tgiannak
10g solarflare & mellanox Nics Supported??
Tue Apr 12, 2022 1:21 pm
hi,
does anyone know if some of these sfp+ nics are supported??
solarflare sfn7122
solarflare sfn5122
mellanox cx312a (connectx3)
rextended
Re: 10g solarflare & mellanox Nics Supported??
Tue Apr 12, 2022 3:18 pm
Directly from RouterOS x86 or with CHR?
tgiannak
Tue Apr 12, 2022 5:49 pm
CHR with passthrough these nics !
tgiannak
Wed Apr 13, 2022 12:31 pm
some help with this??
tgiannak
Fri Apr 15, 2022 11:17 am
so no one uses mellanox or solarflare??? :(
tgiannak
Wed Jun 28, 2023 11:37 am
i can confirm that in router os 7.3 and after, sfn7122 works!
solved
rextended
Wed Aug 16, 2023 5:42 pm
OK :)
chechito
Wed Aug 16, 2023 5:46 pm
thanks for reporting spam eliminated
xike
Wed Aug 23, 2023 9:44 am
Hello
I have used Mellanox and is supported
PortalNET
Sat Oct 21, 2023 4:55 pm
hi,
solarflare sfn7122
solarflare sfn5122
Hi yes they work.. directly on router os v7..
i can also confirm Mellanox 40gbps works.. and mellanox 100GBps card works but you have to go into nvidia to downlaod latest firmware drivers.. and use windows machine to flash new firmware drivers and change infiniband mode to Ethernet mode on configuration of the card.. only after changing to ethernet mode it will work and show up on routerOS v7
Users browsing this forum: No registered users and 10 guests
