AndriejusArt
IPSec to FortiGate with multiple policies Problems
Fri Apr 15, 2022 12:24 pm
Good time of day,
Think I will start with a short and general description, and If needed we will go deeper into details.
So I have CCR1009-8G-1S-1S+, with ROS v 7.1.5
I have 6 IPsec policies configured for the same peer with different SRC and DST addresses.
The settings for each policy are basically the exact same.
The issue is, that at some time a PH2 state of an any of the Policies either expires, or goes to "no phase2". Disabling - and enabling the policy forces it to establish the connection, but the main issues starts here: other peers start disconnecting/re-connecting spontaneously - it looks like when one of the policies establishes a connection - some other loses it, ant the policies cycle through the states for some time, and then settle-up with randomly established or "no phase 2" connections. Usually 5 out of 6 policies go "established" and one "no phase 2". It is not necessarily the one and the same policy.
The phase 1 and 2 settings seem to be correct, because any policy is able to establish the connection if left on it's own (all other policies disabled).
All policies are set level to "unique", since it was one of the few suggestions for issues similar to mine, that I managed to dig out.
Has anybody encountered something similar, any help much appreciated, and if needed - I am prepared to provide more information on the set up.
sindy
Re: IPSec to FortiGate with multiple policies Problems
Sun Apr 17, 2022 1:34 pm
At the Mikrotik side, set level=unique for all the policies. If this is already done, it will require debugging.
AndriejusArt
Tue Apr 19, 2022 5:06 pm
Thank you for the sudgestion, but as I mentioned - all the levels are already set to unique. I will capture and post some debug logs.
AndriejusArt
Tue Apr 26, 2022 3:56 pm
Good time of day. it took me a while, but now I am back. here is a piece of debug log for the IPSec establishing tunnels when one policy gets disabled/ enabled:
Apr/26/2022 15:33:07 ipsec,debug,packet 6ff6c263 bc1a7c3d 5c66ed06 3762d12a 15b65347 73de516d 5d75cad1 871ddef0
Apr/26/2022 15:33:07 ipsec,debug,packet 2c13b993 d588b5ca 97228046 d54e3051 94b3d510 bbab6fa0 2f92d1d6 11f00a72
Apr/26/2022 15:33:07 ipsec,debug,packet b2415ef7 336789eb 234f549c 6697e9da 400dcaf7 31b0d55a 663b6bea e586b2d8
Apr/26/2022 15:33:07 ipsec,debug,packet 925a02de f36b7457 878ed661 a745f24f f56080c0 85c31b9b c7c3150e 5ab6897c
Apr/26/2022 15:33:07 ipsec,debug,packet c44d008e ef332fc5 fcf0d989 c919c50b 5b6db4d3 9fc71fac 05000010 04000000
Apr/26/2022 15:33:07 ipsec,debug,packet 0a3c0000 fffffe00 0b000010 04000000 c0a81f00 ffffff00 0000001c 00000001
Apr/26/2022 15:33:07 ipsec,debug,packet 03046000 e07c74e6 80010001 00020004 0000a8c0 43423653 fcff8887 5a90390b
Apr/26/2022 15:33:07 ipsec,debug,packet padding len=12
Apr/26/2022 15:33:07 ipsec,debug,packet skip to trim padding.
Apr/26/2022 15:33:07 ipsec,debug,packet decrypted.
Apr/26/2022 15:33:07 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08102001 e9098f9c 000001dc 01000024
Apr/26/2022 15:33:07 ipsec,debug,packet 3ba678cf 3c90dda4 b97d6dc8 7b7bd4fe 0c8c142e 4a4565cd 60b8efc2 1d3975fc
Apr/26/2022 15:33:07 ipsec,debug,packet 0a00003c 00000001 00000001 00000030 01030401 e07c74e6 00000024 010c0000
Apr/26/2022 15:33:07 ipsec,debug,packet 80010001 00020004 00015180 80040001 80060100 80050005 8003000e 04000014
Apr/26/2022 15:33:07 ipsec,debug,packet 4cf2800a 488206a3 6356d576 248ef741 05000104 fa713a8f ed7161d9 e904b330
Apr/26/2022 15:33:07 ipsec,debug,packet 091174df 61cefd2c fa8b152c a5aaa95f 2bb627f9 f572a48f be3276fa 734d3a3e
Apr/26/2022 15:33:07 ipsec,debug,packet 6895788a fc6b68b5 a3d4a6de d0f6ccb4 7da40b63 902c9c44 2c79dfa6 c96e5956
Apr/26/2022 15:33:07 ipsec,debug,packet f3a7114c 88f1df28 b4b837be c4637ac6 c1677839 8b1a0758 426121b8 6ff6c263
Apr/26/2022 15:33:07 ipsec,debug,packet bc1a7c3d 5c66ed06 3762d12a 15b65347 73de516d 5d75cad1 871ddef0 2c13b993
Apr/26/2022 15:33:07 ipsec,debug,packet d588b5ca 97228046 d54e3051 94b3d510 bbab6fa0 2f92d1d6 11f00a72 b2415ef7
Apr/26/2022 15:33:07 ipsec,debug,packet 336789eb 234f549c 6697e9da 400dcaf7 31b0d55a 663b6bea e586b2d8 925a02de
Apr/26/2022 15:33:07 ipsec,debug,packet f36b7457 878ed661 a745f24f f56080c0 85c31b9b c7c3150e 5ab6897c c44d008e
Apr/26/2022 15:33:07 ipsec,debug,packet ef332fc5 fcf0d989 c919c50b 5b6db4d3 9fc71fac 05000010 04000000 0a3c0000
Apr/26/2022 15:33:07 ipsec,debug,packet fffffe00 0b000010 04000000 c0a81f00 ffffff00 0000001c 00000001 03046000
Apr/26/2022 15:33:07 ipsec,debug,packet e07c74e6 80010001 00020004 0000a8c0 43423653 fcff8887 5a90390b
Apr/26/2022 15:33:07 ipsec,debug begin.
Apr/26/2022 15:33:07 ipsec,debug seen nptype=8(hash) len=36
Apr/26/2022 15:33:07 ipsec,debug seen nptype=1(sa) len=60
Apr/26/2022 15:33:07 ipsec,debug seen nptype=10(nonce) len=20
Apr/26/2022 15:33:07 ipsec,debug seen nptype=4(ke) len=260
Apr/26/2022 15:33:07 ipsec,debug seen nptype=5(id) len=16
Apr/26/2022 15:33:07 ipsec,debug seen nptype=11(notify) len=28
Apr/26/2022 15:33:07 ipsec,debug succeed.
Apr/26/2022 15:33:07 ipsec,debug Remote_Public_IP Notify Message received
Apr/26/2022 15:33:07 ipsec Remote_Public_IP ignore RESPONDER-LIFETIME notification.
Apr/26/2022 15:33:07 ipsec,debug IDci matches proposal.
Apr/26/2022 15:33:07 ipsec,debug IDcr matches proposal.
