ahmedelbarbary
Re: v7.2 is released!
Sun Apr 10, 2022 7:12 pm
Yes you are right hEX in v7 unstable, interfaces down and up, pppoe all time disconnect
hecatae
Sun Apr 10, 2022 8:36 pm
Chateau 5G upgraded successfully
ksteink
Sun Apr 10, 2022 10:11 pm
Too many issues with my L2TP/IPSec connections. Remote endpoints pings but I cannot connect to them (get timeout). Next day after a reboot I saw error on Phase 2 IPSec negotiations and all VPNs were down.
DHCP static lease also broke so I lost local LAN routing to a L3 switch.
Sorry, too many issues and bugs (in top of others) that I had to pull off my RB5009 and put my old hEX S with version 6.49.5 and downgrade my remote hEX S as well to version 6.49.5 to get stability and VPNs working normally. I will try again the RB5009 with version 7.1.5 with a script to fix the IPSec identities issue as work around.
I don't see this version Stable enough and I am holding any testing or upgrading other routers until there is a version that is really stable.
I am so annoyed and disappointed.
mhenriques
Sun Apr 10, 2022 10:25 pm
After upgrading from V7.1.5 to V7.2 on my RB5009 I'm getting the following message on System - RouterBOARD option:
Warning: cpu not running at default frequency
Maurício
msatter
Sun Apr 10, 2022 10:31 pm
Mikrotik forgot to disable the warning it seems. Maybe next time... ;-)
bluecrow76
Sun Apr 10, 2022 11:13 pm
OpenVPN client broken with AES-256-CBC since upgraded to RouterOS 7.2 (from 7.1.5), switching to Blowfish 128 works.
Echoing the experience. Upgraded from 7.1.5 to 7.2 and some OpenVPN clients using AES on some routers are broken. It does not matter which AES cipher is chosen... none of them work with OpenVPN after the upgrade.
I sent the following information to Mikrotik support:
Subject: RouterOS 7.2 - OpenVPN client with AES appears broken on some routers
OpenVPN client with AES appears to be broken on some routers in RouterOS 7.2. Configs worked just fine prior to upgrade from 7.1.5. Client logs show connecting… disconnected… connecting… disconnect… but no error message. Logs on OpenVPN server (also Mikrotik devices) show no errors. Setting cipher on client and server to blowfish128 will allow tunnel to connect and stay connected. Issue appears only with AES on the following routers:
MMIPS (RB750Gr3, RB760iGS) – OpenVPN AES client FAILED
ARM (RB4011iGS+) – OpenVPN client with AES WORKED
CHR – OpenVPN client with AES WORKED
MIPSBE - OpenVPN client with AES WORKED
POWERPC (RB1200) – OpenVPN client with AES WORKED
TILE (CCR1009-7G-1C-1S+) – OpenVPN client with AES WORKED
Original notes:
Started to test RouterOS 7.2 last night. Upgraded my home office router first (RouterBOARD 750G r3 s/n 6F3806195642) from 7.1.5 to 7.2. This router has several production VPN client connections of various types (L2TP/IPSEC, OpenVPN, SSTP, and Wireguard) to remote Mikrotik devices of various types.
My L2TP/IPSEC, SSTP, and Wireguard client connections worked properly after the upgrade, but my OpenVPN connections would not connect. Two of these were OpenVPN TCP client to RouterOS 7.1.5 CHR instances and one to a Mikrotik 760iGS running 6.49.5. If I use any of the AES ciphers, the connections just bounce (connected… disconnected… connected… disconnected…) with no error messages. If I set the cipher to blowfish128, the OpenVPN clients connect and operate properly.
I then upgraded some other test routers from 7.1.5 to 7.2: two CHR instances, an old RB1200, and an RB760iGS.
•	The CHR instances have no problems to other RouterOS OpenVPN servers regardless of protocol (tcp or udp) and cipher.
•	The RB1200 and the RB760iGS routers both fail in the same way my home office router fails. Switching the cipher to blowfish128 allows the VPNs to work.
It appears that there is some sort of issue with the OpenVPN AES cipher on certain RouterOS devices in 7.2
As a last test, I took a fresh RB760iGS router out of the box, upgraded it to 7.2, factory reset the config again (no-defaults=yes) added my test VPN configuration, and created the attached supout.rif file.
