getfeus
wAP LTE Kit(RBwAPGR-5HacD2HnD) Cannot connect Winbox / pptp from internet
Tue Apr 12, 2022 1:25 am
Hello. I have install wAP LTE kit on my garage but I cannot connect wAP's Winbox/PPTP from internet. I also tried using port mapping.
I have use almost same code on my HAP AC and it is working on it.
What is difference between non LTE model and LTE model?
Here is whole settings(I have blind sensitive codes.)
Thank you for reading.
# apr/11/2022 21:27:27 by RouterOS 6.49.5
# software id = 20LR-NG5U
# model = RBwAPGR-5HacD2HnD
# serial number = XXXXXX
add admin-mac=2C:C8:1B:A5:9B:3A auto-mac=no comment=defconf name=bridge
/interface lte
set [ find ] allow-roaming=no name=lte1 network-mode=3g
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=no_country_set disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=XXXXXX wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-Ceee country=no_country_set disabled=no distance=indoors \
    frequency=auto installation=indoor mode=ap-bridge ssid=XXXXXX_5G \
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=web.sktelecom.com authentication=pap name=\
    "sk telecom"
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=XXXXXXXX \
    wpa2-pre-shared-key=XXXXXXXX
add name=dhcp ranges=192.168.4.10-192.168.4.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=lte1 list=WAN
/interface pptp-server server
set enabled=yes
add address=192.168.4.1/24 comment=defconf interface=bridge network=\
    192.168.4.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=10m
add address=192.168.4.0/24 comment=defconf gateway=192.168.4.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.4.1 comment=defconf name=router.lan
    established,related,untracked
add action=accept chain=input comment="Accept 1723(PPTP)" dst-port=1723 \
    protocol=tcp
    protocol=udp
add action=accept chain=input comment="Accept 1723(PPTP)" protocol=gre
add action=accept chain=input comment="Accept 47(PPTP)" dst-port=47 protocol=\
    tcp
add action=accept chain=input comment=VPN port=1701,500,4500 protocol=udp
add action=accept chain=input comment=Winbox dst-port=8291 protocol=tcp
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=dst-nat chain=dstnat comment=Winbox dst-port=8291 protocol=tcp \
    to-addresses=192.168.4.1 to-ports=0
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=lte1 type=external
/ppp secret
add name=XXXXXX password=XXXXXX profile=default-encryption
/system clock
set time-zone-name=Asia/Seoul
/tool mac-server
/tool mac-server mac-winbox
AidanAus
Re: wAP LTE Kit(RBwAPGR-5HacD2HnD) Cannot connect Winbox / pptp from internet
Wed Apr 13, 2022 8:22 am
Probably a CG nat issue, I know here in Australia we have to pay extra to get a public IP as well as that no one offers static public IP's on the 3g/4g/lte etc services.
I would check and see what IP address the wap is getting from the LTE interface, if it is a private one you will not be able to connect TO it.
You are able to connect FROM it however do the the NAT, how does this help? what you can do is create a VPN server somewhere that does have a public IP address then have the wap be a client of this, once the VPN tunnel is established we would be able to connect to the wap through the VPN server using the tunnel :)
Users browsing this forum: AtomikRoach, rarlup, tesme33, zuna80 and 54 guests