Apr/26/2022 15:33:07 ipsec,debug HASH allocated:hbuf->l=472 actual:tlen=424
Apr/26/2022 15:33:07 ipsec,debug HASH(2) received:
Apr/26/2022 15:33:07 ipsec,debug 3ba678cf 3c90dda4 b97d6dc8 7b7bd4fe 0c8c142e 4a4565cd 60b8efc2 1d3975fc
Apr/26/2022 15:33:07 ipsec,debug,packet HASH with:
Apr/26/2022 15:33:07 ipsec,debug,packet e9098f9c b1b6631d 2092f82d fe06e22d 3a5ef80a 6824888b e97dd1cf 0a00003c
Apr/26/2022 15:33:07 ipsec,debug,packet 00000001 00000001 00000030 01030401 e07c74e6 00000024 010c0000 80010001
Apr/26/2022 15:33:07 ipsec,debug,packet 00020004 00015180 80040001 80060100 80050005 8003000e 04000014 4cf2800a
Apr/26/2022 15:33:07 ipsec,debug,packet 488206a3 6356d576 248ef741 05000104 fa713a8f ed7161d9 e904b330 091174df
Apr/26/2022 15:33:07 ipsec,debug,packet 61cefd2c fa8b152c a5aaa95f 2bb627f9 f572a48f be3276fa 734d3a3e 6895788a
Apr/26/2022 15:33:07 ipsec,debug,packet fc6b68b5 a3d4a6de d0f6ccb4 7da40b63 902c9c44 2c79dfa6 c96e5956 f3a7114c
Apr/26/2022 15:33:07 ipsec,debug,packet 88f1df28 b4b837be c4637ac6 c1677839 8b1a0758 426121b8 6ff6c263 bc1a7c3d
Apr/26/2022 15:33:07 ipsec,debug,packet 5c66ed06 3762d12a 15b65347 73de516d 5d75cad1 871ddef0 2c13b993 d588b5ca
Apr/26/2022 15:33:07 ipsec,debug,packet 97228046 d54e3051 94b3d510 bbab6fa0 2f92d1d6 11f00a72 b2415ef7 336789eb
Apr/26/2022 15:33:07 ipsec,debug,packet 234f549c 6697e9da 400dcaf7 31b0d55a 663b6bea e586b2d8 925a02de f36b7457
Apr/26/2022 15:33:07 ipsec,debug,packet 878ed661 a745f24f f56080c0 85c31b9b c7c3150e 5ab6897c c44d008e ef332fc5
Apr/26/2022 15:33:07 ipsec,debug,packet fcf0d989 c919c50b 5b6db4d3 9fc71fac 05000010 04000000 0a3c0000 fffffe00
Apr/26/2022 15:33:07 ipsec,debug,packet 0b000010 04000000 c0a81f00 ffffff00 0000001c 00000001 03046000 e07c74e6
Apr/26/2022 15:33:07 ipsec,debug,packet 80010001 00020004 0000a8c0
Apr/26/2022 15:33:07 ipsec,debug,packet hmac(hmac_sha2_256)
Apr/26/2022 15:33:07 ipsec,debug,packet HASH computed:
Apr/26/2022 15:33:07 ipsec,debug total SA len=56
Apr/26/2022 15:33:07 ipsec,debug 00000001 00000001 00000030 01030401 0c3c8106 00000024 010c0000 80010001
Apr/26/2022 15:33:07 ipsec,debug 00020004 00015180 80040001 80060100 80050005 8003000e
Apr/26/2022 15:33:07 ipsec,debug seen nptype=2(prop) len=48
Apr/26/2022 15:33:07 ipsec,debug proposal #1 len=48
Apr/26/2022 15:33:07 ipsec,debug seen nptype=3(trns) len=36
Apr/26/2022 15:33:07 ipsec,debug transform #1 len=36
Apr/26/2022 15:33:07 ipsec,debug type=SA Life Type, flag=0x8000, lorv=seconds
Apr/26/2022 15:33:07 ipsec,debug type=SA Life Duration, flag=0x0000, lorv=4
Apr/26/2022 15:33:08 ipsec,debug type=Encryption Mode, flag=0x8000, lorv=Tunnel
Apr/26/2022 15:33:08 ipsec,debug type=Key Length, flag=0x8000, lorv=256
Apr/26/2022 15:33:08 ipsec,debug type=Authentication Algorithm, flag=0x8000, lorv=hmac-sha256
Apr/26/2022 15:33:08 ipsec,debug type=Group Description, flag=0x8000, lorv=14
Apr/26/2022 15:33:08 ipsec,debug dh(modp2048)
Apr/26/2022 15:33:08 ipsec,debug pair 1:
Apr/26/2022 15:33:08 ipsec,debug 0x184e80: next=0 tnext=0
Apr/26/2022 15:33:08 ipsec,debug proposal #1: 1 transform
Apr/26/2022 15:33:08 ipsec,debug total SA len=56
Apr/26/2022 15:33:08 ipsec,debug 00000001 00000001 00000030 01030401 e07c74e6 00000024 010c0000 80010001
Apr/26/2022 15:33:08 ipsec,debug 00020004 00015180 80040001 80060100 80050005 8003000e
Apr/26/2022 15:33:08 ipsec,debug begin.
Apr/26/2022 15:33:08 ipsec,debug seen nptype=2(prop) len=48
Apr/26/2022 15:33:08 ipsec,debug succeed.
Apr/26/2022 15:33:08 ipsec,debug proposal #1 len=48
Apr/26/2022 15:33:08 ipsec,debug seen nptype=3(trns) len=36
Apr/26/2022 15:33:08 ipsec,debug transform #1 len=36
Apr/26/2022 15:33:08 ipsec,debug type=SA Life Type, flag=0x8000, lorv=seconds
Apr/26/2022 15:33:08 ipsec,debug type=SA Life Duration, flag=0x0000, lorv=4
Apr/26/2022 15:33:08 ipsec,debug 0x184ea0: next=0 tnext=0
Apr/26/2022 15:33:08 ipsec,debug begin compare proposals.
Apr/26/2022 15:33:08 ipsec,debug pair[1]: 0x184ea0
Apr/26/2022 15:33:08 ipsec,debug prop#=1 prot-id=ESP spi-size=4 #trns=1 trns#=1 trns-id=AES-CBC
Apr/26/2022 15:33:08 ipsec,debug peer's single bundle:
Apr/26/2022 15:33:08 ipsec,debug (proto_id=ESP spisize=4 spi=e07c74e6 spi_p=00000000 encmode=Tunnel reqid=0:0)
Apr/26/2022 15:33:08 ipsec,debug (trns_id=AES-CBC encklen=256 authtype=hmac-sha256)
Apr/26/2022 15:33:08 ipsec,debug my single bundle:
Apr/26/2022 15:33:08 ipsec,debug (proto_id=ESP spisize=4 spi=0c3c8106 spi_p=00000000 encmode=Tunnel reqid=2:2)
Apr/26/2022 15:33:08 ipsec,debug matched
Apr/26/2022 15:33:08 ipsec,debug ===
Apr/26/2022 15:33:08 ipsec,debug HASH(3) generate
Apr/26/2022 15:33:08 ipsec,debug,packet HASH with:
Apr/26/2022 15:33:08 ipsec,debug,packet 00e9098f 9cb1b663 1d2092f8 2dfe06e2 2d3a5ef8 0a682488 8be97dd1 cf4cf280
Apr/26/2022 15:33:08 ipsec,debug,packet 0a488206 a36356d5 76248ef7 41
Apr/26/2022 15:33:08 ipsec,debug,packet hmac(hmac_sha2_256)
Apr/26/2022 15:33:08 ipsec,debug,packet HASH computed:
Apr/26/2022 15:33:08 ipsec,debug,packet 400f4c8d ed4f72f9 730c8032 4979395b 84c1b666 0dd5dd82 7660c700 f49e62c2
Apr/26/2022 15:33:08 ipsec,debug add payload of len 32, next type 0
Apr/26/2022 15:33:08 ipsec,debug,packet begin encryption.
Apr/26/2022 15:33:08 ipsec,debug,packet encryption(aes)
Apr/26/2022 15:33:08 ipsec,debug,packet pad length = 12
Apr/26/2022 15:33:08 ipsec,debug,packet 00000024 400f4c8d ed4f72f9 730c8032 4979395b 84c1b666 0dd5dd82 7660c700
Apr/26/2022 15:33:08 ipsec,debug,packet f49e62c2 d3f29dae cad9debc efba920b
Apr/26/2022 15:33:08 ipsec,debug,packet with key:
Apr/26/2022 15:33:08 ipsec,debug,packet 6cdf485d dcc0e84f 0c354c1c 1ad13ba2 cb452609 aa860e88 37fefe35 6869ab97
Apr/26/2022 15:33:08 ipsec,debug,packet encrypted payload by IV:
Apr/26/2022 15:33:08 ipsec,debug,packet 907792aa ef1561b5 7916eb34 716fcd11
Apr/26/2022 15:33:08 ipsec,debug,packet save IV for next:
Apr/26/2022 15:33:08 ipsec,debug,packet f5304f6d 01b7f024 412537d6 855ec2bf
Apr/26/2022 15:33:08 ipsec,debug,packet encrypted.
