The connected devices can get individual IPs via the DHCP on the VLAN but they can't access the internet. They are able to ping the bridge the VLAN is on and an IP assigned to ether1 (which is connected to a LAN port on the ISP router). It might be obvious, but I'm pretty new to networking and configuration. I'm not sure how to assign an IP from the ISP router/modem to the devices on the VLAN. Does this require a DHCP relay or is there something I'm overlooking?
I've used viewtopic.php?f=23&t=143620 and tried a few different configurations but am wondering if it's not possible with a single hap ac3 unit. I would appreciate any help I can get.
Thanks!
Text Diagram of Setup
VLANs (1,2,3) --> Bridge on Hap Ac3 --> Ether 1 from HAP ac3 to LAN port --> ISP router/modem
Adding my current export below...
Code: Select all
add ingress-filtering=no name=bridge0 vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX \
disabled=no frequency=auto mode=ap-bridge scan-list=2437,2412,2462 ssid=\
WIFI2 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no frequency=auto installation=indoor \
keepalive-frames=disabled mode=ap-bridge scan-list=5200,5240,5180,5220 \
ssid=WIFI1 wps-mode=disabled
/interface vlan
add interface=bridge0 name=vlan_base vlan-id=40
add interface=bridge0 name=vlanW vlan-id=30
add interface=bridge0 name=vlanX vlan-id=10
add name=WAN
add name=VLAN
add name=BASE
/interface wireless
add default-forwarding=no disabled=no keepalive-frames=disabled mac-address=\
"" master-interface=wlan2 multicast-buffering=disabled \
name=wlan3 security-profile=workey ssid=WORKWIFI wds-cost-range=0 \
wds-default-cost=0 wps-mode=disabled
add name=dhcp_pool4 ranges=192.168.40.2-192.168.40.254
add name=dhcp_pool5 ranges=192.168.30.2-192.168.30.254
add name=dhcp_pool6 ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp_pool4 interface=vlan_base name=dhcp1
add address-pool=dhcp_pool5 interface=vlanW name=dhcp2
add address-pool=dhcp_pool6 interface=vlanX name=dhcp3
add bridge=bridge0 frame-types=admit-only-untagged-and-priority-tagged \
interface=wlan1 pvid=10
interface=wlan2 pvid=10
interface=wlan3 pvid=30
interface=ether4 pvid=10
interface=ether3 pvid=40
interface=ether2 pvid=40
interface=ether5 pvid=30
add bridge=bridge0 hw=no interface=ether1
/interface bridge vlan
add bridge=bridge0 tagged=bridge0,ether2 vlan-ids=40
add bridge=bridge0 tagged=bridge0 vlan-ids=30
add bridge=bridge0 tagged=bridge0 vlan-ids=10
add interface=ether1 list=WAN
add interface=vlan_base list=VLAN
add interface=vlanW list=VLAN
add interface=vlanX list=VLAN
add interface=vlan_base list=BASE
add interface=vlanX list=BASE
add address=192.168.10.1/24 interface=vlanX network=192.168.10.0
add address=192.168.30.1/24 interface=vlanW network=192.168.30.0
add address=192.168.40.1/24 interface=vlan_base network=192.168.40.0
add address=192.168.0.2/24 interface=bridge0 network=192.168.0.0
add address=192.168.10.0/24 dns-server=192.168.0.2 gateway=192.168.10.1
add address=192.168.30.0/24 gateway=192.168.30.1
add address=192.168.40.0/24 gateway=192.168.40.1
add action=accept chain=input comment="Allow Estab & Related" \
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow BASE Full Access" \
in-interface-list=BASE
add action=drop chain=input comment=Drop
add action=accept chain=forward comment="Allow Estab & Related" \
add action=accept chain=forward comment="VLAN Internet Access only" \
connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=masquerade chain=srcnat comment="Default masquerade" \
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.0.1 routing-table=main \
suppress-hw-offload=no
add disabled=no distance=1 dst-address=192.168.0.2/24 gateway=192.168.0.1 \
pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
