aW50ZXJuZXQ
can not connect to rb750gr3 webgui
Thu Mar 31, 2022 10:08 pm
I have problems connecting to my microtik RB750Gr3. First everything went well and I started doing basic installation. The problem occurred when I changed the ip from 192.168.88.1 to 10.0.0.1. Then I did not manage to connect anyone. I decided to do a reset but it did not help. So now I can not connect at all and get no ip address from the router. If I connect it to the internet, the router gives my external IP address and I get out on the internet.
What can I do to restore it? I'm following this guide.
How to reset configuration
1) unplug the device from power
2) press and hold the button right after applying power
Note: hold the button until the LED will start flashing
3) release the button to clear configuration.
aW50ZXJuZXQ
Re: can not connect to rb750gr3 webgui
Fri Apr 01, 2022 12:26 am
Update. I tired to run netinstall and the installation went well both with 7.1.5 and 6.48.6 But I still cant connect to the router and I dont get any ip from the dhcp-server on the router.
Sob
Fri Apr 01, 2022 4:29 am
Try WinBox, select Neighbors tab and you should see the router there. Click its MAC address and try to connect to that.
holvoetn
Fri Apr 01, 2022 1:17 pm
Make sure your PC is connected to the device NOT using ether1.
Users browsing this forum: Amazon [Bot] and 57 guests