Apr/26/2022 15:33:08 ipsec,debug 76 bytes from Local_Public_IP[500] to Remote_Public_IP[500]
Apr/26/2022 15:33:08 ipsec,debug 1 times of 76 bytes message will be sent to Remote_Public_IP[500]
Apr/26/2022 15:33:08 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08102001 e9098f9c 0000004c 8b198691
Apr/26/2022 15:33:08 ipsec,debug,packet 8ecf6706 8e55325f dd86a0ad 64ea1500 94245e52 75903311 495763f2 f5304f6d
Apr/26/2022 15:33:08 ipsec,debug,packet 01b7f024 412537d6 855ec2bf
Apr/26/2022 15:33:08 ipsec,debug,packet compute DH's shared.
Apr/26/2022 15:33:08 ipsec,debug,packet dcacc470 b4b72daf ea24258c 1b1c751f c28316ec 3d030bf8 2eaef6c9 92cfffa0
Apr/26/2022 15:33:08 ipsec,debug,packet 3f80d356 0e94e56e ea107932 c735887a 14ba4648 3f7e4068 71ee27a2 b7df2a0c
Apr/26/2022 15:33:08 ipsec,debug,packet 459aef00 1e396b27 e7aaf044 1ffa6da4 c6e397f2 2ba1f0be ee1335d2 891f5ffe
Apr/26/2022 15:33:08 ipsec,debug,packet 59791a16 2ae59544 3f1b890b 1ae75b9b 080ab62a c3c390ad 283f9c6b 1d9b1a9f
Apr/26/2022 15:33:08 ipsec,debug,packet 82f4ea35 38318650 7c84050e 523d1435 f249e696 43e8a017 53d311fe 681f7182
Apr/26/2022 15:33:08 ipsec,debug,packet 909d2b23 bea0d4e9 3a16012b 586ea7e7 9bd751de a1e1235d 8b5cc369 786c1841
Apr/26/2022 15:33:08 ipsec,debug,packet d749bf33 c6d68b33 59e9a4cf bbdae489 72ad6865 d479e481 1e14c465 cfdc5003
Apr/26/2022 15:33:08 ipsec,debug,packet d72e51b6 f8a7e1d1 644ee616 9598453e 1656adb8 f7b3b56b 6109c5bb 91b695da
Apr/26/2022 15:33:08 ipsec,debug,packet KEYMAT compute with
Apr/26/2022 15:33:08 ipsec,debug,packet 030c3c81 06b1b663 1d2092f8 2dfe06e2 2d3a5ef8 0a682488 8be97dd1 cf4cf280
Apr/26/2022 15:33:08 ipsec,debug encryption(aes-cbc)
Apr/26/2022 15:33:08 ipsec,debug hmac(hmac_sha2_256)
Apr/26/2022 15:33:08 ipsec,debug encklen=256 authklen=256
Apr/26/2022 15:33:08 ipsec,debug generating 1024 bits of key (dupkeymat=4)
Apr/26/2022 15:33:08 ipsec,debug generating K1...K4 for KEYMAT.
Apr/26/2022 15:33:08 ipsec,debug 3c566b01 8c852f20 1a658ee2 79b2f35e d1b7a31a 60988526 0e8151d0 c0a6c646
Apr/26/2022 15:33:08 ipsec,debug bf69039d bec4f8e3 8b633b93 a5d6bf3e 74cfa0fa 8fa4efb5 e8aa9498 3c02dd29
Apr/26/2022 15:33:08 ipsec,debug cfd3ff02 0dd61288 382ebdc1 f658769f 6bedd5e1 8d7bf2c7 fe563639 f0379615
Apr/26/2022 15:33:08 ipsec,debug 7d7466cd 6695963b 27132821 7b966eb6 cdd65412 d1a1b01f 1673adcb e71c544c
Apr/26/2022 15:33:08 ipsec,debug,packet 03e07c74 e6b1b663 1d2092f8 2dfe06e2 2d3a5ef8 0a682488 8be97dd1 cf4cf280
Apr/26/2022 15:33:08 ipsec,debug eb4f0ba0 98cdc69e eb9dbea1 ee0aefd9 baa74b83 70567292 26333628 d7c6f6b9
Apr/26/2022 15:33:08 ipsec,debug 2793b30b 0612bac3 111948c1 a1bbf8be e0e1b122 ff69432e e8bf57ed 6bfc8e9b
Apr/26/2022 15:33:08 ipsec,debug ae8e1d9b 5dcc08c4 759f4c60 b56cae09 91c067ec de7ea88f 3353ba80 37436f8b
Apr/26/2022 15:33:08 ipsec,debug 236fbfbc 58eb2b96 eed622b4 2afc8049 db48e283 507e52a6 fa6f099f 06e86c65
Apr/26/2022 15:33:08 ipsec,debug KEYMAT computed.
Apr/26/2022 15:33:08 ipsec,debug call pk_sendupdate
Apr/26/2022 15:33:08 ipsec,debug call pfkey_send_update_nat
Apr/26/2022 15:33:08 ipsec IPsec-SA established: ESP/Tunnel Remote_Public_IP[500]->Local_Public_IP[500] spi=0xc3c8106
Apr/26/2022 15:33:08 ipsec,debug pfkey update sent.
Apr/26/2022 15:33:08 ipsec,debug call pfkey_send_add_nat
Apr/26/2022 15:33:08 ipsec IPsec-SA established: ESP/Tunnel Local_Public_IP[500]->Remote_Public_IP[500] spi=0xe07c74e6
Apr/26/2022 15:33:08 ipsec,debug pfkey add sent.
Apr/26/2022 15:33:08 ipsec,debug ===== received 92 bytes from Remote_Public_IP[500] to Local_Public_IP[500]
Apr/26/2022 15:33:08 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08100501 633f0bc6 0000005c 5cbd6baa
Apr/26/2022 15:33:08 ipsec,debug,packet 150c9457 8429d4f4 66239f78 276aa2e1 d9c96ea6 00cc9dd2 f339785a 70669aa8
Apr/26/2022 15:33:08 ipsec,debug,packet 6d3209ed 61ffdd1d 228072c8 a3a54c1e c24e42d4 cc9b7a55 89f0438c
Apr/26/2022 15:33:08 ipsec,debug receive Information.
Apr/26/2022 15:33:08 ipsec,debug,packet compute IV for phase2
Apr/26/2022 15:33:08 ipsec,debug,packet phase1 last IV:
Apr/26/2022 15:33:08 ipsec,debug,packet 2d17e26b 9cc4917a 6e3a8b69 f55c0c83 633f0bc6
Apr/26/2022 15:33:08 ipsec,debug hash(sha2_256)
Apr/26/2022 15:33:08 ipsec,debug,packet phase2 IV computed:
Apr/26/2022 15:33:08 ipsec,debug,packet 3317a1d3 58147552 d508333c d74649d0
Apr/26/2022 15:33:08 ipsec,debug,packet IV was saved for next processing:
Apr/26/2022 15:33:08 ipsec,debug,packet a3a54c1e c24e42d4 cc9b7a55 89f0438c
Apr/26/2022 15:33:08 ipsec,debug,packet decrypted payload by IV:
Apr/26/2022 15:33:08 ipsec,debug,packet decrypted payload, but not trimed.
Apr/26/2022 15:33:08 ipsec,debug,packet 0c000024 97b78b4e 29579cac f376f082 98dc4d96 d3eb70ad 2812d60e ffd47056
Apr/26/2022 15:33:08 ipsec,debug,packet ca635eb7 00000010 00000001 03040001 e07c74e2 dcb4b4fb 9fd1506c ba55b10b
Apr/26/2022 15:33:08 ipsec,debug,packet padding len=12
Apr/26/2022 15:33:08 ipsec,debug,packet skip to trim padding.