Please let me know if I can provide any additional information
4/11/2022 Edit: Mikrotik support confirms there is an issue that is affecting the mmips based routers with OpenVPN AES and says it will be resolved in the next release. 🤞
deadkat
Mon Apr 11, 2022 1:10 am
home user here:
most of my devices upgraded with no issues, devices upgraded include
1x RB3011
2x RBLHG-2nD
2x RBLHG-5HPnD
1x RB931-2nD (hAP mini)
2x RB960PGS (hEX poe)
1x RBmAP2n
1x RB952Ui-5ac2nD (hAP ac lite)
the one device I attempted upgrading that failed was a RBD52G-5HacD2HnD (hAP ac2), "not enough space for upgrade"
thankfully, its a very basic config (just a wireless AP with all ports bridged) so I plan to netinstall later and just reconfigure from memory.
I have some other devices planned for upgrade later, including, among others, a hEX poe lite, RB4011 (with wireless), and a CRS226-24g-2s+rm
Tporlapt
Mon Apr 11, 2022 2:48 am
Simple Queues now don’t immediately break IPv6 (thank you!) however… enabling them causes the router to become slow-to-unresponsive in about 60 seconds (RB750GR3). Only quickly logging in via terminal (webfig is unresponsive) to disable the simple queue rescues it.
edit: Reading the other thread viewtopic.php?p=925637#p925637 and it may be Cake, rather than the Simple Queue. Currently using a Simple Queue with fqcodel and not yet seeing an issue.
ath
Mon Apr 11, 2022 10:04 am
I realize that MPLS L3VPNs in RouterOS 7 are still under development, but will it be possible to route VXLAN via a VRF using the mangle, e.g.
/ip firewall mangle
chain=output action=mark-routing new-routing-mark=VXLAN src-address=1.1.1.1 dst-address=2.2.2.2
where VXLAN is the name of the VRF and 1.1.1.1 is the loopback address of the router?
I get the response 22 (Invalid argument) when I try to ping 2.2.2.2 in RouterOS 7.2.
Alternatively, would it be possible to use /routing rule?
Cees2439867
Mon Apr 11, 2022 10:21 am
Just upgraded on my RB750GR3 and winbox does not open on Windows 10. Lucky the web interface still works fine.
holvoetn
Mon Apr 11, 2022 10:23 am
Upgrade winbox to 3.35.
Note
Mon Apr 11, 2022 10:24 am
Terminal is not working for me. Cannot copy paste anything, but i can write normally. On paste try, only characters are showing.......
pe1chl
Mon Apr 11, 2022 10:54 am
Did you read the manual?
How are you pasting? With Ctrl-V? THAT DOES NOT WORK!
You need to paste with Right-mouse-button and then Paste from the menu.
I think there is a keyboard shortcut for it but it is NOT Ctrl-V, the industry standard. That used to be "toggle Hotlock mode" which is now F7.
It is all ridiculous, I know...
emils
Forum Veteran
Forum Veteran
Mon Apr 11, 2022 11:24 am
What are you talking about? CTRL+C and CTRL+V works in WinBox terminal. SSH/Telnet depends on the actual terminal software you are using.
rextended
Mon Apr 11, 2022 11:29 am
This topic is a mess, 90% is out of OP...
Znevna
Mon Apr 11, 2022 11:31 am
90.1% now.
Wait, 90.2%
msatter
Mon Apr 11, 2022 11:36 am
It works but the sequencing is killing. It does not recognize in what status the terminal is.
Paste code and pause, seeing errors. Correct code in external editor and copy. In Terminal press CTRL-c (break), then the clip-board with just copied corrected code is empty.
rextended
Mon Apr 11, 2022 11:45 am
For problems about WinBox, please use the right topic:
If nothing is selected, why CTRL+C clean the clipboard?...
CTRL+C used for stop the script or instruction...
viewtopic.php?p=925701#p925701
pe1chl
Mon Apr 11, 2022 11:48 am
Oh it has been changed again? I rarely use it because it is so confusing. I'm sure it did not work before.
At least it is fortunate that it does not "toggle Hotlock" anymore. That whole feature should be removed, it is not useful at all.
