kwjennings
RB 4011 running CAPs-MAN slow wifi
Mon Apr 11, 2022 6:10 pm
Hi All
I have an RB 4011 and two cAP ac administered by CAPs MAN.
Everything in Mikro Tik is running router board OS V 6.49.5
The two cAPs are connected to the 4011 with Cat 6A cable
I have an Apple TV 4K box connected to the RB 4011 with Cat 6A cable. Using speed.cloudflare.net on the Apple TV 4K box I see speeds of 496 - 510 Mbps at the Apple 4K box.
6 meters away from the cAP I see 35 - 50 Mbps on most wi-fi clients (both Apple & Android)
What do I need to do to my settings to improve my wifi? Certainly the RB 4011 is able to pass the 500 Mbps speed through its ethernet with zero degradation.
Should I try to use (Tools > Bandwidth Test) to check the speed between the RB 4011 and the 2 cAPS?
If I do that and see acceptable speeds there then I can focus on the wireless setting for the cAPs. Is this diagnostic path sensible?
How must I change my wireless settings to improve my wi-fi throughput and speed?
kwjennings
Re: RB 4011 running CAPs-MAN slow wifi
Mon Apr 11, 2022 6:19 pm
UPDATE:
Using SPEED TEST I checked the speed of the ethernet connection between my cAPS and the RB 4011.
One shows 980 Mbps the other shows 970Mbps.
Now I think that that the CAPs MAN settings and the network settings on my RB 4011 are OK.
As a NEWBIE / ROOKIE it seems to me therefore; that I should FOCUS my troubleshooting work on the radio settings for my 2 cAPs .
Does anyone think that I am jumping to conclusions?
Does anyone have any advice or guidance on how I should proceed to OPTIMIZE my radio / wi fi settings?
holvoetn
Mon Apr 11, 2022 8:54 pm
Post config for capsman controller.
/export hide-sensitive file= anynameyouwish.
Review for sensitieve info and post between [code] quote.
holvoetn
Mon Apr 11, 2022 8:56 pm
Review for sensitive info and post between [code] quote.
Users browsing this forum: No registered users and 42 guests