Apr/26/2022 15:33:08 ipsec,debug,packet decrypted.
Apr/26/2022 15:33:08 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08100501 633f0bc6 0000005c 0c000024
Apr/26/2022 15:33:08 ipsec,debug,packet 97b78b4e 29579cac f376f082 98dc4d96 d3eb70ad 2812d60e ffd47056 ca635eb7
Apr/26/2022 15:33:08 ipsec,debug,packet 00000010 00000001 03040001 e07c74e2 dcb4b4fb 9fd1506c ba55b10b
Apr/26/2022 15:33:08 ipsec,debug,packet 633f0bc6 00000010 00000001 03040001 e07c74e2
Apr/26/2022 15:33:08 ipsec,debug hash validated.
Apr/26/2022 15:33:08 ipsec,debug seen nptype=8(hash) len=36
Apr/26/2022 15:33:08 ipsec,debug seen nptype=12(delete) len=16
Apr/26/2022 15:33:08 ipsec,debug Remote_Public_IP delete payload for protocol ESP
Apr/26/2022 15:33:08 ipsec purged IPsec-SA proto_id=ESP spi=0xe07c74e2
Apr/26/2022 15:33:08 ipsec purged IPsec-SA proto_id=ESP spi=0xb7e0b9d
Apr/26/2022 15:33:08 ipsec,debug purged SAs.
Apr/26/2022 15:33:08 ipsec acquire for policy: 10.60.0.0/23 <=> 10.1.1.0/24
Apr/26/2022 15:33:08 ipsec,debug (proto_id=ESP spisize=4 spi=00000000 spi_p=00000000 encmode=Tunnel reqid=5:5)
Apr/26/2022 15:33:08 ipsec,debug begin QUICK mode.
Apr/26/2022 15:33:08 ipsec initiate new phase 2 negotiation: Local_Public_IP[500]<=>Remote_Public_IP[500]
Apr/26/2022 15:33:08 ipsec,debug,packet 2d17e26b 9cc4917a 6e3a8b69 f55c0c83 b4e92cc7
Apr/26/2022 15:33:08 ipsec,debug,packet fbd33acd e87dc919 01e3d52b d8707bd0
Apr/26/2022 15:33:08 ipsec,debug call pfkey_send_getspi 5512
Apr/26/2022 15:33:08 ipsec,debug pfkey GETSPI sent: ESP/Tunnel Remote_Public_IP[500]->Local_Public_IP[500]
Apr/26/2022 15:33:08 ipsec,debug pfkey getspi sent.
Apr/26/2022 15:33:08 ipsec,debug,packet compute DH's private.
Apr/26/2022 15:33:08 ipsec,debug,packet 6271e503 8c79475d 8bd52f95 7675b758 76ecfd39 3cdacf91 7da4fd6a 8a2e8f30
Apr/26/2022 15:33:08 ipsec,debug,packet b39a6cb5 94f95b77 ec543478 1647efc4 c0cf71f2 7886a5db 04f59267 26c0a107
Apr/26/2022 15:33:08 ipsec,debug,packet 82e5d35d 63d083e2 a24f28e3 82b643a9 1c71cfc5 d71a2586 be55d739 77a25175
Apr/26/2022 15:33:08 ipsec,debug,packet 1dd29c9f 1da132f0 a37851a6 66fd1ce1 64c98575 d8efc97e 28690993 2d90eb34
Apr/26/2022 15:33:08 ipsec,debug,packet f9664453 94d3c80c 1cfe7ad9 b6259d0d 20e12f0c 352f0429 5c34ab13 144665db
Apr/26/2022 15:33:08 ipsec,debug,packet 27a78008 e4cc1908 2ebc9888 9ab7b62a 2ed6b081 e0d568ef bb112f8d f6566ad3
Apr/26/2022 15:33:08 ipsec,debug,packet d7ddc91b a0660c6c 7af96fb6 dc3610e0 64f3cb11 4e689c01 8d67e661 226a02e4
Apr/26/2022 15:33:08 ipsec,debug,packet eff9a2d3 05e26288 e3331f77 0bb7a016 17beb2d3 8e484a87 6b1d3cea 304285a5
Apr/26/2022 15:33:08 ipsec,debug,packet compute DH's public.
Apr/26/2022 15:33:08 ipsec,debug,packet eb7cea3c 2854cc05 0e6cb2e9 43dc8916 1f9202a1 d5a2f3a4 426802e3 effd9896
Apr/26/2022 15:33:08 ipsec,debug,packet fa87fe17 f70ecdc6 c1e6f486 9568135d 5fab48a0 5cf508f6 c2522e0c 3e383804
Apr/26/2022 15:33:08 ipsec,debug,packet 12328138 a74bd745 b5fe2d55 371bae99 425751f9 fff87cab a01278f3 fbda58ac
Apr/26/2022 15:33:08 ipsec,debug,packet acafc7a7 55c81448 f3c533f4 d644cd33 f07f8866 35fcde4a cbd3aea7 1d6d0ef4
Apr/26/2022 15:33:08 ipsec,debug,packet c764c211 698be59b 348ad3ad e6f36fc4 8ac7b310 1a539883 3c309282 4e3a4a0d
Apr/26/2022 15:33:08 ipsec,debug,packet 9ed6bbfa fca33f28 f27cdefc 1c95a590 b5da9c58 d15338bc 9b5ff651 1aed67a2
Apr/26/2022 15:33:08 ipsec,debug,packet b5340b4c ead6b578 275a1e15 7ed03c6f 34931cd5 9d3e39cf 2bfc3914 26763fdb
Apr/26/2022 15:33:08 ipsec,debug,packet fe87cf0a 0ff3253d 4025db82 5cef6c5c 1a0e9b93 8d90823f c1330bf6 ad3615f6
Apr/26/2022 15:33:08 ipsec,debug use local ID type IPv4_subnet
Apr/26/2022 15:33:08 ipsec,debug use remote ID type IPv4_subnet
Apr/26/2022 15:33:08 ipsec,debug IDci:
Apr/26/2022 15:33:08 ipsec,debug 04000000 0a3c0000 fffffe00
Apr/26/2022 15:33:08 ipsec,debug IDcr:
Apr/26/2022 15:33:08 ipsec,debug 04000000 0a010100 ffffff00
Apr/26/2022 15:33:08 ipsec,debug add payload of len 56, next type 10
Apr/26/2022 15:33:08 ipsec,debug add payload of len 24, next type 4
Apr/26/2022 15:33:08 ipsec,debug add payload of len 256, next type 5
Apr/26/2022 15:33:08 ipsec,debug add payload of len 12, next type 5
Apr/26/2022 15:33:08 ipsec,debug add payload of len 12, next type 0
Apr/26/2022 15:33:08 ipsec,debug,packet b4e92cc7 0a00003c 00000001 00000001 00000030 01030401 0bf63321 00000024
Apr/26/2022 15:33:08 ipsec,debug,packet 010c0000 80010001 00020004 00015180 80040001 80060100 80050005 8003000e
Apr/26/2022 15:33:08 ipsec,debug,packet 0400001c c6a9daf7 9ddcec14 46fe9227 599f559e 28a33ccd f71d1082 05000104
Apr/26/2022 15:33:08 ipsec,debug,packet 05000010 04000000 0a3c0000 fffffe00 00000010 04000000 0a010100 ffffff00
Apr/26/2022 15:33:08 ipsec,debug,packet fd41b3f0 6a59ed81 2e2b8101 6043225e ffc50a5b c4974845 7f4ba654 95ac48f4
Apr/26/2022 15:33:08 ipsec,debug add payload of len 32, next type 1
Apr/26/2022 15:33:08 ipsec,debug,packet pad length = 16
Apr/26/2022 15:33:08 ipsec,debug,packet 01000024 fd41b3f0 6a59ed81 2e2b8101 6043225e ffc50a5b c4974845 7f4ba654