(for this to be useful it would have to "eat" any matching characters after it has expanded a word, e.g. when typing "ping" in Hotlock mode it should expand pi to ping but then when you type an n it should not make that "ping n" but it should just ignore the n)
mrz
Mon Apr 11, 2022 11:52 am
Here you can find the list of terminal keys
https://help.mikrotik.com/docs/display/ ... ListofKeys
rextended
Mon Apr 11, 2022 11:53 am
Missing: (RouterOS 7.2.1 and WinBox 3.35 64 bit)
Control-C without selection: keyboard interrupt and also EMPTY THE CLIPBOARD
Control-C with something inside terminal selected: copy that on clipboard
Control-V paste the clipboard inside the terminal (if compatible contents)
raimondsp
Mon Apr 11, 2022 11:55 am
As an alternative, you can use CTRL+INS / SHIFT+INS for copy/pasting in Winbox terminal.
normis
Mon Apr 11, 2022 11:56 am
or mouse right click :)
rextended
Mon Apr 11, 2022 11:57 am
But the problem still persist: Control-C without selection EMPTY THE CLIPBOARD
raimondsp
Mon Apr 11, 2022 12:00 pm
In a terminal, CTRL+C is the interrupt command and should not be used as a copy (despite it is working in some cases).
rextended
i do all with mouse, both select & copy and paste, but if I interrupt the script or empty the current line with CTRL+C, I lost the script inside the clipboard, and I must go to copy again the script...
for be clear: I do not want use CTRL+ something for do copy & paste, I hope only than "copy" is removed from CTRL+C operation....
I use CTRL+C only for stop script or clear input line
pe1chl
Mon Apr 11, 2022 12:28 pm
There is a difference between "what keys does the commandline interface interpret" and "what keys can be used in terminal".
That is already obvious because the keys being discussed here are (rightfully) not in that document.
Furthermore, can I suggest that all support for "Hotlock mode" be removed from any new release of RouterOS made from today?
Poll: has anyone here ever made useful use of "Hotlock mode" (the commandline feature where it automatically expands words as soon as they are unique within the current context)?
Has anyone used Hotlock mode except when enabling it by mistake, and questioning whether the router has gone insane when pasting text?
Does anyone think this feature has to be retained in the state it is now?
allan2358
Mon Apr 11, 2022 1:47 pm
viewtopic.php?t=182059
please fix this issue!
Cha0s
Mon Apr 11, 2022 1:49 pm
I've never used it (except by mistakenly hitting ctrl+v in terminal), nor I've ever needed it.
It is indeed confusing. I don't know how it behaves nowadays since I've learned to use shift+ins for pasting into terminal (any terminal - not just ROS).
If "hotlock mode" was removed, I wouldn't miss it.
netmouse
Mon Apr 11, 2022 1:52 pm
For terminal use
Ctrl + Insert - copy
Shift + Insert - paste
dave3
90.1% now.
Wait, 90.2%
Yes, a 10 megabyte file downloading at dial-up speed. Same for me. I can envision a 30 year old PC hooked up to a US Robotics 28.8k modem sitting in the corner of an office serving firmware update files. :)
rextended
Mon Apr 11, 2022 2:00 pm
For terminal use
already wroted, nothing new,
the point is ctrl+c used for break script, ALSO delete clipboard.
mrz
Mon Apr 11, 2022 2:12 pm
@pe1chl I understand that reading is overrated, but please look once more at the manual I provided above. hot lock mode is enabled by F7 for quite some time now (not by ctrl+v).
mafiosa
Mon Apr 11, 2022 3:55 pm
@mrz @normis next release please fix vxlan mac changing after every reboot.
pe1chl
Mon Apr 11, 2022 4:02 pm
I know that has changed, but that does not mean hotlock mode is now suddenly useful, doesn't it?
Why is it not simply REMOVED? Or fixed so that it becomes useful?
The "my router is suddenly haunted" reports keep coming in, apparently people hit random keys and still are able to enter hotlock mode.
mrz
Mon Apr 11, 2022 4:08 pm
can you elaborate further on what should be fixed for hot lock mode? AFAIK it is not broken, and it is not causing any trouble to anyone especially now when ctrl+v no longer enables this mode.
rextended
Mon Apr 11, 2022 4:11 pm
sorry if I insist, ctrl-v no longer cause problems, but add "copy to clipboard, also if nothing is selected" to ctrl-c,
a command used for interrupt something or start a "fresh" line on terminal, is ungraceful....
pe1chl
Mon Apr 11, 2022 4:23 pm
IMHO what is broken is that when it has expanded a certain word (e.g. you type pi and it expands it to ping) it also adds a space and the next input you type is added as new input.
