spaxton
V7.2 OpenVPN
Thu Apr 07, 2022 6:45 pm
Hello Friends,
We finally have dude server in V7 but it seems there are other problems. After upgrading to V7.2 from 6.49.5, OpenVPN clients from other mikrotik routers (some of them still 6.49.5 and some 7.2)and windows machines keeps disconnecting right after it connects. I tried many things to change in the server settings but without results.
Does anyone know why this happens?
Best Regards.
spaxton
Re: V7.2 OpenVPN
Fri Apr 08, 2022 12:26 am
Whatever I do in V7.2 for OpenVPN, I can't make it work. I am using the same ways for server setup and self signed certificates on mikrotik which I used for years. Does anyone have an example of working setup?
Best Regards.
Znevna
Re: V7.2 OpenVPN
Fri Apr 08, 2022 11:02 am
[...]which I used for years.
My best guess is because you're using OpenVPN on RouterOS.
Try switching to something else more stable and better implemented, you had years to think about something better.
spaxton
Re: V7.2 OpenVPN
Fri Apr 08, 2022 8:24 pm
1. All that "better openvpn solutions" first made a headache for us
2. I disagree about Your guess because it worked excellent without a single drop for years on more than 150 locations
3. With all due respect, Your reply wasn't helpful.
Best Regards.
Anyone has some valid clue about how to resolve this?
Znevna
Re: V7.2 OpenVPN
Fri Apr 08, 2022 8:26 pm
Switch back to the last version that worked and stick to it.
spaxton
Re: V7.2 OpenVPN
Fri Apr 08, 2022 8:39 pm
If possible, I would do that right away but I have no idea if it is going to work. The devices are all on a remote locations and if i brick them then I will have even bigger problems. ;( Did You ever try to downgrade to latest V6 from any V7?
JohnTRIVOLTA
Re: V7.2 OpenVPN
Fri Apr 08, 2022 9:12 pm
I downgraded to v.7.1.5 and now my mmips and arm boards are working fine with OpenVPN udp !
spaxton
Re: V7.2 OpenVPN
Fri Apr 08, 2022 9:19 pm
Unfortunately, these two routers I upgraded are with dude server and dude is not available in V7.1.5. I have to go back to 6.49.5. Possible?
JohnTRIVOLTA
Re: V7.2 OpenVPN
Fri Apr 08, 2022 9:24 pm
I don't know, there is always the possibility of something going wrong.
anav
Re: V7.2 OpenVPN
Fri Apr 08, 2022 9:25 pm
Not a problem stick with 7.2 and use wireguard vice openvpn to establish tunnels.
Very smooth, if you do your homework!!
viewtopic.php?t=182340
spaxton
Re: V7.2 OpenVPN
Fri Apr 08, 2022 10:32 pm
Thanks for suggestion. Do You mean to replace ovpn with wireguard?
MircoADM
Re: V7.2 OpenVPN
Sat Apr 16, 2022 11:43 am
sorry i have no idea why your OpenVPN not work in the newer ROS.
We have a some(about 500) of (IoT) connections to few "serverrouter" and they work fine with 7.2.
Most client(IoT) devices are on "long term 6.48"
Since few weeks we have some wireguard(testing) connections with newer ROS devices.
Here an client config that will work with ROS 7.2(1).... on a arm-device (RB4011)
The serverrouter are RB1100 Hx4
/interface ovpn-client
add certificate="Admin Router01" cipher=aes256 connect-to=x.x.x.x \
    mac-address=02:2F:C1:8F:4F:EB name="Router01 OVPN" password=\
    xxx port=443 use-peer-dns=no user=xxx \
    verify-server-certificate=yes
add certificate="Admin Router01" cipher=aes256 connect-to=y.y.y.y \
    mac-address=02:67:20:B7:8B:1B name="Router02 OVPN" password=\
    yyy port=500 use-peer-dns=no user=yyy \
add certificate="VPN User RU01" cipher=aes256 connect-to=\
    z.z.z.z mac-address=02:79:C7:D3:8A:1A name=BackupVPN \
    password=zzz port=443 use-peer-dns=no user=zzz \
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=x.x.x.x endpoint-port=\
    64740 interface=wireguard1 preshared-key=\
    "secret key psk" public-key=\
    "secret key public"
kioan
Re: V7.2 OpenVPN
Sun Apr 17, 2022 10:05 am
After upgrading to V7.2 ... windows machines keeps disconnecting right after it connects. I tried many things to change in the server settings but without results.
I am experiencing exactly the same problems after the 7.2 upgrade. My OVPN clients that keep disconnecting are Linux and Android.
I had no luck with all the changes I tried and finally downgraded to make it work again.
kunago
Re: V7.2 OpenVPN
Tue Apr 19, 2022 6:45 pm
It happens to be as well but not with all routers. To be precise, the issue occurs only on a "mmips" device. Maybe there is some issue with thich architecture? I tried to take a look at debug logs on both sides but there is nothing useful to make use of. Certificate is okay, login credentials as well.
