eldoncito2019
Files in File
Fri Apr 01, 2022 10:49 pm
Friends, I have the following script:
:local a ("court");
:local data1 (" at: " elaborate script
by: FRANK MU/OZ") ;
/file print file=$a
/file set $a contents=$data1;
and I want it to save a .TXT file to file.
Thank you for your answers.
EL DONCITO.
rextended
Re: Files in File
Sat Apr 02, 2022 12:02 am
this is invalid:
by: FRANK MU/OZ") ;
elaborate script ????
also put the script inside code blocks
What mean:
"and I want it to save a .TXT file to file" ???
At the end of this:
:local a "court"
:local data1 "do not write random text and call it script"
/file
print file="$a"
the file court.txt is created.
And for do something better, if the file must persist on reboot, this create the file inside flash disk on Flash devices without modifing the script when used on NAND devices.
:local a "court"
:if ([:len [/file find where name="flash" and type="disk"]]=1) do={:set a "flash/$a"}
/file
print file="$a"
eldoncito2019
Re: Files in File
Sat Apr 02, 2022 4:44 pm
this is invalid:
by: FRANK MU/OZ") ;
What mean:
At the end of this:
:local a "court"
/file
print file="$a"
:global Gprfx ""
:if ([:len [/file find where name="flash" and type="disk"]]=1) do={:set Gprfx "/flash"}
:local a "$Gprfx/court"
/file
print file="$a"
Very grateful for your answer friend, now how do I place the script as you have it here, shaded in blue, I don't know much about the forum
EL DONCITO.
rextended
Re: Files in File
Sat Apr 02, 2022 5:02 pm
Select a text and click on [] icon
eldoncito2019
Re: Files in File  [SOLVED]
Sat Apr 02, 2022 5:30 pm
:local a ("court");
by: FRANK MU/OZ") ;
/file print file=$a
Very grateful friend
EL DONCITO.
Users browsing this forum: No registered users and 52 guests
