samciar
issue, Traffic duplicate in others ports into a bridge
Sat Apr 09, 2022 8:44 am
Hi guys,
I hope those of you who read me are doing well!
I want to share my case with you, in the hope that someone will guide me on the possible solution.
I hope you can forgive my bad English,
It happens that I have a network with static ips /24, on a bridge.
This bridge has 6 ports assigned, among those:
Combo1, ether4, 5, 6, 7, 8.
The network works apparently fine, however when I go to /interface ethernet, the transmission traffic on combo1, ether7 and ether8 are the same, exactly the same.
If I torch the ether7 or ether8 I can see all the traffic that is generated on the /24 network, even though only two tplink routers are connected to those two ports, with one ip each.
What do you think this behavior is due to?
Users browsing this forum: haung05 and 96 guests