I alo tried basically everything - regenrating all certificates, re-importing them, deleting the whole configuration and startin over but have not succeeded. All the advices in here make sense, but in my case as well - I prefer to use OpenVPN as a backup service.
server side debug log
Apr/19/2022 17:55:16 ovpn,info connection established from XXX.XXX.XXX.XXX, port: 49034
Apr/19/2022 17:55:16 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=8ab7f6297e28688b pid=0 DATA len=0
Apr/19/2022 17:55:16 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=72dc52f2da185b3d pid=0 DATA len=0
Apr/19/2022 17:55:16 ovpn,debug,packet sent P_ACK kid=0 sid=8ab7f6297e28688b [0 sid=72dc52f2da185b3d] DATA len=0
Apr/19/2022 17:55:16 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=72dc52f2da185b3d pid=1 DATA len=132
Apr/19/2022 17:55:16 ovpn,debug,packet sent P_ACK kid=0 sid=8ab7f6297e28688b [1 sid=72dc52f2da185b3d] DATA len=0
Apr/19/2022 17:55:16 ovpn,debug,packet rcvd P_ACK kid=0 sid=72dc52f2da185b3d [0 sid=8ab7f6297e28688b] DATA len=0
Apr/19/2022 17:55:16 ovpn,debug,packet sent P_CONTROL kid=0 sid=8ab7f6297e28688b pid=1 DATA len=1400
Apr/19/2022 17:55:16 ovpn,debug,packet sent P_CONTROL kid=0 sid=8ab7f6297e28688b pid=2 DATA len=1366
Apr/19/2022 17:55:16 ovpn,debug,packet rcvd P_ACK kid=0 sid=72dc52f2da185b3d [1 sid=8ab7f6297e28688b] DATA len=0
Apr/19/2022 17:55:16 ovpn,debug,packet rcvd P_ACK kid=0 sid=72dc52f2da185b3d [2 sid=8ab7f6297e28688b] DATA len=0
Apr/19/2022 17:55:16 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=72dc52f2da185b3d pid=2 DATA len=126
Apr/19/2022 17:55:16 ovpn,debug,packet sent P_ACK kid=0 sid=8ab7f6297e28688b [2 sid=72dc52f2da185b3d] DATA len=0
Apr/19/2022 17:55:16 ovpn,debug,packet sent P_CONTROL kid=0 sid=8ab7f6297e28688b pid=3 DATA len=51
Apr/19/2022 17:55:16 ovpn,debug,packet rcvd P_ACK kid=0 sid=72dc52f2da185b3d [3 sid=8ab7f6297e28688b] DATA len=0
Apr/19/2022 17:55:16 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=72dc52f2da185b3d pid=3 DATA len=316
Apr/19/2022 17:55:16 ovpn,debug,packet sent P_ACK kid=0 sid=8ab7f6297e28688b [3 sid=72dc52f2da185b3d] DATA len=0
Apr/19/2022 17:55:16 ovpn,info : using encoding - AES-256-CBC/SHA1
Apr/19/2022 17:55:16 ovpn,info,account OVPN-CLIENT logged in, 172.27.241.27 from XXX.XXX.XXX.XXX
Apr/19/2022 17:55:16 ovpn,debug,packet sent P_CONTROL kid=0 sid=8ab7f6297e28688b pid=4 DATA len=227
Apr/19/2022 17:55:16 ovpn,debug,packet rcvd P_ACK kid=0 sid=72dc52f2da185b3d [4 sid=8ab7f6297e28688b] DATA len=0
Apr/19/2022 17:55:16 ovpn,info OVPN-CLIENT: connected
Apr/19/2022 17:55:16 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=72dc52f2da185b3d pid=4 DATA len=42
Apr/19/2022 17:55:16 ovpn,debug,packet sent P_ACK kid=0 sid=8ab7f6297e28688b [4 sid=72dc52f2da185b3d] DATA len=0
Apr/19/2022 17:55:16 ovpn,debug,packet sent P_CONTROL kid=0 sid=8ab7f6297e28688b pid=5 DATA len=145
Apr/19/2022 17:55:16 ovpn,debug,packet rcvd P_ACK kid=0 sid=72dc52f2da185b3d [5 sid=8ab7f6297e28688b] DATA len=0
Apr/19/2022 17:55:17 ovpn,debug <XXX.XXX.XXX.XXX>: disconnected <peer disconnected>
Apr/19/2022 17:55:17 ovpn,info OVPN-CLIENT: terminating... - peer disconnected
Apr/19/2022 17:55:17 ovpn,info connection established from XXX.XXX.XXX.XXX, port: 49036
Apr/19/2022 17:55:17 ovpn,info,account OVPN-CLIENT logged out, 1 0 0 0 0 from XXX.XXX.XXX.XXX
Apr/19/2022 17:55:17 ovpn,info OVPN-CLIENT: disconnected
Apr/19/2022 17:55:17 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=62c3b6cbfa34475 pid=0 DATA len=0
Apr/19/2022 17:55:17 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=a3fad434c1548f6 pid=0 DATA len=0
