Dude Server - System requirements
The_Dude_v6 - System_requirements_for_server_package
RouterOS Hardware:
- TILE devices;
- ARM devices;
- MMIPS devices;
- RouterOS x86 installations;
- RouterOS Cloud Hosted Router, CHR
Download - Extra packages
Dude Agent - System requirements
The Dude v6/Agents
Agents are other Dude servers that can be used as intermediaries for device monitoring. Starting from RouterOS 6.38.x any RouterOS device can be a Dude agent without any installation or configuration required.
Hardware considerations
Small environment: < 200 devices
1. hEX (RB750Gr3) with microSD card 16/32GB
2. VM with 1 vCPU/512MB RAM/10GB Disk
Medium environment: 200 - 500 devices
1. RB1100AHx4 Dude Edition with included 60GB SSD
2. VM with 2 vCPU/2GB RAM/20GB Disk
Large environment: > 500 devices
2. TILE based device which have M.2 slot for SSD
3. VM with 4 vCPU/4GB RAM/40GB Disk
Note: Dude can be unstable and slow with big number of devices/probes
Storage considerations
System requirements for server package
Note: For models with 16MB on-board storage use of USB/μSD storage is required to run The Dude server on the device.
Note: Preferably you should use industrial grade mircoSD cards and USB drives as they have longer life cycle under applications that can write data to flash more frequently as The Dude server database in this case. For large network monitoring it is suggested to us highly reliable HDD/SSD drives.
krisjanis
CCR microSD slot performance is not to great, at least per our tests it is not good enough for The Dude server storage. I would try again with some high speed usb3.0 flash or drive. Also in best case with latest v6.38rc build on the device, to have all of the latest db performance tweaks.
Mikrotik hardware - Product matrix
1 - Supported architecture
2 - Storage expanding options (M.2/MiniPCI-e/Memory card/USB)
3 - CPU
4 - RAM
5 - Price
TILE
CCR1009-7G-1C-PC - TILE | microUSB | 9 x 1 GHz (TLR4-00980) | 1 GB | $465.00
CCR1009-7G-1C-1S+ - TILE | microSD / microUSB | 9 x 1.2 GHz (TLR4-00980) | 2 GB | $545.00
CCR1009-7G-1C-1S+PC - TILE | microSD / microUSB | 9 x 1 GHz (TLR4-00980) | 2 GB | $545.00
CCR1016-12G - TILE | USB type A | 16 x 1.2 GHz (TLR4-01680) | 2 GB | $705.00
CCR1016-12S-1S+ - TILE | microSD / USB type A | 16 x 1.2 GHz (TLR4-01680) | 2 GB | $815.00
CCR1036-12G-4S - TILE | M.2 / USB type A | 36 x 1.2 GHz (TLR4-03680) | 4 GB | $1095.00
CCR1036-8G-2S+ - TILE | M.2 / microSD / USB type A | 36 x 1.2 GHz (TLR4-03680) | 4 GB | $1195.00
CCR1036-12G-4S-EM - TILE | M.2 / USB type A | 36 x 1.2 GHz (TLR4-03680) | 8 GB | $1295.00
CCR1036-8G-2S+EM - TILE | M.2 / microSD / USB type A | 36 x 1.2 GHz (TLR4-03680) | 8 GB | $1395.00
CCR1072-1G-8S+ - TILE | 2 x M.2 / microSD / USB 2.0 type A / microUSB 2.0 | 72 x 1 GHz (TLR4-07280) | 16 GB | $3350.00
ARM
RB3011UIAS-RM - ARM 32bit | USB 3.0 type A | 2 x 1.4 GHz (IPQ-8064) | 1 GB | $179.00
RB5009UG+S+IN - ARM 64bit | USB 3.0 type A | 4 x 350-1400 MHz (88F7040) | 1 GB | $219.00
RB5009UPr+S+IN - ARM 64bit | USB 3.0 type A | 4 x 350-1400 MHz (88F7040) | 1 GB | $299.00
RB1100AHx4 - ARM 32bit | microSD | 4 x 1.4 GHz (AL21400) | 1 GB | $385.00
RB1100AHx4 Dude Edition - ARM 32bit | 60GB M.2 SSD included / 2 x M.2 / microSD / 2 x SATA3 | 4 x 1.4 GHz (AL21400) | 1 GB | $385.00
