Thomas73951
Port forwarding problems
Sun Apr 03, 2022 8:16 pm
Hi, I'm trying to get portforwarding working and have tried quite a few things but nothing has worked.
The setup is a little strange cause the fttc comes in and goes to a technicolor router first (using it as a "modem", wifi disabled and one ethernet connected, to ether1 of mikrotik router) which has login details then using a mikrotik router to connect to all the devices.
I have tried:
  • adding port forwarding to technicolor router & setting it's firewall to low meaning it wont silently drop incoming traffic
  • disabling "drop all not coming from LAN" rule
  • various versions of the dstnat rule for port forwarding
testing with https://www.yougetsignal.com/tools/open-ports/
add action=accept chain=input comment="Management" dst-port=22 protocol=tcp src-address=[redacted]
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat comment="Port forwarding" dst-port=25565 in-interface=ether1 protocol=tcp to-addresses=192.168.88.176
Any ideas?
Thanks in advance
Thomas :)
anav
Re: Port forwarding problems
Sun Apr 03, 2022 8:32 pm
have to see the whole config, nothing of significance to stop port forwarding in what you have shown!
Plus how does inbound traffic get from first device to mikrotik? public IP, private IP??
Sob
Sun Apr 03, 2022 8:47 pm
Two things:
- Your dstnat rule, if you check its counters, are they non-zero?
- Mainly if not, public address, do you know what it is and are you sure you have it (on the first router)?
Thomas73951
Sun Apr 03, 2022 9:50 pm
Here's the exported:
# apr/03/2022 19:28:44 by RouterOS 6.44.6
# software id = X6DX-16TW
# model = RBD52G-5HacD2HnD
# serial number = [redacted]
add admin-mac=C4:AD:34:9C:53:93 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment="adsl link"
/interface pppoe-client
add add-default-route=yes interface=ether1 name=pppoe-out3 use-peer-dns=yes \
    user=[redacted]
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=[redacted] \
    wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto mode=\
    ap-bridge ssid=[redacted] wireless-protocol=802.11 wps-mode=disabled
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/dude
set enabled=yes
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=pppoe-out1 list=WAN
add comment="v usb tethering with moto g6 to unlimited smarty plan." list=WAN
add comment="ADSL link" list=WAN
add comment="adsl ether 1" interface=ether1 list=WAN
    192.168.88.0
add address=192.168.1.102/24 comment=adsl interface=ether1 network=\
    192.168.1.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment="Management" dst-port=22 protocol=\
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=dst-nat chain=dstnat comment="Port forwarding" dst-port=25565 \
add comment="adsl the one i added" distance=1 gateway=192.168.1.1
/ip smb
set enabled=yes
/ip smb shares
add directory=/disk1 name=disk1share
/ip smb users
[redacted]
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/London
/system identity
set name=[redacted]
/system logging
add topics=lte
/system package update
set channel=long-term
/tool graphing interface
add interface=pppoe-out1
/tool mac-server
/tool mac-server mac-winbox
Mikrotik is at 192.168.88.1 as usual and that connects to technicolor at 192.168.1.1 which I believe then connects to the public ip.
currently at 5kib with 94 packets so tiny but non zero. (this is with that drop all not from lan rule enabled)
anav
Sun Apr 03, 2022 11:18 pm
Your setup is confused on the wan side.
Why do you have any pppoe client if the IP is a fixed private IP from an ADSL modem?
Further its not clear how the modem pushes any traffic to the mikrotik?
Is there a port forwarding menu on the modem, or a way to set static routes?
Thomas73951
Tue Apr 05, 2022 7:51 pm
That's a good point, when I was trying to get something to work I did try quite a few things and didn't tidy up. I've removed all of them except the correct one which is the ether1 one.
Hmm ok, so because the public/private ip "barrier" would be at the "modem", I should be doing the port forwarding from there?
I've had a better look at the technicolor end and it seems to have its own dhcp server because the only ip it autocompletes is 192.168.1.102. It will only accept 192.168.1.X address in that field.
Looking from the mikrotik end:
The technicolor does have something for static routes but I can't change anything on there.
Sob
Tue Apr 05, 2022 8:17 pm
Yes, you need to forward port from first router. If static routes and forwarding directly to .88.x address doesn't work, then use whatever RB gets on ether1 (192.168.0.103 according to your screenshot). You must have had that before if dstnat rule on RB had non-zero counters.
anav
Re: Port forwarding problems  [SOLVED]
Tue Apr 05, 2022 8:45 pm
As sob stated, the technicolor port forward has to be the same PRIVATE IP that the mikrotik is getting from the technicolour modem
Then it will all work!
If you think about it, the Technicolour modem has not awareness of the private LAN behind the mikrotik it is hidden behind NAT.
Thus the router doesnt know where to send the information.
However the technicolor knows about the mikrotik so it will send the traffic onward to the MT, for the destination port on the incoming traffic.
The MT will get the traffic and say oh okay for that destination port, I have a dst-nat rule, and the filter rule allows such traffic and it will reach the intended server.
Thomas73951
Thu Apr 07, 2022 12:09 pm
Ah that makes a lot of sense.
Setting technicolor to .1.103 (and opening the server) fixed it. Now works flawlessly.
Thank you both :)
Users browsing this forum: Google [Bot] and 52 guests