Apr/19/2022 17:55:17 ovpn,debug,packet sent P_ACK kid=0 sid=62c3b6cbfa34475 [0 sid=a3fad434c1548f6] DATA len=0
Apr/19/2022 17:55:17 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=a3fad434c1548f6 pid=1 DATA len=132
Apr/19/2022 17:55:17 ovpn,debug,packet sent P_ACK kid=0 sid=62c3b6cbfa34475 [1 sid=a3fad434c1548f6] DATA len=0
Apr/19/2022 17:55:17 ovpn,debug,packet rcvd P_ACK kid=0 sid=a3fad434c1548f6 [0 sid=62c3b6cbfa34475] DATA len=0
Apr/19/2022 17:55:17 ovpn,debug,packet sent P_CONTROL kid=0 sid=62c3b6cbfa34475 pid=1 DATA len=1400
Apr/19/2022 17:55:17 ovpn,debug,packet sent P_CONTROL kid=0 sid=62c3b6cbfa34475 pid=2 DATA len=1366
Apr/19/2022 17:55:17 ovpn,debug,packet rcvd P_ACK kid=0 sid=a3fad434c1548f6 [1 sid=62c3b6cbfa34475] DATA len=0
Apr/19/2022 17:55:17 ovpn,debug,packet rcvd P_ACK kid=0 sid=a3fad434c1548f6 [2 sid=62c3b6cbfa34475] DATA len=0
Apr/19/2022 17:55:17 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=a3fad434c1548f6 pid=2 DATA len=126
Apr/19/2022 17:55:17 ovpn,debug,packet sent P_ACK kid=0 sid=62c3b6cbfa34475 [2 sid=a3fad434c1548f6] DATA len=0
Apr/19/2022 17:55:17 ovpn,debug,packet sent P_CONTROL kid=0 sid=62c3b6cbfa34475 pid=3 DATA len=51
Apr/19/2022 17:55:17 ovpn,debug,packet rcvd P_ACK kid=0 sid=a3fad434c1548f6 [3 sid=62c3b6cbfa34475] DATA len=0
Apr/19/2022 17:55:17 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=a3fad434c1548f6 pid=3 DATA len=316
Apr/19/2022 17:55:17 ovpn,debug,packet sent P_ACK kid=0 sid=62c3b6cbfa34475 [3 sid=a3fad434c1548f6] DATA len=0
Apr/19/2022 17:55:17 ovpn,info : using encoding - AES-256-CBC/SHA1
Apr/19/2022 17:55:17 ovpn,info,account OVPN-CLIENT logged in, 172.27.241.27 from XXX.XXX.XXX.XXX
Apr/19/2022 17:55:17 ovpn,debug,packet sent P_CONTROL kid=0 sid=62c3b6cbfa34475 pid=4 DATA len=227
Apr/19/2022 17:55:17 ovpn,debug,packet rcvd P_ACK kid=0 sid=a3fad434c1548f6 [4 sid=62c3b6cbfa34475] DATA len=0
Apr/19/2022 17:55:17 ovpn,info OVPN-CLIENT: connected
Apr/19/2022 17:55:17 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=a3fad434c1548f6 pid=4 DATA len=42
Apr/19/2022 17:55:17 ovpn,debug,packet sent P_ACK kid=0 sid=62c3b6cbfa34475 [4 sid=a3fad434c1548f6] DATA len=0
Apr/19/2022 17:55:17 ovpn,debug,packet sent P_CONTROL kid=0 sid=62c3b6cbfa34475 pid=5 DATA len=145
Apr/19/2022 17:55:17 ovpn,debug,packet rcvd P_ACK kid=0 sid=a3fad434c1548f6 [5 sid=62c3b6cbfa34475] DATA len=0
Apr/19/2022 17:55:18 ovpn,debug <XXX.XXX.XXX.XXX>: disconnected <peer disconnected>
Apr/19/2022 17:55:18 ovpn,info OVPN-CLIENT: terminating... - peer disconnected
Apr/19/2022 17:55:18 ovpn,info,account OVPN-CLIENT logged out, 1 0 0 0 0 from XXX.XXX.XXX.XXX
Apr/19/2022 17:55:18 ovpn,info OVPN-CLIENT: disconnected
Apr/19/2022 17:55:18 ovpn,info connection established from XXX.XXX.XXX.XXX, port: 49038
Apr/19/2022 17:55:18 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=b7665d814564ec pid=0 DATA len=0
Apr/19/2022 17:55:18 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=4a49d53ab58f2167 pid=0 DATA len=0
Apr/19/2022 17:55:18 ovpn,debug,packet sent P_ACK kid=0 sid=b7665d814564ec [0 sid=4a49d53ab58f2167] DATA len=0
Apr/19/2022 17:55:18 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=4a49d53ab58f2167 pid=1 DATA len=132
Apr/19/2022 17:55:18 ovpn,debug,packet sent P_ACK kid=0 sid=b7665d814564ec [1 sid=4a49d53ab58f2167] DATA len=0
Apr/19/2022 17:55:18 ovpn,debug,packet rcvd P_ACK kid=0 sid=4a49d53ab58f2167 [0 sid=b7665d814564ec] DATA len=0
Apr/19/2022 17:55:18 ovpn,debug,packet sent P_CONTROL kid=0 sid=b7665d814564ec pid=1 DATA len=1400
Apr/19/2022 17:55:18 ovpn,debug,packet sent P_CONTROL kid=0 sid=b7665d814564ec pid=2 DATA len=1366