CCR2004-16G-2S+ - ARM 64bit | USB 3.0 type A | 4 x 1700 MHz | 4 GB | $465.00
CCR2116-12G-4S+ - ARM 64bit | M.2 | 16 x 2000 MHz (AL73400) | 16 GB | $995.00
CCR2216-1G-12XS-2XQ - ARM 64bit | 2 x M.2 | 16 x 2000 MHz (AL73400) | 16 GB | $2795.00
mANTBox 52 15s (RBD22UGS-5HPacD2HnD-15S) - ARM 32bit | USB type A | 4 x 716 MHz (IPQ-4019) | 256 MB | $159.00
NetMetal ac² (RBD23UGS-5HPacD2HnD-NM) - ARM 32bit | USB type A | 4 x 716 MHz (IPQ-4019) | 256 MB | $169.00
hAP ac² (RBD52G-5HacD2HnD-TC) - ARM 32bit | USB 2.0 type A | 4 x 716 MHz (IPQ-4018) | 128 MB | $69.00
hAP ac³ (RBD53iG-5HacD2HnD) - ARM 32bit | USB 2.0 type A | 4 x 716 MHz (IPQ-4019) | 256 MB | $99.00
RB4011iGS+5HacQ2HnD-IN - ARM 32bit | MiniPCI-e slot with installed card | 4 x 1.4 GHz (AL21400) | 1 GB | $275.00
hAP ac³ LTE6 kit (RBD53GR-5HacD2HnD&R11e-LTE6) - ARM 32bit | USB 2.0 type A | 4 x 716 MHz (IPQ-4019) | 256 MB | $219.00
Chateau LTE12 (RBD53G-5HacD2HnD-TC&EG12-EA) - ARM 32bit | USB 2.0 type A | 4 x 716 MHz (IPQ-4019) | 256 MB | $229.00
Chateau LTE6-US (D53G-5HacD2HnD-TC&EG06-A) - ARM 32bit | USB 2.0 type A | 4 x 488-896 MHz (IPQ-4019) | 256 MB | $189.00
Chateau 5G (D53G-5HacD2HnD-TC&RG502Q-EA) - ARM 32bit | USB 2.0 type A | 4 x 716 MHz (IPQ-4019) | 256 MB | $530.00
Chateau LTE18 ax (S53UG+5HaxD2HaxD-TC&EG18-EA) - ARM 64bit | USB 3.0 type A | 4 x 864-1800 MHz (IPQ-6010) | 1 GB | $299.00
Chateau 5G ax (S53UG+M-5HaxD2HaxD-TC&RG502Q-EA) - ARM 64bit | M.2 | USB 3.0 type A | 4 x 864-1800 MHz (IPQ-6010) | 1 GB | $595.00
hAP ax³ (C53UiG+5HPaxD2HPaxD) - ARM 64bit | USB 3.0 type A | 4 x 864-1800 MHz (IPQ-6010) | 1 GB | $139.00
L009UiGS-RM - ARM 64bit | USB 3.0 type A | 2 x 800 MHz (IPQ-5018) | 128 MB | $119
RB5009UPr+S+OUT - ARM 64bit | USB 3.0 type A | 4 x 350-1400 MHz (88F7040) | 1 GB | $319
L009UiGS-2HaxD-IN - ARM 64bit | USB 3.0 type A | 2 x 800 MHz (IPQ-5018) | 128 MB | $129
MMIPS
hEX (RB750Gr3) - MMIPS | microSD / USB 2.0 type A | 2 x 880 MHz (MT7621A) | 256 MB | $59.95
hEX S (RB760iGS) - MMIPS | microSD / USB 2.0 type A | 2 x 880 MHz (MT7621A) | 256 MB | $69.00
Related posts
1. The Dude: Large scale setup. Improved performance. No timeouts.
2. Poor Dude performance.
3. Hardware to run Dude Server
4. The Dude installed & enabled but not working
5. Cheapest hardware for Dude Server
6. Minimum size of MicroSD card on hEX for the Dude? [SOLVED]
7. Unable to install dude server
8. Newbie Dude installation
9. How can I install dude in MIPSBE?[SOLVED]
10. A VPS to run Dude
11. Options for hosting Dude Server
12. Installation of the dude
13. no dude for PPC neither MIPSBE
14. RB750r2 MIPS-BE Dude Capable?
15. What Mikrotik router support TheDude?
16. Optimal hardware for dude chart performance
17. help
18. Dude setup on RB 3011
19. Dude Server on Windows
20. Dude on hEX - unsuitable for 500+ devices?
21. Best Device to run Dude
22. New device that supports The Dude server package: RB750r3 hEX [SOLVED]
23. Windows Dude vs RouterOS Dude
24. Most simple / cheapest HW for the Dude
25. The Dude without windows
26. The dude RB1100 and RB450G
27. What is the ideal hardware/software Dude setup?
28. Dude 3.6 on ROS 6.x mipsbe (RB2011UAS-2HND-IN)
29. Dude crashes RB2011 UAS-RM
30. Dude on RB1100
31. Run The Dude from a Routerboard
32. Dude-3.6.npk on a cheapest MikroTik Hardware e.g. RB250GS
33. monitoring 490 items - want to move from x86 to 1100ahx2
