apzaldivar
Mikrotik LHG 5 is not recognized by winbox after being reset
Mon Apr 04, 2022 4:20 am
Hello, I have a Mikrotik LHG 5 and after doing a reset, the winbox does not recognize it. What I can do?
AidanAus
Re: Mikrotik LHG 5 is not recognized by winbox after being reset
Thu Apr 07, 2022 10:28 am
Are you able to give us a little more information on what you mean by recognise?
Are you able to tell us if the networking device or PC recognised a layer one connection, on a mikrotik device the interface will say running or if you are connecting this directly to a PC in your network status tab it should indicate that a cable is plugged?
If this is not the cause I would check on the device to make sure the power light is on etc.
If you are able to get a layer 1 connection I would suggest typing in the mac address of the ethernet port into inbox and see if it is able to connect, if you are connecting through a mikrotik device I would first make sure that the port to the LHG and the PC are bridged together and if they already are I would check the bridge>hosts table to see if there is 2 devices at least reported one for the interface going to the LHG 1 and should have DL next to it and the other will be for the LHG its self and it will say D
If you do not see this try another port and cable and see if that helps.
report back what you find and we can help further troubleshoot from there
Users browsing this forum: Pilo2710, roemer, VMX and 63 guests
