biostein
zerotier bridge question
Fri Apr 01, 2022 7:58 pm
Hi all,
So I have zerotier up and running on my personal devices with no issues. Using cell or home wifi. I can ping said devices via zerotier ip's.
The only device I can not seem to ping is my router running a zerotier interface.
The interface has traffic going across it via torch. But when I ping ---- I get no response back. Under connections---- I can see the zerotier making connections.
Do yall have any guidance on the best way to trouble shoot?
k6ccc
Re: zerotier bridge question
Fri Apr 01, 2022 8:00 pm
Firewall rules in the Input chain?
biostein
Fri Apr 01, 2022 8:05 pm
New to posting stuff in the code box. Hopefully I did that correctly.
I have disabled the zerotier interface rules--- they where being used for testing.
Edit --- forgot to add that I added the zerotier to a bridge. Thinking that might fix it. --- It did not.
/ip firewall layer7-protocol
add name=rdp regexp="rdpdr.*cliprdr.*rdpsnd\""
add action=drop chain=input dst-port=53 in-interface-list=WAN protocol=tcp
add action=drop chain=input dst-port=53 in-interface-list=WAN protocol=udp
add action=accept chain=output disabled=yes out-interface=zerotier1
add action=accept chain=forward disabled=yes out-interface=zerotier1
add action=accept chain=input disabled=yes in-interface=zerotier1
add action=accept chain=input comment="allow ICMP" protocol=icmp
add action=accept chain=forward connection-nat-state=dstnat connection-state=new in-interface-list=WAN
add action=accept chain=input connection-nat-state=dstnat connection-state=new in-interface-list=WAN
add action=fasttrack-connection chain=forward comment="fast-track for established,related" connection-state=\
    established,related hw-offload=yes
add action=accept chain=forward comment="accept established,related" connection-state=established,related
add action=accept chain=input comment="accept established,related" connection-state=established,related
add action=accept chain=input in-interface-list=LAN
add action=accept chain=forward in-interface-list=LAN
add action=accept chain=input comment="allow Winbox" in-interface=bridge1 port=8291 protocol=tcp
add action=accept chain=input comment="allow SSH" in-interface=bridge1 port=22 protocol=tcp
add action=accept chain=forward protocol=tcp src-port=80
add action=accept chain=forward protocol=tcp src-port=443
add action=accept chain=forward layer7-protocol=rdp
add action=drop chain=input comment="drop invalid" connection-state=invalid log=yes
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=drop chain=input log=yes
add action=log chain=forward log=yes
add action=log chain=input log=yes log-prefix=log
biostein
Fri Apr 01, 2022 8:21 pm
I dont think its a firewall thing--- mainly cause I see the connections going out--- I feel more like I messed up a configuration of the zerotier part
biostein
Fri Apr 01, 2022 8:41 pm
update --- so I can ping the ip of the zerotier router --- ie my router on the zerotier interface --- via ping from the MT router.
But I can not ping the zerotier network from the interface.
biostein
Fri Apr 01, 2022 10:36 pm
So update --- I can see torch traffic on the zero tier interface. I can see traffic across the firewall from said interface.
I see routes in the routes table.
I am stumped.
biostein
Re: zerotier bridge question  [SOLVED]
Fri Apr 01, 2022 10:48 pm
So what I did to fix -- made the subnets match and turned on bridge mode for the router, on zerotier side.
Users browsing this forum: m4rk3J and 43 guests
