bruins0437
CPU Temp - CCR2216-1G-12XS-2XQ
Sun Apr 10, 2022 12:39 am
I just got a CCR2216-1G-12XS-2XQ up and running in my lab. I noticed the CPU temperature has been around 58-60 degrees Celsius. Based on the data sheet, it looks like that is on the boarder of upper-end of the operating temperature.
I was curious if anyone else has a CCR2216 or 2116 and is seeing the same cpu temps. Ambient temperature is 20 Celsius.
chechito
Re: CPU Temp - CCR2216-1G-12XS-2XQ
Sun Apr 10, 2022 3:13 am
operating temperature on datasheet refers to ambient temperature suitable for operation
bruins0437
Sun Apr 10, 2022 4:56 am
Ah, thank you. So there isn’t any concern that the cpu is around 60 Celsius.
chechito
Sun Apr 10, 2022 7:28 am
i think for any modern CPU 60 C° its ok
normally in a MikroTik router we dont see CPU deep sleeping on the CPU when not loaded to achieve low temps when the load is low so this temperature is normal even when not heavy loaded
We will see with a heavy workload how much it rise
Looking the images of the thermal solution on ccr2216 i dont expect to have temperature problems
StubArea51
Trainer
Trainer
Sun Apr 10, 2022 10:08 am
Here's what the temps are on the two CCR2216s I have in my lab
[zuul@ccr2216-01.test.lab.ipa] > system/health/print
Columns: NAME, VALUE, TYPE
 #  NAME                VALUE  TYPE
 0  temperature         38     C
 1  cpu-temperature     58     C
 2  sfp-temperature     38     C
 3  switch-temperature  48     C
 4  fan1-speed          5160   RPM
 5  fan2-speed          5190   RPM
 6  fan3-speed          5250   RPM
 7  fan4-speed          5190   RPM
 8  board-temperature1  33     C
 9  board-temperature2  34     C
10  psu1-state          ok
11  psu2-state          fail
[zuul@ccr2216-02.test.lab.ipa] > system/health/print
 #  NAME                VALUE  TYPE
 0  temperature         37     C
 1  cpu-temperature     57     C
 2  sfp-temperature     37     C
 4  fan1-speed          4830   RPM
 5  fan2-speed          4980   RPM
 6  fan3-speed          4980   RPM
 7  fan4-speed          4920   RPM
 8  board-temperature1  35     C
 9  board-temperature2  35     C
10  psu1-state          ok
11  psu2-state          fail
Miracle
Sun Apr 10, 2022 12:02 pm
Maybe they use low quality thermal paste ?
bruins0437
Mon Apr 11, 2022 4:15 am
Okay cool! We are both seeing same results. Thanks for the feed back everyone!
[admin@wildcats.rtr01] > system health print
 #  NAME                VALUE  TYPE
 0  temperature         30     C
 2  sfp-temperature     30     C
 3  switch-temperature  35     C
 4  fan1-speed          3390   RPM
 5  fan2-speed          3510   RPM
 6  fan3-speed          3510   RPM
 7  fan4-speed          3540   RPM
 8  board-temperature1  23     C
 9  board-temperature2  22     C
10  psu1-state          ok
11  psu2-state          ok
Users browsing this forum: Ferdinando1968 and 111 guests
