nikant
[HELP] MTU size in all devices
Mon Apr 11, 2022 8:25 pm
Hoping for some help again..
The setup is as following [ISP-router] -> RB2011uias-in -> two Nanostations M2 in bridge mode that work as access points..
ISP-router has an MTU setting of 1492 (connected in eth1)
RB2011 and NSM2 (eth3 and eth4) have 1500 and additionally RB2011 L2MTU 1598
Should all 1500's (eth1, eth3, eth4) be changed to ISPs 1492 ? (and what about L2MTU)
Thank you
mkx
Re: [HELP] MTU size in all devices
Mon Apr 11, 2022 10:27 pm
All MTUs on same IP subnet should be the same. If ISP modem has MTU 1492 on LAN interface, then that's the value on all other LAN devices. Note, that MTU on ISP modem WAN interface can be different. If RB is routing between ISP modem and nanos, then again MTU does not have to be the same on both sides.
L2MTU can be as high as it gets, but should not be lower than MTU+ethernet overhead, normally that's MTU+14 (if VLAN is used, it's +18).
nikant
Tue Apr 12, 2022 2:04 pm
Thank you!
Kublach
Sat Jun 04, 2022 12:54 pm
I also need help with MTU...
I have two Mtik devices:
What MTU must be on L2TP and EoIP...
Bridges on both sides are 1500.
Traffic through EoIP is multicast (IPTV) and it lags...
Thanks...
mkx
Sun Jun 05, 2022 2:53 pm
EoIP should have same MTU as other LAN devices are, most likely that's 1500. Since it comes with overhead and thus very often exceeds MTUs of underlying interfaces (e.g. PPPoE), it performs its own fragmentation/defragmentation, so at the end of the day it shouldn't be a problem other than performance hit.
With regards to multicasts over L2TP /EoIP: life sucks. Tunnels go via internet where all sorts of stuff happens. And multicasts don't like that. And there's nothing you can do about it.
nichky
Mon Jun 06, 2022 9:20 am
use the ping with do-not-fragment , that will tell u a lot
mkx
Mon Jun 06, 2022 11:41 am
If multicasts work somehow (albeit with pauses), then this is not the matter of MTU settings ... PMTUD doesn't work for multicast packets. If multicasts didn't work at all, then this could point towards MTUs.
Users browsing this forum: johnson73 and 233 guests
