ipv6
Thu Mar 31, 2022 2:12 pm
How to passthrough LTE with ipv4 and ipv6?
IPv4 works OK ... but can not manage to work both ipv4 nd ipv6 the same time
There is no even IP type ipv4ipv6
ROS 7.2rc7
aesmith
Re: How to passthrough LTE with ipv4 and ipv6
Thu Mar 31, 2022 5:12 pm
If you remove the passthrough configuration, does the LTE interface receive an IPv6 address?
bublikoff
Sun Apr 03, 2022 6:23 pm
Yes, my mobile operator does support ipv6 ... the main problem is to get ipv6 and ipv4 the same time ...
Current router firmware ROS v.7.2rc7
tdw
Sun Apr 03, 2022 7:16 pm
Does the carrier provide dual-stack IPv4 and IPv6 at the same time, or do they provide IPv6 with IPv4 tunneling support (e.g. DS-Lite, Lw4o6, 464XLAT, NAT64/DNS64 or MAP-T/E) which requires the client device to implement the their end of the tunnel?
Also you will likely get a /64 IPv6 address so you can only use one subnet.
Zacharias
Sun Apr 03, 2022 7:51 pm
What do you mean ?
In the APN menu there is an IP type field where you can select both IPv4 and IPv6.
After that you enable the passthrough feature...
And ofcorse in the LTE general tab you should select the correct APN profile.
gabeluci
Mon Jul 18, 2022 4:58 pm
What do you mean ?
I'm curious about this too. In WinBox, in the APN config, if I have IP Type set to "Auto" and try to enable Passthrough, I get an error message saying, "Passthrough can not be used with ipv6-interface! (6)"
Busily5562
Wed Aug 31, 2022 4:23 pm
What do you mean ?
Did you manage to get it sorted ?
gabeluci
Wed Aug 31, 2022 6:51 pm
No. Honestly, I just gave up on IPv6 for now and disabled it.
hifigraz
Thu May 11, 2023 5:13 pm
Same here, it's really sad, that this does not work.
Users browsing this forum: unhuzpt and 92 guests