Apr/19/2022 17:55:18 ovpn,debug,packet rcvd P_ACK kid=0 sid=4a49d53ab58f2167 [1 sid=b7665d814564ec] DATA len=0
Apr/19/2022 17:55:18 ovpn,debug,packet rcvd P_ACK kid=0 sid=4a49d53ab58f2167 [2 sid=b7665d814564ec] DATA len=0
Apr/19/2022 17:55:18 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=4a49d53ab58f2167 pid=2 DATA len=126
Apr/19/2022 17:55:18 ovpn,debug,packet sent P_ACK kid=0 sid=b7665d814564ec [2 sid=4a49d53ab58f2167] DATA len=0
Apr/19/2022 17:55:18 ovpn,debug,packet sent P_CONTROL kid=0 sid=b7665d814564ec pid=3 DATA len=51
Apr/19/2022 17:55:19 ovpn,debug,packet rcvd P_ACK kid=0 sid=4a49d53ab58f2167 [3 sid=b7665d814564ec] DATA len=0
Apr/19/2022 17:55:19 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=4a49d53ab58f2167 pid=3 DATA len=316
Apr/19/2022 17:55:19 ovpn,debug,packet sent P_ACK kid=0 sid=b7665d814564ec [3 sid=4a49d53ab58f2167] DATA len=0
Apr/19/2022 17:55:19 ovpn,info : using encoding - AES-256-CBC/SHA1
Apr/19/2022 17:55:19 ovpn,info,account OVPN-CLIENT logged in, 172.27.241.27 from XXX.XXX.XXX.XXX
Apr/19/2022 17:55:19 ovpn,debug,packet sent P_CONTROL kid=0 sid=b7665d814564ec pid=4 DATA len=227
Apr/19/2022 17:55:19 ovpn,debug,packet rcvd P_ACK kid=0 sid=4a49d53ab58f2167 [4 sid=b7665d814564ec] DATA len=0
Apr/19/2022 17:55:19 ovpn,info OVPN-CLIENT: connected
Apr/19/2022 17:55:19 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=4a49d53ab58f2167 pid=4 DATA len=42
Apr/19/2022 17:55:19 ovpn,debug,packet sent P_ACK kid=0 sid=b7665d814564ec [4 sid=4a49d53ab58f2167] DATA len=0
Apr/19/2022 17:55:19 ovpn,debug,packet sent P_CONTROL kid=0 sid=b7665d814564ec pid=5 DATA len=145
Apr/19/2022 17:55:19 ovpn,debug,packet rcvd P_ACK kid=0 sid=4a49d53ab58f2167 [5 sid=b7665d814564ec] DATA len=0
Apr/19/2022 17:55:19 ovpn,debug <XXX.XXX.XXX.XXX>: disconnected <peer disconnected>
Apr/19/2022 17:55:19 ovpn,info OVPN-CLIENT: terminating... - peer disconnected
Apr/19/2022 17:55:19 ovpn,info,account OVPN-CLIENT logged out, 1 0 0 0 0 from XXX.XXX.XXX.XXX
Apr/19/2022 17:55:19 ovpn,info OVPN-CLIENT: disconnected
client side debug log
Apr/19/2022 17:59:04 ovpn,info OVPN-CLIENT: initializing...
Apr/19/2022 17:59:04 ovpn,info OVPN-CLIENT: connecting...
Apr/19/2022 17:59:04 ovpn,debug,packet sent P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=d8fb87dce0bdfe93 pid=0 DATA len=0
Apr/19/2022 17:59:04 ovpn,debug,packet sent P_CONTROL kid=0 sid=d8fb87dce0bdfe93 pid=1 DATA len=132
Apr/19/2022 17:59:04 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=bda1fb1f7c5ecbb pid=0 DATA len=0
Apr/19/2022 17:59:04 ovpn,debug,packet sent P_ACK kid=0 sid=d8fb87dce0bdfe93 [0 sid=bda1fb1f7c5ecbb] DATA len=0
Apr/19/2022 17:59:04 ovpn,debug,packet rcvd P_ACK kid=0 sid=bda1fb1f7c5ecbb [0 sid=d8fb87dce0bdfe93] DATA len=0
Apr/19/2022 17:59:04 ovpn,debug,packet rcvd P_ACK kid=0 sid=bda1fb1f7c5ecbb [1 sid=d8fb87dce0bdfe93] DATA len=0
Apr/19/2022 17:59:04 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=bda1fb1f7c5ecbb pid=1 DATA len=1400
Apr/19/2022 17:59:04 ovpn,debug,packet sent P_ACK kid=0 sid=d8fb87dce0bdfe93 [1 sid=bda1fb1f7c5ecbb] DATA len=0
Apr/19/2022 17:59:04 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=bda1fb1f7c5ecbb pid=2 DATA len=1366
Apr/19/2022 17:59:04 ovpn,debug,packet sent P_ACK kid=0 sid=d8fb87dce0bdfe93 [2 sid=bda1fb1f7c5ecbb] DATA len=0
Apr/19/2022 17:59:05 ovpn,debug,packet sent P_CONTROL kid=0 sid=d8fb87dce0bdfe93 pid=2 DATA len=126
Apr/19/2022 17:59:05 ovpn,debug,packet rcvd P_ACK kid=0 sid=bda1fb1f7c5ecbb [2 sid=d8fb87dce0bdfe93] DATA len=0
