ericSchultz
CRS sfp woe's
Tue Apr 12, 2022 11:11 pm
I use a fairly wide variety of RouterBOARD hardware and am having an issue with getting NEW sfp 10/100/1000 ethernet modules working in a CRS.
I have 3 different model SFP modules:
Module A - Old model
                    sfp-vendor-name: QSFPTEK
             sfp-vendor-part-number: QT-SFP-T
                sfp-vendor-revision: A
             sfp-manufacturing-date: 20-08-05
Module B - Same as A, just the new model
                sfp-vendor-revision: 1.0
             sfp-manufacturing-date: 21-12-07
Module C - Different module completely
                    sfp-vendor-name: OEM
             sfp-vendor-part-number: SFP-GE-T
             sfp-manufacturing-date: 21-08-31
In the 2011UiAS-2HnD All 3 work perfect, no issues
In the CRS317-1G-16S+ Only the "old" version Module A works
So, baseline info Everything works:
# jun/02/2021 09:09:27 by RouterOS 6.48.3
# software id = N9JC-YMW5
# model = 2011UiAS-2HnD
Module B Working
                             status: link-ok
                   auto-negotiation: done
                               rate: 1Gbps
                        full-duplex: yes
                    tx-flow-control: no
                    rx-flow-control: no
                        advertising:
           link-partner-advertising:
                 sfp-module-present: yes
                        sfp-rx-loss: no
                           sfp-type: SFP-or-SFP+
                 sfp-connector-type: RJ45
  sfp-link-length-copper-active-om4: 100m
                  sfp-vendor-serial: BQT1129119
                    eeprom-checksum: good
                             eeprom: 0000: 03 04 22 00 00 00 08 00  00 00 00 01 0d 00 00 00  .."..... ........
                                     0010: 00 00 64 00 51 53 46 50  54 45 4b 20 20 20 20 20  ..d.QSFP TEK
                                     0020: 20 20 20 20 00 00 00 00  51 54 2d 53 46 50 2d 54      .... QT-SFP-T
                                     0030: 20 20 20 20 20 20 20 20  31 2e 30 20 00 00 00 cc           1.0 ....
                                     0040: 00 1a 00 00 42 51 54 31  31 32 39 31 31 39 20 20  ....BQT1 129119
                                     0050: 20 20 20 20 32 31 31 32  30 37 20 20 00 00 00 96      2112 07  ....
                                     0060: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     0070: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     0080: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     0090: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     00a0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     00b0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     00c0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     00d0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     00e0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     00f0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
Module C Working
                             status: link-ok
                               rate: 1Gbps
                        full-duplex: yes
                    tx-flow-control: no
                    rx-flow-control: no
                        advertising:
                        sfp-rx-loss: no
                  sfp-vendor-serial: CSGE2L84231
                             eeprom: 0000: 03 04 00 00 00 00 08 00  00 00 00 01 0d 00 00 00  ........ ........
                                     0010: 00 00 64 00 4f 45 4d 20  20 20 20 20 20 20 20 20  ..d.OEM
                                     0020: 20 20 20 20 00 00 00 00  53 46 50 2d 47 45 2d 54      .... SFP-GE-T
                                     0030: 20 20 20 20 20 20 20 20  20 20 20 20 00 00 c1 66               ...f
                                     0040: 00 1a 00 00 43 53 47 45  32 4c 38 34 32 33 31 20  ....CSGE 2L84231
                                     0050: 20 20 20 20 32 31 30 38  33 31 20 20 00 00 00 cb      2108 31  ....
                                     0060: 00 00 11 d2 60 cd 19 49  21 dc b3 e5 20 ff 95 dc  ....`..I !... ...
                                     0070: 5d 10 0b 00 00 00 00 00  00 00 00 00 b7 f2 8e eb  ]....... ........
Then in the CRS.
# apr/12/2022 09:58:49 by RouterOS 6.49.5
# software id = XWL6-PMIM
# model = CRS317-1G-16S+
Module A Working
                             status: link-ok
                               rate: 1Gbps
                        full-duplex: yes
                    tx-flow-control: no
                    rx-flow-control: no
                        advertising:
                        sfp-rx-loss: no
                       sfp-tx-fault: no
                  sfp-vendor-serial: BQT200805006
           sfp-dwdm-channel-spacing: 1Ghz
                                     0020: 20 20 20 20 01 00 00 00  51 54 2d 53 46 50 2d 54      .... QT-SFP-T
                                     0030: 20 20 20 20 20 20 20 20  41 20 20 20 00 00 c1 5e           A   ...^
                                     0040: 00 10 00 00 42 51 54 32  30 30 38 30 35 30 30 36  ....BQT2 00805006
                                     0050: 20 20 20 20 32 30 30 38  30 35 20 20 00 00 00 ab      2008 05  ....
                                     0060: 00 00 08 48 12 2f 2e 37  43 a9 ae 7c 94 57 a4 85  ...H./.7 C..|.W..
                                     0070: c5 51 4f 00 00 00 00 00  00 00 00 00 60 56 0c 0a  .QO..... ....`V..
Module C Not Working
                             status: no-link
                   auto-negotiation: failed
                        advertising:
                        sfp-rx-loss: no
                       sfp-tx-fault: no
Module B Not Working
                             status: no-link
                        advertising:
                        sfp-rx-loss: yes
                       sfp-tx-fault: no
Now these all had the same network cable and mini switch on the other end (so that the test conditions were the same.)
killersoft
Re: CRS sfp woe's
Sat Apr 16, 2022 3:50 pm
Yep, seems pretty normal for generic sfp's to randomly work between MT chassis. I have about 50 MT devices in my care all using fiber trunks.
Generally speaking I use either genuine mikrotik SFP's, or Cisco Genuine( which seem to work fine ) in my MT gear.
I also keep an eye on :
https://wiki.mikrotik.com/wiki/MikroTik ... ansceivers
savage
Re: CRS sfp woe's
Sun Apr 17, 2022 10:45 am
+1 I also stay away from copper SFPs Even MT's own copper SFPs.
AidanAus
Re: CRS sfp woe's
Wed Apr 20, 2022 8:22 am
for the last 2 non working modules, can you try turning off auto negotiation on both ends of the link and then setting the link speed manually and see if you are able to get the link up and running?
ericSchultz
Re: CRS sfp woe's
Wed Apr 20, 2022 2:16 pm
I will give that a try. Thank you.
Users browsing this forum: No registered users and 50 guests
