tommyd
7.2 redistribute BGP to OSPF
Fri Apr 15, 2022 10:39 am
How do I change distance of routes imported into OSPF from BGP, and generally how can I control what is redistributed ?
I've tried to set ospf out filter to
if (dst in 10.126.22.0/24) { set ospf-ext-metric 40; set ospf-ext-type type1; set distance 40; accept}
but it doesn't seem to do anything
mrz
Re: 7.2 redistribute BGP to OSPF
Fri Apr 15, 2022 2:38 pm
You cannot set distance for output routes, because distance is local to the router. You can set other parametrer like ospf metric or route tag which can then be used to match specific routes and adjust the distance on the remote routers input.
eduplant
Fri Apr 15, 2022 8:15 pm
I haven’t tested this myself yet but reading @mrz’s response I’m curious. Since setting distance is conceptually invalid in this case, is the result that the entire filter clause fails to be applied? I would naïvely expect that it would just ignore the irrelevant set statement. It seems reasonable that it would still do the match, set the OSPF metric, set the OSPF type, and then accept the route.
@mrz are you just pointing this out for @tommyd’s benefit or are you saying that this is why no routes are being matched at all?
mrz
Tue Apr 19, 2022 7:51 am
In the original post there is no mention that prefix is not matched at all. Setting distance in the output will not fail to match anything, rule in the first post will still apply ospf ext type and ext metric.
tommyd
Tue Apr 19, 2022 10:24 am
doesn't work either
mrz
Tue Apr 19, 2022 11:07 am
Then does the prefixes you are trying to match and set ext metric are actually external (LSA type should be "external")?
Users browsing this forum: No registered users and 13 guests
