wladkolc
Capsman cAP ac recommended settings
Sat Apr 09, 2022 1:04 pm
is there any recommended settings for cAP ac devices? I have house with 2 floor and cellar, i have tried lot of different settings but withou success.. my max speed over wifi is 300mb/s. I have 1gigabit provider speed, measured over cable over 850mb/s. I have one cap ac in cellar, one in living room on 1st floor, and another one on 2nd floor. Coverage is great, i have enabled access list restriction to devices with poor signal. Anybody knows how to make it faster? Thanks a lot for your help.
my settings:
# apr/09/2022 12:01:35 by RouterOS 7.2
# software id = MW9S-AAW0
# model = RB4011iGS+
# serial number = xxxxxxxxxxxx
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz extension-channel=disabled frequency=2432 name=channel24
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=Ceee frequency=5180 name=channel51 skip-dfs-channels=yes
/caps-man datapath
add client-to-client-forwarding=yes local-forwarding=yes name=datapath-default
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=security-default
/caps-man configuration
add channel=channel24 country=slovakia datapath=datapath-default installation=indoor mode=ap name=cfg24 security=security-default ssid=ssid
add channel=channel51 country=slovakia datapath=datapath-default installation=indoor mode=ap name=cfg51 security=security-default ssid=ssid_5G
/caps-man access-list
add action=accept allow-signal-out-of-range=10s disabled=no signal-range=-80..120 ssid-regexp="" time=0s-1d,sun,mon,tue,wed,thu,fri,sat
add action=reject
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes upgrade-policy=suggest-same-version
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=cfg24 name-format=prefix-identity name-prefix=2.4g
add action=create-dynamic-enabled hw-supported-modes=an master-configuration=cfg51 name-format=prefix-identity name-prefix=5g
Users browsing this forum: Majestic-12 [Bot] and 88 guests