Apr/26/2022 15:33:08 ipsec,debug,packet 95ac48f4 0a00003c 00000001 00000001 00000030 01030401 0bf63321 00000024
Apr/26/2022 15:33:08 ipsec,debug,packet a0aaceee fecfb3cc 9bd4b1c5 d7d2a50f
Apr/26/2022 15:33:08 ipsec,debug,packet d873969f 8c073f59 a371f955 f309bc77
Apr/26/2022 15:33:08 ipsec,debug 460 bytes from Local_Public_IP[500] to Remote_Public_IP[500]
Apr/26/2022 15:33:08 ipsec,debug 1 times of 460 bytes message will be sent to Remote_Public_IP[500]
Apr/26/2022 15:33:08 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08102001 b4e92cc7 000001cc 550e9d0a
Apr/26/2022 15:33:08 ipsec,debug,packet e49b8d6d d3cc9cc9 d103476f f22ec4ee 31600769 ab39ec54 4d97f1c9 202ccbd2
Apr/26/2022 15:33:08 ipsec,debug,packet 32595478 a8f939c7 14dec1d4 4e1be353 b4f136d7 4b89f817 fa892a89 94db7942
Apr/26/2022 15:33:08 ipsec,debug,packet b9a7c6f7 f0bd0523 3a03af0b 5df9da89 87ec7fc0 a19a4651 f6ffe0d9 90ebb980
Apr/26/2022 15:33:08 ipsec,debug,packet f4a710dc ba0b6375 b724c066 b9367260 71803dfb 7524a16b 138356a0 bf7563c8
Apr/26/2022 15:33:08 ipsec,debug,packet 67873dfe 85c1ee73 6edba220 de7d9484 77828216 d138d5eb 8e67c36a 646a2abe
Apr/26/2022 15:33:08 ipsec,debug,packet 736edaa8 d004c771 ecc701c6 0a0d7e8e 43204169 1adc3427 3a58c6e6 4b949801
Apr/26/2022 15:33:08 ipsec,debug,packet 3a911537 99f8de62 98d3e0c6 833bd461 b9942b0d 9356f252 2203866d 6c8a1406
Apr/26/2022 15:33:08 ipsec,debug,packet ebdc3b47 f0f7c284 101e7345 ed7fcbd3 d3b47172 a105e565 b41c8e62 9d497415
Apr/26/2022 15:33:08 ipsec,debug,packet 2907ae8a b85ca792 ddffeb4c 93e84f78 01bea46e 0ee6f3d2 652840bb 76668763
Apr/26/2022 15:33:08 ipsec,debug,packet 0c19ad50 6f2f12b0 80592864 54cedcb7 f8592c59 32d930ff 8a294ea0 c9fc2640
Apr/26/2022 15:33:08 ipsec,debug,packet 86001379 bdd0bc1a 7a73ec87 f36b9e27 71e167ee 09181909 55321de5 cff69ca5
Apr/26/2022 15:33:08 ipsec,debug,packet 69221e16 b7c990a2 ea9a3de7 b9dd15ba 164ec54e a1185ad7 0ef789c0 1dff3c01
Apr/26/2022 15:33:08 ipsec,debug,packet d7a0cbf3 57b43665 17d3d3b7 bf48baaf f1a24f9b 9432fad2 152d7927 d873969f
Apr/26/2022 15:33:08 ipsec,debug,packet 8c073f59 a371f955 f309bc77
Apr/26/2022 15:33:08 ipsec sent phase2 packet Local_Public_IP[500]<=>Remote_Public_IP[500] 51e8e9ce0eb406ee:98bd391ef8c866c3:0000b4e9
Apr/26/2022 15:33:08 ipsec,debug ===== received 476 bytes from Remote_Public_IP[500] to Local_Public_IP[500]
Apr/26/2022 15:33:08 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08102001 b4e92cc7 000001dc 36d7bf1d
Apr/26/2022 15:33:08 ipsec,debug,packet 4eb4b4ce f905d95a 6a39ed2d 594cfaf1 7f33aefb 3ef9a8b8 ce604b0b 79fcc511
Apr/26/2022 15:33:08 ipsec,debug,packet 0c490b3d 8fc78ce5 a87f151d 36bd69a4 ab741bea e473c3bb 475c07d6 6d0bdb57
Apr/26/2022 15:33:08 ipsec,debug,packet f2400225 adbfae09 839515c9 1526f99f 0ec70106 aa0b3c83 5050f058 1fed546e
Apr/26/2022 15:33:08 ipsec,debug,packet 3e47bbe3 b6efbde2 f2289523 6197e183 b2781c23 f65f1029 b36c9852 efdc03c2
Apr/26/2022 15:33:08 ipsec,debug,packet b3417e1f 9c5973ed cc603d03 a0190421 d04aad90 77d3c382 397e9f03 a090bd91
Apr/26/2022 15:33:08 ipsec,debug,packet 552a56b4 75b216a8 c6a5e7e0 40924210 453431e0 7121a945 06b56645 5fc10482
Apr/26/2022 15:33:08 ipsec,debug,packet c6ce1ee6 eea73bd1 1061a27a f378f07c 87d34bcb c859acc1 3eddf117 59e3b613
Apr/26/2022 15:33:08 ipsec,debug,packet 5619d8c7 7cc5b4f7 1165216c 747d11b1 4a3e0833 af12cfe0 86ec2cb1 55869448
Apr/26/2022 15:33:08 ipsec,debug,packet 723663b2 2b0fa47d 7a018389 05cf4a22 d0ad0cb2 8d99ba4b 27dfefbc 5728ca96
Apr/26/2022 15:33:08 ipsec,debug,packet 4ffbb27f ce108a09 960bd31f 88e4dbd1 13405cd0 33d300a5 a556efe9 7f59ff30
Apr/26/2022 15:33:08 ipsec,debug,packet 0f4ceaef b2625149 6856b1c8 7e411042 43e25832 4a4c273c 219ae54a d0853214
Apr/26/2022 15:33:08 ipsec,debug,packet 9a14026b dce4b972 560f10f9 c408a683 c620c43a e5d81a06 2a07cb18 c4ee062c
Apr/26/2022 15:33:08 ipsec,debug,packet c34961b4 0a2904ce ff484a13 a048ea3f 63b28bb0 f82f9192 53bc1b68 0b7a1103
Apr/26/2022 15:33:08 ipsec,debug,packet c123f437 9899e303 88bba170 4ff31047 9cfe8ac3 b8336874 b83828f1
Apr/26/2022 15:33:08 ipsec,debug,packet 4ff31047 9cfe8ac3 b8336874 b83828f1
Apr/26/2022 15:33:08 ipsec,debug,packet 01000024 128dbfd5 a1b3cdff 6cad0efe cd983aeb f8b7994b e25984a2 7964df42
Apr/26/2022 15:33:08 ipsec,debug,packet 0fc5b75a 0a00003c 00000001 00000001 00000030 01030401 e07c74e7 00000024
Apr/26/2022 15:33:08 ipsec,debug,packet 04000014 63c66f6e 8b7cc01f 9748b751 1f4210f4 05000104 c65e8cc4 a1e516ad
Apr/26/2022 15:33:08 ipsec,debug,packet 23501b88 90e71ccd 7f711e8f 10b4550e 843c03d7 f34b10c5 d0ca5da0 a65b2624
Apr/26/2022 15:33:08 ipsec,debug,packet 47b8f4f4 a648075d 3e475e2d e0aa2524 b7a9d89d 0dafe00c 2c6c44de b16f3eb6
Apr/26/2022 15:33:08 ipsec,debug,packet 0017ac17 b4fd210b 7907c8df bed03f8a bb3fbe7e 14113237 bff77007 680085d0
Apr/26/2022 15:33:08 ipsec,debug,packet c1613aa2 24c2dfdf 6940801c 1a0bd8b9 1277aba4 7dfa9707 92c87582 171cce01