Apr/19/2022 17:59:05 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=bda1fb1f7c5ecbb pid=3 DATA len=51
Apr/19/2022 17:59:05 ovpn,debug,packet sent P_ACK kid=0 sid=d8fb87dce0bdfe93 [3 sid=bda1fb1f7c5ecbb] DATA len=0
Apr/19/2022 17:59:05 ovpn,debug,packet sent P_CONTROL kid=0 sid=d8fb87dce0bdfe93 pid=3 DATA len=316
Apr/19/2022 17:59:05 ovpn,debug,packet rcvd P_ACK kid=0 sid=bda1fb1f7c5ecbb [3 sid=d8fb87dce0bdfe93] DATA len=0
Apr/19/2022 17:59:05 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=bda1fb1f7c5ecbb pid=4 DATA len=227
Apr/19/2022 17:59:05 ovpn,debug,packet sent P_ACK kid=0 sid=d8fb87dce0bdfe93 [4 sid=bda1fb1f7c5ecbb] DATA len=0
Apr/19/2022 17:59:05 ovpn,info OVPN-CLIENT: using encoding - AES-256-CBC/SHA1
Apr/19/2022 17:59:05 ovpn,debug,packet sent P_CONTROL kid=0 sid=d8fb87dce0bdfe93 pid=4 DATA len=42
Apr/19/2022 17:59:05 ovpn,debug,packet rcvd P_ACK kid=0 sid=bda1fb1f7c5ecbb [4 sid=d8fb87dce0bdfe93] DATA len=0
Apr/19/2022 17:59:05 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=bda1fb1f7c5ecbb pid=5 DATA len=145
Apr/19/2022 17:59:05 ovpn,debug,packet sent P_ACK kid=0 sid=d8fb87dce0bdfe93 [5 sid=bda1fb1f7c5ecbb] DATA len=0
Apr/19/2022 17:59:05 ovpn,info OVPN-CLIENT: connected
Apr/19/2022 17:59:05 ovpn,debug OVPN-CLIENT: disconnected <peer disconnected>
Apr/19/2022 17:59:05 ovpn,info OVPN-CLIENT: terminating... - peer disconnected
Apr/19/2022 17:59:05 ovpn,info OVPN-CLIENT: disconnected
Apr/19/2022 17:59:05 ovpn,info OVPN-CLIENT: initializing...
Apr/19/2022 17:59:05 ovpn,info OVPN-CLIENT: connecting...
Apr/19/2022 17:59:05 ovpn,debug,packet sent P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=3d1fac3a8fdbc63 pid=0 DATA len=0
Apr/19/2022 17:59:05 ovpn,debug,packet sent P_CONTROL kid=0 sid=3d1fac3a8fdbc63 pid=1 DATA len=132
Apr/19/2022 17:59:05 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=7b3287a21bd39341 pid=0 DATA len=0
Apr/19/2022 17:59:05 ovpn,debug,packet sent P_ACK kid=0 sid=3d1fac3a8fdbc63 [0 sid=7b3287a21bd39341] DATA len=0
Apr/19/2022 17:59:05 ovpn,debug,packet rcvd P_ACK kid=0 sid=7b3287a21bd39341 [0 sid=3d1fac3a8fdbc63] DATA len=0
Apr/19/2022 17:59:05 ovpn,debug,packet rcvd P_ACK kid=0 sid=7b3287a21bd39341 [1 sid=3d1fac3a8fdbc63] DATA len=0
Apr/19/2022 17:59:05 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=7b3287a21bd39341 pid=1 DATA len=1400
Apr/19/2022 17:59:05 ovpn,debug,packet sent P_ACK kid=0 sid=3d1fac3a8fdbc63 [1 sid=7b3287a21bd39341] DATA len=0
Apr/19/2022 17:59:05 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=7b3287a21bd39341 pid=2 DATA len=1366
Apr/19/2022 17:59:05 ovpn,debug,packet sent P_ACK kid=0 sid=3d1fac3a8fdbc63 [2 sid=7b3287a21bd39341] DATA len=0
Apr/19/2022 17:59:06 ovpn,debug,packet sent P_CONTROL kid=0 sid=3d1fac3a8fdbc63 pid=2 DATA len=126
Apr/19/2022 17:59:06 ovpn,debug,packet rcvd P_ACK kid=0 sid=7b3287a21bd39341 [2 sid=3d1fac3a8fdbc63] DATA len=0
Apr/19/2022 17:59:06 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=7b3287a21bd39341 pid=3 DATA len=51
Apr/19/2022 17:59:06 ovpn,debug,packet sent P_ACK kid=0 sid=3d1fac3a8fdbc63 [3 sid=7b3287a21bd39341] DATA len=0
Apr/19/2022 17:59:06 ovpn,debug,packet sent P_CONTROL kid=0 sid=3d1fac3a8fdbc63 pid=3 DATA len=316
Apr/19/2022 17:59:06 ovpn,debug,packet rcvd P_ACK kid=0 sid=7b3287a21bd39341 [3 sid=3d1fac3a8fdbc63] DATA len=0
Apr/19/2022 17:59:06 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=7b3287a21bd39341 pid=4 DATA len=227
Apr/19/2022 17:59:06 ovpn,debug,packet sent P_ACK kid=0 sid=3d1fac3a8fdbc63 [4 sid=7b3287a21bd39341] DATA len=0
Apr/19/2022 17:59:06 ovpn,info OVPN-CLIENT: using encoding - AES-256-CBC/SHA1