In a properly working hotlock mode, it would only expand the pi to ping but it would not add the space, and when the user now types n and g it would just "eat" that (knowing it has expanded pi to ping) and wait for the user to type a space to indicate they want to move on to the next word.
As it is now, hotlock mode modifies input and causes e.g. pasted correct input to be made incorrect.
Do you know ANY user who can work in hotlock mode without constantly watching the screen to make sure it does not do anything unexpected? And who actually uses that, instead of using TAB to make predictable expansions when required?
pe1chl
Mon Apr 11, 2022 4:48 pm
As others have reported previously, GRE-IPSec tunnels are not working well in 7.x. I had no performance issues with them in 6.x, but they are extremely slow in 7.x.
Is that related to the above, i.e. to IPv6? Because for me GRE/IPsec tunnels that transport IPv4 over IPv4 work OK in v7.2.
colinardo
Mon Apr 11, 2022 5:03 pm
Hi.
in the current release there is a problem with dot1x (mac/dot1x) authentication and dynamic vlan assignment with usermanager as radius server. The same settings were successfully tested with RouterOS release 7.1.5(CHR_x86), but in the current release 7.2 (CHR_x86) the setup fails.
RouterOS sends multiple radius requests, always gets Access-Accept from usermanager, but it fails to unblock the port and assignment to the vlan as untagged port.
Demo Config used to reproduce the problem
# apr/11/2022 16:06:40 by RouterOS 7.2
# software id =
add ingress-filtering=no name=bridgeLocal protocol-mode=none vlan-filtering=yes
/interface vlan
add interface=bridgeLocal name=vlan200 vlan-id=200
add bridge=bridgeLocal frame-types=admit-only-untagged-and-priority-tagged interface=ether3
add name=pool_vlan200 ranges=10.200.0.10-10.200.0.254
add address-pool=pool_vlan200 interface=vlan200 lease-time=1h name=dhcp_vlan200
/user-manager user
add attributes=Tunnel-Private-Group-ID:200,Tunnel-Medium-Type:6,Tunnel-Type:13 name=00:0C:29:16:E1:B7
/interface bridge vlan
add bridge=bridgeLocal tagged=bridgeLocal vlan-ids=200
/interface dot1x server
add auth-types=mac-auth interface=ether3
add address=10.200.0.1/24 interface=vlan200 network=10.200.0.0
add address=10.200.0.0/24 dns-server=10.200.0.1 gateway=10.200.0.1 netmask=24
set allow-remote-requests=yes
/radius
add address=127.0.0.1 service=hotspot,ipsec,dot1x src-address=127.0.0.1
/radius incoming
set accept=yes
/system logging
add topics=manager
add topics=dot1x
/user-manager
set enabled=yes
/user-manager router
add address=127.0.0.1 name=local
Best Regards
osc86
Mon Apr 11, 2022 5:12 pm
he.net tunnels are working ok in 7.2. Make sure your endpoint address matches your current public address (tunnelbroker.net), it is not updated automatically. Always use the cli to add routes. Winbox route menu is still buggy af, don't know about webfig.
sirbryan
Mon Apr 11, 2022 5:39 pm
Doing anything with routes in Webfig has been broken in 7.x for a long time (which is really frustrating since I browse into RouterOS from my Macs or iPhone when Winbox (Mac) or a terminal (iPhone) are often not convenient or available). Until I started deploying 7-only devices, I had no need for Winbox.
As mentioned, CLI is best place to view them for now; I believe they work OK in Winbox.
pe1chl
Mon Apr 11, 2022 7:10 pm
Winbox is not an option for me as it's Mac and Linux only here.
winbox.exe is a portable executable that easily runs under wine on both Linux and Mac.