Apr/26/2022 15:33:08 ipsec,debug,packet 94f026d5 b0918edb 3a31435d d42460ff 8335151c fa5d8e5a ee92eec3 13437b0e
Apr/26/2022 15:33:08 ipsec,debug,packet 37aeae84 2c7bb382 cce9eb91 cc7aabc0 b34f6432 9a322595 60351ceb 5964fb33
Apr/26/2022 15:33:08 ipsec,debug,packet e8c078d7 86824fae 3219bf8c deb8a404 f3461f2c c63facaf 56a26776 1f0d5de7
Apr/26/2022 15:33:08 ipsec,debug,packet c7842bb7 c80dda96 fc04f076 a7aadccc 51761ae4 b8fd8f2f 05000010 04000000
Apr/26/2022 15:33:08 ipsec,debug,packet 0a3c0000 fffffe00 0b000010 04000000 0a010100 ffffff00 0000001c 00000001
Apr/26/2022 15:33:08 ipsec,debug,packet 03046000 e07c74e7 80010001 00020004 0000a8c0 76ab7c20 c2a40057 e1d19d0b
Apr/26/2022 15:33:08 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08102001 b4e92cc7 000001dc 01000024
Apr/26/2022 15:33:08 ipsec,debug,packet 128dbfd5 a1b3cdff 6cad0efe cd983aeb f8b7994b e25984a2 7964df42 0fc5b75a
Apr/26/2022 15:33:08 ipsec,debug,packet 0a00003c 00000001 00000001 00000030 01030401 e07c74e7 00000024 010c0000
Apr/26/2022 15:33:08 ipsec,debug,packet 80010001 00020004 00015180 80040001 80060100 80050005 8003000e 04000014
Apr/26/2022 15:33:08 ipsec,debug,packet 63c66f6e 8b7cc01f 9748b751 1f4210f4 05000104 c65e8cc4 a1e516ad 23501b88
Apr/26/2022 15:33:08 ipsec,debug,packet 90e71ccd 7f711e8f 10b4550e 843c03d7 f34b10c5 d0ca5da0 a65b2624 47b8f4f4
Apr/26/2022 15:33:08 ipsec,debug,packet a648075d 3e475e2d e0aa2524 b7a9d89d 0dafe00c 2c6c44de b16f3eb6 0017ac17
Apr/26/2022 15:33:08 ipsec,debug,packet b4fd210b 7907c8df bed03f8a bb3fbe7e 14113237 bff77007 680085d0 c1613aa2
Apr/26/2022 15:33:08 ipsec,debug,packet 24c2dfdf 6940801c 1a0bd8b9 1277aba4 7dfa9707 92c87582 171cce01 94f026d5
Apr/26/2022 15:33:08 ipsec,debug,packet b0918edb 3a31435d d42460ff 8335151c fa5d8e5a ee92eec3 13437b0e 37aeae84
Apr/26/2022 15:33:08 ipsec,debug,packet 2c7bb382 cce9eb91 cc7aabc0 b34f6432 9a322595 60351ceb 5964fb33 e8c078d7
Apr/26/2022 15:33:08 ipsec,debug,packet 86824fae 3219bf8c deb8a404 f3461f2c c63facaf 56a26776 1f0d5de7 c7842bb7
Apr/26/2022 15:33:08 ipsec,debug,packet c80dda96 fc04f076 a7aadccc 51761ae4 b8fd8f2f 05000010 04000000 0a3c0000
Apr/26/2022 15:33:08 ipsec,debug,packet fffffe00 0b000010 04000000 0a010100 ffffff00 0000001c 00000001 03046000
Apr/26/2022 15:33:08 ipsec,debug,packet e07c74e7 80010001 00020004 0000a8c0 76ab7c20 c2a40057 e1d19d0b
Apr/26/2022 15:33:08 ipsec,debug seen nptype=1(sa) len=60
Apr/26/2022 15:33:08 ipsec,debug seen nptype=10(nonce) len=20
Apr/26/2022 15:33:08 ipsec,debug seen nptype=4(ke) len=260
Apr/26/2022 15:33:08 ipsec,debug seen nptype=5(id) len=16
Apr/26/2022 15:33:08 ipsec,debug seen nptype=11(notify) len=28
Apr/26/2022 15:33:08 ipsec,debug Remote_Public_IP Notify Message received
Apr/26/2022 15:33:08 ipsec Remote_Public_IP ignore RESPONDER-LIFETIME notification.
Apr/26/2022 15:33:08 ipsec,debug IDci matches proposal.
Apr/26/2022 15:33:08 ipsec,debug IDcr matches proposal.
Apr/26/2022 15:33:08 ipsec,debug HASH allocated:hbuf->l=472 actual:tlen=424
Apr/26/2022 15:33:08 ipsec,debug HASH(2) received:
Apr/26/2022 15:33:08 ipsec,debug 128dbfd5 a1b3cdff 6cad0efe cd983aeb f8b7994b e25984a2 7964df42 0fc5b75a
Apr/26/2022 15:33:08 ipsec,debug,packet b4e92cc7 c6a9daf7 9ddcec14 46fe9227 599f559e 28a33ccd f71d1082 0a00003c
Apr/26/2022 15:33:08 ipsec,debug,packet 00000001 00000001 00000030 01030401 e07c74e7 00000024 010c0000 80010001
Apr/26/2022 15:33:08 ipsec,debug,packet 00020004 00015180 80040001 80060100 80050005 8003000e 04000014 63c66f6e
Apr/26/2022 15:33:08 ipsec,debug,packet 8b7cc01f 9748b751 1f4210f4 05000104 c65e8cc4 a1e516ad 23501b88 90e71ccd
Apr/26/2022 15:33:08 ipsec,debug,packet 7f711e8f 10b4550e 843c03d7 f34b10c5 d0ca5da0 a65b2624 47b8f4f4 a648075d
Apr/26/2022 15:33:08 ipsec,debug,packet 3e475e2d e0aa2524 b7a9d89d 0dafe00c 2c6c44de b16f3eb6 0017ac17 b4fd210b
Apr/26/2022 15:33:08 ipsec,debug,packet 7907c8df bed03f8a bb3fbe7e 14113237 bff77007 680085d0 c1613aa2 24c2dfdf
Apr/26/2022 15:33:08 ipsec,debug,packet 6940801c 1a0bd8b9 1277aba4 7dfa9707 92c87582 171cce01 94f026d5 b0918edb
Apr/26/2022 15:33:08 ipsec,debug,packet 3a31435d d42460ff 8335151c fa5d8e5a ee92eec3 13437b0e 37aeae84 2c7bb382
Apr/26/2022 15:33:08 ipsec,debug,packet cce9eb91 cc7aabc0 b34f6432 9a322595 60351ceb 5964fb33 e8c078d7 86824fae
Apr/26/2022 15:33:08 ipsec,debug,packet 3219bf8c deb8a404 f3461f2c c63facaf 56a26776 1f0d5de7 c7842bb7 c80dda96
Apr/26/2022 15:33:08 ipsec,debug,packet fc04f076 a7aadccc 51761ae4 b8fd8f2f 05000010 04000000 0a3c0000 fffffe00
Apr/26/2022 15:33:08 ipsec,debug,packet 0b000010 04000000 0a010100 ffffff00 0000001c 00000001 03046000 e07c74e7
Apr/26/2022 15:33:08 ipsec,debug,packet 80010001 00020004 0000a8c0
Apr/26/2022 15:33:08 ipsec,debug 00000001 00000001 00000030 01030401 0bf63321 00000024 010c0000 80010001
Apr/26/2022 15:33:08 ipsec,debug 0x468f20: next=0 tnext=0
Apr/26/2022 15:33:08 ipsec,debug 00000001 00000001 00000030 01030401 e07c74e7 00000024 010c0000 80010001
Apr/26/2022 15:33:08 ipsec,debug 0x468f40: next=0 tnext=0