Apr/19/2022 17:59:06 ovpn,debug,packet sent P_CONTROL kid=0 sid=3d1fac3a8fdbc63 pid=4 DATA len=42
Apr/19/2022 17:59:06 ovpn,debug,packet rcvd P_ACK kid=0 sid=7b3287a21bd39341 [4 sid=3d1fac3a8fdbc63] DATA len=0
Apr/19/2022 17:59:06 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=7b3287a21bd39341 pid=5 DATA len=145
Apr/19/2022 17:59:06 ovpn,debug,packet sent P_ACK kid=0 sid=3d1fac3a8fdbc63 [5 sid=7b3287a21bd39341] DATA len=0
Apr/19/2022 17:59:06 ovpn,info OVPN-CLIENT: connected
Apr/19/2022 17:59:06 ovpn,debug OVPN-CLIENT: disconnected <peer disconnected>
Apr/19/2022 17:59:06 ovpn,info OVPN-CLIENT: terminating... - peer disconnected
Apr/19/2022 17:59:06 ovpn,info OVPN-CLIENT: disconnected
Apr/19/2022 17:59:06 ovpn,info OVPN-CLIENT: initializing...
Apr/19/2022 17:59:06 ovpn,info OVPN-CLIENT: connecting...
Apr/19/2022 17:59:06 ovpn,debug,packet sent P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=e73f8e7b6e667 pid=0 DATA len=0
Apr/19/2022 17:59:06 ovpn,debug,packet sent P_CONTROL kid=0 sid=e73f8e7b6e667 pid=1 DATA len=132
Apr/19/2022 17:59:06 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=e2bda09762b84cfb pid=0 DATA len=0
Apr/19/2022 17:59:06 ovpn,debug,packet sent P_ACK kid=0 sid=e73f8e7b6e667 [0 sid=e2bda09762b84cfb] DATA len=0
Apr/19/2022 17:59:06 ovpn,debug,packet rcvd P_ACK kid=0 sid=e2bda09762b84cfb [0 sid=e73f8e7b6e667] DATA len=0
Apr/19/2022 17:59:06 ovpn,debug,packet rcvd P_ACK kid=0 sid=e2bda09762b84cfb [1 sid=e73f8e7b6e667] DATA len=0
Apr/19/2022 17:59:07 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=e2bda09762b84cfb pid=1 DATA len=1400
Apr/19/2022 17:59:07 ovpn,debug,packet sent P_ACK kid=0 sid=e73f8e7b6e667 [1 sid=e2bda09762b84cfb] DATA len=0
Apr/19/2022 17:59:07 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=e2bda09762b84cfb pid=2 DATA len=1366
Apr/19/2022 17:59:07 ovpn,debug,packet sent P_ACK kid=0 sid=e73f8e7b6e667 [2 sid=e2bda09762b84cfb] DATA len=0
Apr/19/2022 17:59:07 ovpn,debug,packet sent P_CONTROL kid=0 sid=e73f8e7b6e667 pid=2 DATA len=126
Apr/19/2022 17:59:07 ovpn,debug,packet rcvd P_ACK kid=0 sid=e2bda09762b84cfb [2 sid=e73f8e7b6e667] DATA len=0
Apr/19/2022 17:59:07 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=e2bda09762b84cfb pid=3 DATA len=51
Apr/19/2022 17:59:07 ovpn,debug,packet sent P_ACK kid=0 sid=e73f8e7b6e667 [3 sid=e2bda09762b84cfb] DATA len=0
Apr/19/2022 17:59:07 ovpn,debug,packet sent P_CONTROL kid=0 sid=e73f8e7b6e667 pid=3 DATA len=316
Apr/19/2022 17:59:07 ovpn,debug,packet rcvd P_ACK kid=0 sid=e2bda09762b84cfb [3 sid=e73f8e7b6e667] DATA len=0
Apr/19/2022 17:59:07 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=e2bda09762b84cfb pid=4 DATA len=227
Apr/19/2022 17:59:07 ovpn,debug,packet sent P_ACK kid=0 sid=e73f8e7b6e667 [4 sid=e2bda09762b84cfb] DATA len=0
Apr/19/2022 17:59:07 ovpn,info OVPN-CLIENT: using encoding - AES-256-CBC/SHA1
Apr/19/2022 17:59:07 ovpn,debug,packet sent P_CONTROL kid=0 sid=e73f8e7b6e667 pid=4 DATA len=42
Apr/19/2022 17:59:07 ovpn,debug,packet rcvd P_ACK kid=0 sid=e2bda09762b84cfb [4 sid=e73f8e7b6e667] DATA len=0
Apr/19/2022 17:59:07 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=e2bda09762b84cfb pid=5 DATA len=145
Apr/19/2022 17:59:07 ovpn,debug,packet sent P_ACK kid=0 sid=e73f8e7b6e667 [5 sid=e2bda09762b84cfb] DATA len=0
Apr/19/2022 17:59:07 ovpn,info OVPN-CLIENT: connected
Apr/19/2022 17:59:08 ovpn,debug OVPN-CLIENT: disconnected <peer disconnected>
Apr/19/2022 17:59:08 ovpn,info OVPN-CLIENT: terminating... - peer disconnected
Apr/19/2022 17:59:08 ovpn,info OVPN-CLIENT: disconnected
Apr/19/2022 17:59:08 ovpn,info OVPN-CLIENT: initializing...
