AKCErftstadt
HotSpot SSL ERROR: ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Wed Apr 13, 2022 11:34 pm
I have the problem at a location with RouterOS version 6.49.5 that the clients display the message "ERR_SSL_VERSION_OR_CIPHER_MISMATCH" and therefore no login to the HotSpot is possible.
- DNS name is set
- Certificate including all intermediate certificates is installed and valid including key
We now have the error in 8 routers out of 10,000 devices. But those are also the first ones with version 6.49.5. Unfortunately, I can't reproduce the error and it only appears with the customer.
Not all end devices are affected either (approx. 15%).
Has anyone ever had this?
Kind regards
heiko
Test with SSLYZE:
CHECKING CONNECTIVITY TO SERVER(S)
#DNSNAME#:443 => 172.31.0.1
SCAN RESULTS FOR #DNSNAME#:443 - 172.31.0.1
* Certificates Information:
Hostname sent for SNI: #DNSNAME#
Number of certificates detected: 1
Certificate #0 ( _RSAPublicKey )
SHA1 Fingerprint: 807fadf85104deb88139be84839dba1c49a79c69
Common Name: #DNSNAME#
Issuer: Thawte TLS RSA CA G1
Serial Number: 17074692820744584699632232447661896795
Not Before: 2021-06-18
Not After: 2022-07-19
Public Key Algorithm: _RSAPublicKey
Signature Algorithm: sha256
Key Size: 4096
Exponent: 65537
DNS Subject Alternative Names: ['#DNSNAME#']
Certificate #0 - Trust
Hostname Validation: OK - Certificate matches server hostname
Android CA Store (12.0.0_r9): OK - Certificate is trusted
Apple CA Store (iOS 15, iPadOS 15, macOS 12, tvOS 15, and watchOS 8):OK - Certificate is trusted
Java CA Store (jdk-13.0.2): OK - Certificate is trusted
Mozilla CA Store (2021-12-19): OK - Certificate is trusted
Windows CA Store (2021-11-28): OK - Certificate is trusted
Symantec 2018 Deprecation: OK - Not a Symantec-issued certificate
Received Chain: #DNSNAME# --> Thawte TLS RSA CA G1 --> DigiCert Global Root G2
Verified Chain: #DNSNAME# --> Thawte TLS RSA CA G1 --> DigiCert Global Root G2
Received Chain Contains Anchor: WARNING - Received certificate chain contains the anchor certificate
Received Chain Order: OK - Order is valid
Verified Chain contains SHA1: OK - No SHA1-signed certificate in the verified certificate chain
Certificate #0 - Extensions
OCSP Must-Staple: NOT SUPPORTED - Extension not found
Certificate Transparency: OK - 3 SCTs included
Certificate #0 - OCSP Stapling
NOT SUPPORTED - Server did not send back an OCSP response
* SSL 2.0 Cipher Suites:
Attempted to connect using 7 cipher suites; the server rejected all cipher suites.
* SSL 3.0 Cipher Suites:
Attempted to connect using 80 cipher suites; the server rejected all cipher suites.
* TLS 1.0 Cipher Suites:
Attempted to connect using 80 cipher suites.
The server accepted the following 6 cipher suites:
TLS_RSA_WITH_CAMELLIA_256_CBC_SHA 256
TLS_RSA_WITH_CAMELLIA_128_CBC_SHA 128
TLS_RSA_WITH_AES_256_CBC_SHA 256
TLS_RSA_WITH_AES_128_CBC_SHA 128
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA 256 ECDH: prime256v1 (256 bits)
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA 128 ECDH: prime256v1 (256 bits)
The group of cipher suites supported by the server has the following properties:
Forward Secrecy OK - Supported
Legacy RC4 Algorithm OK - Not Supported
* TLS 1.1 Cipher Suites:
* TLS 1.2 Cipher Suites:
Attempted to connect using 156 cipher suites.
The server accepted the following 14 cipher suites:
TLS_RSA_WITH_AES_256_GCM_SHA384 256
TLS_RSA_WITH_AES_256_CBC_SHA256 256
TLS_RSA_WITH_AES_128_GCM_SHA256 128
TLS_RSA_WITH_AES_128_CBC_SHA256 128
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 256 ECDH: prime256v1 (256 bits)
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 256 ECDH: prime256v1 (256 bits)
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 128 ECDH: prime256v1 (256 bits)
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 128 ECDH: prime256v1 (256 bits)
* TLS 1.3 Cipher Suites:
Attempted to connect using 5 cipher suites; the server rejected all cipher suites.
* Deflate Compression:
OK - Compression disabled
* OpenSSL CCS Injection:
OK - Not vulnerable to OpenSSL CCS injection
* OpenSSL Heartbleed:
OK - Not vulnerable to Heartbleed
* ROBOT Attack:
OK - Not vulnerable.
* Session Renegotiation:
Client Renegotiation DoS Attack: VULNERABLE - Server honors client-initiated renegotiations
Secure Renegotiation: OK - Supported
* Elliptic Curve Key Exchange:
Supported curves: prime256v1
Rejected curves: X25519, X448, prime192v1, secp160k1, secp160r1, secp160r2, secp192k1, secp224k1, secp224r1, secp256k1, secp384r1, secp521r1, sect163k1, sect163r1, sect163r2, sect193r1, sect193r2, sect233k1, sect233r1, sect239k1, sect283k1, sect283r1, sect409k1, sect409r1, sect571k1, sect571r1
SCANS COMPLETED IN 8.419035 S
COMPLIANCE AGAINST MOZILLA TLS CONFIGURATION
Checking results against Mozilla's "intermediate" configuration. See https://ssl-config.mozilla.org/ for more details.
#DNSNAME#:443: FAILED - Not compliant.
* maximum_certificate_lifespan: Certificate life span is 396 days, should be less than 366.
* tls_versions: TLS versions {'TLSv1.1', 'TLSv1'} are supported, but should be rejected.
* ciphers: Cipher suites {'TLS_RSA_WITH_AES_256_CBC_SHA256', 'TLS_RSA_WITH_AES_256_CBC_SHA', 'TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384', 'TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA', 'TLS_RSA_WITH_AES_128_CBC_SHA', 'TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA', 'TLS_RSA_WITH_AES_128_CBC_SHA256', 'TLS_RSA_WITH_CAMELLIA_256_CBC_SHA', 'TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256', 'TLS_RSA_WITH_CAMELLIA_128_CBC_SHA', 'TLS_RSA_WITH_AES_256_GCM_SHA384', 'TLS_RSA_WITH_AES_128_GCM_SHA256'} are supported, but should be rejected.
Users browsing this forum: AndHe, Bing [Bot], gtsspmsbr, HeinoHomm, holvoetn, JohnConnett, madmeesh and 123 guests
