eldoncito2019
Can it be done with a script?
Thu Apr 07, 2022 9:33 pm
Greetings, friends, you can change the time of the format that the routerboard brings from 24 hours, to (AM-PM), according to the following example:
08:05:00 08:05:00 AM.
15:18:00 03:18:00 PM.
Thanks for your help.
EL DONCITO.
holvoetn
Re: Can it be done with a script?
Thu Apr 07, 2022 9:53 pm
Pseudo code:
If value(<first two digits) > 12
then
newvalue=value(<first two digits>) - 12
print new value and all the rest
print PM
else
print value as it was
print AM
endif
Start your engines ...
rextended
Thu Apr 07, 2022 10:07 pm
You, as usual, do not describe entirely the request.
Where that time must be read?
Where that time must be print?
The RouterOS can not be "nationalized".
Dummy date format and 24h clock.
rextended
Thu Apr 07, 2022 10:14 pm
Pseudo code:
then
print PM
else
print AM
endif
24 do not exist, everytime you have from 00 to 23
00 = 12 AM
01 = 01 AM
11 = 11 AM
12 = 12 PM
13 = 01 PM
14 = 02 PM
22 = 10 PM
23 = 11 PM
holvoetn
Thu Apr 07, 2022 10:22 pm
Ah yes, lookup table, that's also an option :D
rextended
Thu Apr 07, 2022 10:52 pm
This is the "easy" part...
example code
:for i from=0 to=23 step=1 do={
    :local hours  $i
    :local mhours [:tonum $hours]
    :local msymbl "AM"
    :if ($mhours > 11) do={:set msymbl "PM"}
    :set mhours ($mhours % 12)
    :if ($mhours = 0) do={:set mhours 12}
    :if ($mhours < 10) do={:set mhours "0$mhours"}
    :local mtime "$mhours $msymbl"
    :local test $i
    :if ($test < 10) do={:set test "0$test"}
    :put "$test = $mtime"
Just for start...
eldoncito2019
Thu Apr 07, 2022 10:53 pm
It is to register it in a script but with AM-PM time
EL DONCITO.
rextended
Re: Can it be done with a script?  [SOLVED]
Thu Apr 07, 2022 11:07 pm
international to meridian code
    :local itime  [/system clock get time]
    :local hours  [:pick $itime 0 2]
    :local minsec [:pick $itime 2 8]
    :local msymbl "AM"
    :local mtime "$mhours$minsec $msymbl"
    :put "$itime = $mtime"
22:07:27 = 10:07:27 PM
holvoetn
Thu Apr 07, 2022 11:54 pm
Why ? Whatever you do with it afterwards, it's in my view mostly better to use 24h format.
Always sorts nicely.
Always can be evaluated.
eldoncito2019
Fri Apr 08, 2022 4:13 pm
Thank you friend rextended.
EL DONCITO.
Users browsing this forum: handiansudianto, raiser and 70 guests