Apr/19/2022 17:59:08 ovpn,info OVPN-CLIENT: connecting...
Apr/19/2022 17:59:08 ovpn,debug,packet sent P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=63499e5dc59c571e pid=0 DATA len=0
Apr/19/2022 17:59:08 ovpn,debug,packet sent P_CONTROL kid=0 sid=63499e5dc59c571e pid=1 DATA len=132
Apr/19/2022 17:59:08 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=2b958018aeaee55b pid=0 DATA len=0
Apr/19/2022 17:59:08 ovpn,debug,packet sent P_ACK kid=0 sid=63499e5dc59c571e [0 sid=2b958018aeaee55b] DATA len=0
Apr/19/2022 17:59:08 ovpn,debug,packet rcvd P_ACK kid=0 sid=2b958018aeaee55b [0 sid=63499e5dc59c571e] DATA len=0
Apr/19/2022 17:59:08 ovpn,debug,packet rcvd P_ACK kid=0 sid=2b958018aeaee55b [1 sid=63499e5dc59c571e] DATA len=0
Apr/19/2022 17:59:08 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=2b958018aeaee55b pid=1 DATA len=1400
Apr/19/2022 17:59:08 ovpn,debug,packet sent P_ACK kid=0 sid=63499e5dc59c571e [1 sid=2b958018aeaee55b] DATA len=0
Apr/19/2022 17:59:08 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=2b958018aeaee55b pid=2 DATA len=1366
Apr/19/2022 17:59:08 ovpn,debug,packet sent P_ACK kid=0 sid=63499e5dc59c571e [2 sid=2b958018aeaee55b] DATA len=0
Apr/19/2022 17:59:09 ovpn,debug,packet sent P_CONTROL kid=0 sid=63499e5dc59c571e pid=2 DATA len=126
Apr/19/2022 17:59:09 ovpn,debug,packet rcvd P_ACK kid=0 sid=2b958018aeaee55b [2 sid=63499e5dc59c571e] DATA len=0
Apr/19/2022 17:59:09 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=2b958018aeaee55b pid=3 DATA len=51
Apr/19/2022 17:59:09 ovpn,debug,packet sent P_ACK kid=0 sid=63499e5dc59c571e [3 sid=2b958018aeaee55b] DATA len=0
Apr/19/2022 17:59:09 ovpn,debug,packet sent P_CONTROL kid=0 sid=63499e5dc59c571e pid=3 DATA len=316
Apr/19/2022 17:59:09 ovpn,debug,packet rcvd P_ACK kid=0 sid=2b958018aeaee55b [3 sid=63499e5dc59c571e] DATA len=0
Apr/19/2022 17:59:09 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=2b958018aeaee55b pid=4 DATA len=227
Apr/19/2022 17:59:09 ovpn,debug,packet sent P_ACK kid=0 sid=63499e5dc59c571e [4 sid=2b958018aeaee55b] DATA len=0
Apr/19/2022 17:59:09 ovpn,info OVPN-CLIENT: using encoding - AES-256-CBC/SHA1
Apr/19/2022 17:59:09 ovpn,debug,packet sent P_CONTROL kid=0 sid=63499e5dc59c571e pid=4 DATA len=42
Apr/19/2022 17:59:09 ovpn,debug,packet rcvd P_ACK kid=0 sid=2b958018aeaee55b [4 sid=63499e5dc59c571e] DATA len=0
Apr/19/2022 17:59:09 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=2b958018aeaee55b pid=5 DATA len=145
Apr/19/2022 17:59:09 ovpn,debug,packet sent P_ACK kid=0 sid=63499e5dc59c571e [5 sid=2b958018aeaee55b] DATA len=0
Apr/19/2022 17:59:09 ovpn,info OVPN-CLIENT: connected
Apr/19/2022 17:59:09 ovpn,debug OVPN-CLIENT: disconnected <peer disconnected>
Apr/19/2022 17:59:09 ovpn,info OVPN-CLIENT: terminating... - peer disconnected
Apr/19/2022 17:59:09 ovpn,info OVPN-CLIENT: disconnected
I am using the latest FW (7.2.1). The device is "hEX S".