Just download it and type "wine winbox.exe".
normis
Mon Apr 11, 2022 8:49 pm
or wine64 winbox64.exe :)
Larsa
Mon Apr 11, 2022 9:04 pm
How to install Winbox on MacOS
1. Follow the Mikrotik install instructions: Run Winbox on macOS. You can install Wine64 using brew: "$ brew --cask install wine-stable"
2. Create a start icon using the "Script Editor" with the Apple-script code below and save it as type Application in /Applications/Winbox.
on run
	do shell script "/usr/local/bin/wine64 /Applications/Winbox.app/Contents/MacOS/winbox64.exe"
end run
3. Download and copy the 64 bit version of Winbox (winbox64.exe) to /Applications/Winbox.app/Contents/MacOS
4 Start "System Preferences -> Security & Privacy -> Privacy -> Developer Tools" and add /Applications/Winbox
wuffzack
Mon Apr 11, 2022 11:05 pm
This CRS354-48G-4S+2Q+ feels a little cold (-274 degrees Celsius).
Only a copper pigtail cable is present in one SFP+ port, which has no temperature to report.
It is a Mellanox MCP2104-X01AB cable.
/system/health> print
Columns: NAME, VALUE, TYPE
#  NAME                VALUE  TYPE
0  temperature         -274   C
1  cpu-temperature     61     C
2  sfp-temperature     -274   C
3  fan1-speed          5550   RPM
4  fan2-speed          5445   RPM
5  fan3-speed          5610   RPM
6  board-temperature1  44     C
7  board-temperature2  27     C
8  psu1-state          ok
9  psu2-state          ok
EDIT: I am not sure if this problem is Router OS 7.2 specific, but I just noticed it the first time after upgrading.
Rfulton
Mon Apr 11, 2022 11:38 pm
7.2 on CCR2004-1G-12S+2XS
PIM-SM still does not work.
I will be submitting an FBI tip.
ingdaka
Trainer
Trainer
Tue Apr 12, 2022 12:09 am
Just upgraded CCR2004-16G-2S+ / Overall OK
BGP Prefix Count still 0
*) bgp - added BGP advertisements display (requires output.keep-sent-attributes to be set); even that i set output.keep-sent-attributes=yes still no info on command
[username@identity] > routing/bgp/session/dump-saved-advertisements
numbers: 1
numbers: 0
There are 2 BGP Peers
I found this! When command is typed there is pcap file on disc that is saved. Downloaded on computer and read with a pcap reader (wireshark in my case)
Tporlapt
Tue Apr 12, 2022 7:22 am
Just to update, Simple Queues with IPv6 and fq-codel are working fine for the past 24 hours. This is most welcome news.
Note
Tue Apr 12, 2022 9:43 am
On paste i get this now........
if u cant paste, writing from begin is time painful
haedertowfeq
Tue Apr 12, 2022 12:05 pm
@Note
Can you share your mangle
Or at least ,Qos DSCP
I have 2WAN in loadbalance
jadehart
Tue Apr 12, 2022 9:57 pm
I lost Winbox connectivity after I upgraded my CCR2216. I am using Winbox for MAC 3.30. I could see the router in my neighbors list, and could connect to it. When I tried to login with the default login username and password, the Winbox session simply disappeared. I upgrade a router before I even create a username and password.
mkx
Tue Apr 12, 2022 10:22 pm
Winbox 3.35 should be fine.
ath
L3VPN Filters Don't Work
Wed Apr 13, 2022 4:55 am
Applying an export filter to a VRF results in no routes being distributed.
/routing filter rule
	chain=DISTRIBUTE rule="accept"
/routing bgp vpn
	export-filter=DISTRIBUTE
tigro11
Wed Apr 13, 2022 9:47 am
Original notes:
BIG problem!!
maybe before a stable release first to churn out, which is tested well, thankful that I stopped with the updates of the other devices
thuety
Wed Apr 13, 2022 10:01 am
Have had 3 random reboots after updating my RB2011UiAS-2HnD from 7.1.5 to 7.2.
I've never had this problem before, so I went back to 7.1.5 for now.
Note
Wed Apr 13, 2022 10:18 am
@Note
You can get it from here..........
viewtopic.php?t=157048
Theo9216
Wed Apr 13, 2022 2:01 pm
After upgrade from 6.49.5 to 7.2 RoMon stopped seeing almost all devices in our network. If needed I can post the config here?
Works fine for me...
Try the export-netinstall-import route.
(do not forget show-sensitive with the export)
Problem fixed with secret disabled.
emils
Forum Veteran
Forum Veteran
Wed Apr 13, 2022 2:09 pm
New version v7.2.1 has been released:
viewtopic.php?t=184992
Users browsing this forum: Benzebub and 32 guests
