This one seems to get lost in the announce channel, so I created this separate post.
Trying to upgrade my test RB1100 to 7.2 ...
routeros-powerpc-7.2.npk missing in the upgrade channel ...
Anyone got this working ?
Hi @normisWhen did you try this last? We fixed it yesterday
tried again at 14:00 CEST, stil the same errorWhen did you try this last? We fixed it yesterday
You can always download manually and drop it in Files. Reboot and the upgrade will be done.tried again at 14:00 CEST, stil the same errorWhen did you try this last? We fixed it yesterday
tried today 15:00 CESTWhen did you try this last? We fixed it yesterday
Any updates on this?When did you try this last? We fixed it yesterday
channel: upgrade
installed-version: 6.49.6
latest-version: 7.2.1
status: routeros-powerpc-7.2.1.npk missing, use ignore-missing or disable package(s)
system routerboard pr
routerboard: yes
model: 1200
serial-number: 2E320285D9A6
firmware-type: amcc460
factory-firmware: 2.37
current-firmware: 6.49.6
upgrade-firmware: 6.49.6
/tool fetch url="https://download.mikrotik.com/routeros/7.2.1/routeros-7.2.1-ppc.npk"
For other platforms it never has been manually.Yes... and not... transition from v6 to v7, wanted or accidentally, for me must be manual only...
Is my opinion...For other platforms it never has been manually....for me must be manual only...
Why here ?
I confirm that RB1200 is loaded with this particular file, but nothing with network works, I hardly rolled back to 6...
or by fetchBUT I SUGGEST TO NOT UPGRADE powerpc to v7, search other topic and you see than some 1100 stop booting after update!!!Code: Select all/tool fetch url="https://download.mikrotik.com/routeros/7.2.1/routeros-7.2.1-ppc.npk"