Apr/26/2022 15:33:08 ipsec,debug pair[1]: 0x468f40
Apr/26/2022 15:33:08 ipsec,debug (proto_id=ESP spisize=4 spi=e07c74e7 spi_p=00000000 encmode=Tunnel reqid=0:0)
Apr/26/2022 15:33:08 ipsec,debug (proto_id=ESP spisize=4 spi=0bf63321 spi_p=00000000 encmode=Tunnel reqid=5:5)
Apr/26/2022 15:33:08 ipsec,debug,packet 00b4e92c c7c6a9da f79ddcec 1446fe92 27599f55 9e28a33c cdf71d10 8263c66f
Apr/26/2022 15:33:08 ipsec,debug,packet 6e8b7cc0 1f9748b7 511f4210 f4
Apr/26/2022 15:33:08 ipsec,debug,packet 23fdfd29 ba274cfb f8106227 794d6ac4 3ba48fde a55f9dfc 3630ed6c b42590ea
Apr/26/2022 15:33:08 ipsec,debug,packet 00000024 23fdfd29 ba274cfb f8106227 794d6ac4 3ba48fde a55f9dfc 3630ed6c
Apr/26/2022 15:33:08 ipsec,debug,packet b42590ea cbfb82c8 a6f5c2e4 a8e2dd0b
Apr/26/2022 15:33:08 ipsec,debug,packet eceecc84 eedc82d0 b8ba12ae 76dbb296
Apr/26/2022 15:33:08 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08102001 b4e92cc7 0000004c d6c5f772
Apr/26/2022 15:33:08 ipsec,debug,packet af66be91 2e97d0c1 f50a1a43 6c1d6ae5 d2f17571 5746f9c2 3d75e0ac eceecc84
Apr/26/2022 15:33:08 ipsec,debug,packet eedc82d0 b8ba12ae 76dbb296
Apr/26/2022 15:33:08 ipsec,debug,packet 730ac383 153a6dc0 9b735adb 6378da6f 2b09b50d 381161dc 80cbab25 319ec115
Apr/26/2022 15:33:08 ipsec,debug,packet 042e64c3 bf3478ce 683a742e c6f7993a 61fdc3d3 1a81860b 782b38ee 4448a6f4
Apr/26/2022 15:33:08 ipsec,debug,packet d3747e2e 5db410d6 df7fb24f 543ce112 27e4baf2 0b30eee5 bd8fd561 44f7b6de
Apr/26/2022 15:33:08 ipsec,debug,packet 0d17e276 5d8dd3e7 735c2fb7 c9ccd28f 593e7646 ae7e0e54 39d658d3 3995e0fa
Apr/26/2022 15:33:08 ipsec,debug,packet 2f1a1a6d 58aa4653 2aa5c4ce 24523c00 e1ee495a 4892e311 7c8b3143 1b113fa7
Apr/26/2022 15:33:08 ipsec,debug,packet 240807d3 9f59e3aa c9bfeb2f 8083ead0 fbd45dc9 26542abf 50f5e848 f67a59ad
Apr/26/2022 15:33:08 ipsec,debug,packet 506be419 6f69251a 4cdfcb4a e9654785 9be486ea ffe29644 cd1de47f 1bf2cbc1
Apr/26/2022 15:33:08 ipsec,debug,packet d4007a8e fb37387d 86a934c3 15e49e7e 20b05ae9 e09c9f78 b4bfc74f 7e8f417f
Apr/26/2022 15:33:08 ipsec,debug,packet 030bf633 21c6a9da f79ddcec 1446fe92 27599f55 9e28a33c cdf71d10 8263c66f
Apr/26/2022 15:33:08 ipsec,debug d392114c 7f5a1a3f 30dc788f c9f83b7f 531bae0e 021d5cc0 72b8ad1c de63d254
Apr/26/2022 15:33:08 ipsec,debug a2b3981a 70abfef2 c23cb541 b422107d 03089022 57de2c3f 9766a2ec 466f06dd
Apr/26/2022 15:33:08 ipsec,debug de245e9b e3f657c2 49e7b54d d9ca21f2 bd415a56 87c07938 8fea32f5 fe14d764
Apr/26/2022 15:33:08 ipsec,debug ef8cb06c 842db86e 8aa56898 6d873aca 1a376db6 792c1fa3 6c42c07b ae9f3698
Apr/26/2022 15:33:08 ipsec,debug,packet 03e07c74 e7c6a9da f79ddcec 1446fe92 27599f55 9e28a33c cdf71d10 8263c66f
Apr/26/2022 15:33:08 ipsec,debug 59e59bec 3079bc60 df5e2242 e20bc029 1b564fae a2cf3ac3 196ff194 89516c2f
Apr/26/2022 15:33:08 ipsec,debug fe0986af b1b02ea1 1032ad00 f97a31b3 50a36a62 ba64c1c4 9c19024b c3c9cc02
Apr/26/2022 15:33:08 ipsec,debug 37fc6c73 320f620d 5fca6fe5 c4270263 5bca2be5 19b7b70c 96651db1 9ce030a7
Apr/26/2022 15:33:08 ipsec,debug 661ae2ec fd3e151b f1891203 477f45b2 0388486f 0fd390ca a1ef3118 431461bf
Apr/26/2022 15:33:08 ipsec IPsec-SA established: ESP/Tunnel Remote_Public_IP[500]->Local_Public_IP[500] spi=0xbf63321
Apr/26/2022 15:33:08 ipsec IPsec-SA established: ESP/Tunnel Local_Public_IP[500]->Remote_Public_IP[500] spi=0xe07c74e7
Apr/26/2022 15:33:08 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08100501 4f045b8e 0000005c 85246b2c
Apr/26/2022 15:33:08 ipsec,debug,packet 5abcd9e9 78141f14 72e151d5 3b8de0e7 80775105 eadda306 684bbe3e 0327596b
Apr/26/2022 15:33:08 ipsec,debug,packet c9efdd5d 48fc7f5c b0fd6a86 a52ca3ff 9f8d4559 6965b490 bd7e4172
Apr/26/2022 15:33:08 ipsec,debug,packet 2d17e26b 9cc4917a 6e3a8b69 f55c0c83 4f045b8e
Apr/26/2022 15:33:08 ipsec,debug,packet 224905e6 2b81294e 1e560187 c112966e
Apr/26/2022 15:33:08 ipsec,debug,packet a52ca3ff 9f8d4559 6965b490 bd7e4172
Apr/26/2022 15:33:08 ipsec,debug,packet 0c000024 0e0199b3 a61ec7e7 0cfcebb1 f08431f0 27ead576 74df415c b4f1260e
Apr/26/2022 15:33:08 ipsec,debug,packet 70193138 00000010 00000001 03040001 e07c74e3 0dd21f1d ee93f9ed 83251e0b
Apr/26/2022 15:33:08 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08100501 4f045b8e 0000005c 0c000024
Apr/26/2022 15:33:08 ipsec,debug,packet 0e0199b3 a61ec7e7 0cfcebb1 f08431f0 27ead576 74df415c b4f1260e 70193138
Apr/26/2022 15:33:08 ipsec,debug,packet 00000010 00000001 03040001 e07c74e3 0dd21f1d ee93f9ed 83251e0b
Apr/26/2022 15:33:08 ipsec,debug,packet 4f045b8e 00000010 00000001 03040001 e07c74e3
Apr/26/2022 15:33:08 ipsec purged IPsec-SA proto_id=ESP spi=0xe07c74e3
Apr/26/2022 15:33:08 ipsec purged IPsec-SA proto_id=ESP spi=0xb7ca6e6
Apr/26/2022 15:33:12 ipsec acquire for policy: 192.168.1.0/24 <=> 10.21.20.0/24
Apr/26/2022 15:33:12 ipsec,debug (proto_id=ESP spisize=4 spi=00000000 spi_p=00000000 encmode=Tunnel reqid=11:11)
Apr/26/2022 15:33:12 ipsec,debug (trns_id=AES-CBC encklen=256 authtype=hmac-sha256)
Apr/26/2022 15:33:12 ipsec,debug begin QUICK mode.