Can anyone advise me how to report the issue?
repcio
Re: V7.2 OpenVPN
Wed Apr 20, 2022 2:49 am
I have the same issue. After upgrade of RB1100AHx4 to ROS 7.2 (7.2.1) openvpn connection are not working. Client connects to a server and after a second server is reporting that client have dropped a connection :(
Client using ROS 7.1.3 was working properly with previous ROS (6.49.3) on server
MaxKrok72
Re: V7.2 OpenVPN
Wed Apr 20, 2022 7:16 pm
Dear Mikrotik developers! Why millions of users has to wait for months and you do not answer?
Why OpenVPN is broken on 7.2+ on MMIPS architecture? Please answer ASAP...
What for this forum if you do not answer?
BTW OpenVPN is broken for android connection on my MMIPS on 7.+ Again no answer for that...
nickrm
Re: V7.2 OpenVPN
Fri Apr 22, 2022 7:35 am
I've run into the same issue with OpenVPN client on hEX S after upgrading it to the version 7.2.1. I'd downgraded firmware to the version 7.1.5 _AS_A_TEMPORARY_WORKAROUND_ and OpenVPN client on hEX S started working again. Will be waiting for the permanent solution and feedback from Mikrotik Support Team. I hope they will fix the issue soon. BTW - do I need to raise a separate ticket to Mikrotik Support Portal (on Jira) or they are reading and commenting posts in this forum on a regular basis?
kunago
Re: V7.2 OpenVPN
Fri Apr 22, 2022 11:04 am
I would have created a support ticked if I had known how so please, if you know how, I believe creating it is the fastest way to fix it.
Reason: removed excessive quotting of preceding post; be wise, quote smart. lines of quote, 1 line of post.
tangent
Re: V7.2 OpenVPN
Fri Apr 22, 2022 3:52 pm
This page is linked from two separate places on the main MikroTik.com site pages, both offering “Support”.
nickrm
Re: V7.2 OpenVPN
Mon Apr 25, 2022 11:42 am
I'd raised a support ticket and have just got a response from the Support:
The issue is already fixed in the latest RouterOS v7.3beta:
*) ovpn - fixed packet processing on MT7621A;
.. and here is the latest clarification from the Support:
Yes, the fix will be available in the RouterOS v7.2.2, but the release time is unknown yet. RouterOS v7.3 stable build is quite far.
So we need to be patient..
kbehrens
Re: V7.2 OpenVPN
Tue May 31, 2022 8:23 am
I'm having the same issue on CHR (x86_64). With 7.1.5, everything is worklng fine with the OpenVPN TCP road warrior conections. With 7.2.1 or 7.2.3, no connection is established. It looks like a timeout.
Any chance this is related?
i8nhj
Re: V7.2 OpenVPN
Mon Dec 12, 2022 10:17 pm
I'm running 7.6 on powerpc (1100AH2x) and still have the issue with OVPN; there is no way to have it working.
Is this a powerpc-specific version-related issue? Has it been fixed for other platforms?
Thanks.
i8nhj
Re: V7.2 OpenVPN
Tue Dec 13, 2022 8:21 pm
I just updated to 7.7rc1 (powerpc).
I rebuilt the whole configuration from scratch, but still no luck. I see many people and posts talking about this kind of issue, but no one has a working suggestion.
Tue Dec 13 01:06:22 2022 ovpn-dco device [OpenVPN Data Channel Offload] opened
Tue Dec 13 01:06:22 2022 TCP_CLIENT link local: (not bound)
Tue Dec 13 01:06:22 2022 TCP_CLIENT link remote: [AF_INET] XX.YY.WW.ZZ:1194
Tue Dec 13 01:06:22 2022 MANAGEMENT: >STATE:1670893582,WAIT,,,,,,
Tue Dec 13 01:06:22 2022 MANAGEMENT: >STATE:1670893582,AUTH,,,,,,
Tue Dec 13 01:06:22 2022 TLS: Initial packet from [AF_INET] XX.YY.WW.ZZ:1194, sid=a9ec45d4 8cfcd533
Tue Dec 13 01:06:23 2022 VERIFY OK: depth=1, CN=myCa
Tue Dec 13 01:06:23 2022 VERIFY KU OK
Tue Dec 13 01:06:23 2022 NOTE: --mute triggered...
Tue Dec 13 01:06:23 2022 4 variation(s) on previous 10 message(s) suppressed by --mute
Tue Dec 13 01:06:23 2022 Connection reset, restarting [-1]
Tue Dec 13 01:06:23 2022 Closing DCO interface
Tue Dec 13 01:06:23 2022 SIGUSR1[soft,connection-reset] received, process restarting
Tue Dec 13 01:06:23 2022 MANAGEMENT: >STATE:1670893583,RECONNECTING,connection-reset,,,,,
Tue Dec 13 01:06:23 2022 Restart pause, 5 second(s)
martinf11
Re: V7.2 OpenVPN
Tue Feb 14, 2023 10:23 am
Did you solve the problem? I cannot get it running as well :(
Users browsing this forum: Bing [Bot], Google [Bot], GoogleOther [Bot], outtahere and 67 guests
