maaathieu
bgp filter problem
Wed Apr 06, 2022 1:24 pm
Hi
Since ros v7.1, I have a problem with a bgp filter concerning the bogon list that I receive from team cymru.
My filter looks like this:
 1   chain=cymru-in rule="if ( bgp-communities includes 65332:888 ) { set blackhole yes; accept;} else { reject;}"
but the routes are not blackholed, for example:
 Fb   afi=ip4 contribution=filtered dst-address=23.135.225.0/24 routing-table=main gateway=38.229.6.20 immediate-gw=1.2.3.4%ether5_832 distance=20 scope=40
       target-scope=30 belongs-to="BGP IP routes from 38.229.6.20"
       bgp.peer-cache-id=*B000004 .as-path="65332" .communities=65332:888,no-export .atomic-aggregate=no .origin=igp
       debug.fwp-ptr=0x20282360
If I append a ramdom community before this rule, like this:
 0   chain=cymru-in rule="append bgp-communities 1:1"
then it works:
 Ab B afi=ip4 contribution=active dst-address=23.135.225.0/24 routing-table=main immediate-gw="" distance=20 scope=40 target-scope=30
       bgp.peer-cache-id=*B000004 .as-path="65332" .communities=1:1,no-export,65332:888 .atomic-aggregate=no .origin=igp
       debug.fwp-ptr=0x202823C0
Am I doing something wrong, or is this a bug ?
Thanks,
Mat
bigd35
Re: bgp filter problem
Sun May 28, 2023 2:23 pm
Hi
I see the same on my part. The route filters are not getting blackholed. Will hear what Mikrotik Support says
Users browsing this forum: No registered users and 56 guests