Apr/26/2022 15:33:12 ipsec,debug ===
Apr/26/2022 15:33:12 ipsec initiate new phase 2 negotiation: Local_Public_IP[500]<=>Remote_Public_IP[500]
Apr/26/2022 15:33:12 ipsec,debug,packet compute IV for phase2
Apr/26/2022 15:33:12 ipsec,debug,packet phase1 last IV:
Apr/26/2022 15:33:12 ipsec,debug,packet 2d17e26b 9cc4917a 6e3a8b69 f55c0c83 f9d74543
Apr/26/2022 15:33:12 ipsec,debug hash(sha2_256)
Apr/26/2022 15:33:12 ipsec,debug,packet encryption(aes)
Apr/26/2022 15:33:12 ipsec,debug,packet phase2 IV computed:
Apr/26/2022 15:33:12 ipsec,debug,packet 135df574 6e3efbc1 75692672 b71c4aad
Apr/26/2022 15:33:12 ipsec,debug call pfkey_send_getspi 5513
Apr/26/2022 15:33:12 ipsec,debug pfkey GETSPI sent: ESP/Tunnel Remote_Public_IP[500]->Local_Public_IP[500]
Apr/26/2022 15:33:12 ipsec,debug pfkey getspi sent.
Apr/26/2022 15:33:12 ipsec,debug dh(modp2048)
Apr/26/2022 15:33:12 ipsec,debug,packet compute DH's private.
Apr/26/2022 15:33:12 ipsec,debug,packet 54b05f6f 06c7160e 59cd71a9 03184df9 6ca1f8ba af0553ab 8cd1189b ca38726c
Apr/26/2022 15:33:12 ipsec,debug,packet 5fc830f4 cdda7d28 14d380c9 09756f48 3f77609b 1a7095bb 038c0f08 19efe90b
Apr/26/2022 15:33:12 ipsec,debug,packet d4bc8907 12b04da1 4c70ecb8 131f96fb 81463b41 ab05850d cd447b5c 5e6c3707
Apr/26/2022 15:33:12 ipsec,debug,packet 9018c6cd d0f6e12f a53c2536 9bf05bc9 7ff1db8d d18a1474 111765e8 528720ec
Apr/26/2022 15:33:12 ipsec,debug,packet 64a0a134 a918b2f9 8e352a43 8eb01b5a b488d3e6 e91408da e5afe88a 52cb186f
Apr/26/2022 15:33:12 ipsec,debug,packet f4308f71 acc7d54f 616c5286 a9c6ed84 e61c21e7 14a5a77a 04ae4f29 184fa7ec
Apr/26/2022 15:33:12 ipsec,debug,packet ba138225 2abad604 24a71359 0b9028fb 176ed2ca a0c590f3 13084859 b944e34b
Apr/26/2022 15:33:12 ipsec,debug,packet dbe3a072 55c9ef6f 4422ccf7 31f669c1 4d8ec9c7 557b0e77 90274023 e2eb3903
Apr/26/2022 15:33:12 ipsec,debug,packet compute DH's public.
Apr/26/2022 15:33:12 ipsec,debug,packet e4d800c9 1deab569 b6fbd74e d4157125 7fb6b3b3 5362b4bf c4fb0bae b4710aaf
Apr/26/2022 15:33:12 ipsec,debug,packet 164e35fe 6a098b3c 178a025d bfb75b95 e03bc4ed f39eb1bd 2ca0bd9b 15c870b8
Apr/26/2022 15:33:12 ipsec,debug,packet 4e1dfda4 9a3f787e f19c51fd 25d22202 f3ccbc78 41154af0 0b69850a 1253def7
Apr/26/2022 15:33:12 ipsec,debug,packet 4b230e94 40d958ff fe9d9cd0 d771662e 4dc89ee6 63cbac44 d26d4718 7a52d0a9
Apr/26/2022 15:33:12 ipsec,debug,packet b392e6ee ced2a5bd ed0191f9 8b5d0b41 5f6223e0 34cecd17 0f6effbc 8da9a32d
Apr/26/2022 15:33:12 ipsec,debug,packet a386a965 d0b9208e 4c948b22 dc7c62c9 03b899ce 790e2c8b 195f68b3 e79f3053
Apr/26/2022 15:33:12 ipsec,debug,packet 728e0230 ffa4036b f95590cc a56512c2 1d090302 39e88ebc 1095ac1e 2ef76844
Apr/26/2022 15:33:12 ipsec,debug,packet f5f1e14c 2ae35c27 1de3727d e3150487 37229def 84f67f17 755694b3 74b60a9e
Apr/26/2022 15:33:12 ipsec,debug use local ID type IPv4_subnet
Apr/26/2022 15:33:12 ipsec,debug use remote ID type IPv4_subnet
Apr/26/2022 15:33:12 ipsec,debug IDci:
Apr/26/2022 15:33:12 ipsec,debug 04000000 c0a80100 ffffff00
Apr/26/2022 15:33:12 ipsec,debug IDcr:
Apr/26/2022 15:33:12 ipsec,debug 04000000 0a151400 ffffff00
Apr/26/2022 15:33:12 ipsec,debug add payload of len 56, next type 10
Apr/26/2022 15:33:12 ipsec,debug add payload of len 24, next type 4
Apr/26/2022 15:33:12 ipsec,debug add payload of len 256, next type 5
Apr/26/2022 15:33:12 ipsec,debug add payload of len 12, next type 5
Apr/26/2022 15:33:12 ipsec,debug add payload of len 12, next type 0
Apr/26/2022 15:33:12 ipsec,debug,packet HASH with:
Apr/26/2022 15:33:12 ipsec,debug,packet f9d74543 0a00003c 00000001 00000001 00000030 01030401 06e3239b 00000024
Apr/26/2022 15:33:12 ipsec,debug,packet 010c0000 80010001 00020004 00015180 80040001 80060100 80050005 8003000e
Apr/26/2022 15:33:12 ipsec,debug,packet 0400001c ac9f93fe 27ed240c 9356469f 4553151d 59a9bb02 e7236990 05000104
Apr/26/2022 15:33:12 ipsec,debug,packet 05000010 04000000 c0a80100 ffffff00 00000010 04000000 0a151400 ffffff00
Apr/26/2022 15:33:12 ipsec,debug,packet hmac(hmac_sha2_256)
Apr/26/2022 15:33:12 ipsec,debug,packet HASH computed:
Apr/26/2022 15:33:12 ipsec,debug,packet 7005297f d81effda 470286d9 2cd68aee 34a8d2b3 cfd1365b d589fcbb 97630031
Apr/26/2022 15:33:12 ipsec,debug add payload of len 32, next type 1
Apr/26/2022 15:33:12 ipsec,debug,packet begin encryption.
Apr/26/2022 15:33:12 ipsec,debug,packet pad length = 16
Apr/26/2022 15:33:12 ipsec,debug,packet 01000024 7005297f d81effda 470286d9 2cd68aee 34a8d2b3 cfd1365b d589fcbb
Apr/26/2022 15:33:12 ipsec,debug,packet 97630031 0a00003c 00000001 00000001 00000030 01030401 06e3239b 00000024
Apr/26/2022 15:33:12 ipsec,debug,packet b8e4ff86 dfd5c690 e4dd8583 a4f3ad0f
Apr/26/2022 15:33:12 ipsec,debug,packet with key:
Apr/26/2022 15:33:12 ipsec,debug,packet 6cdf485d dcc0e84f 0c354c1c 1ad13ba2 cb452609 aa860e88 37fefe35 6869ab97
Apr/26/2022 15:33:12 ipsec,debug,packet encrypted payload by IV:
Apr/26/2022 15:33:12 ipsec,debug,packet save IV for next:
Apr/26/2022 15:33:12 ipsec,debug,packet cc423416 2166325a 244860bc 327120fb
Apr/26/2022 15:33:12 ipsec,debug,packet encrypted.
Apr/26/2022 15:33:12 ipsec,debug 460 bytes from Local_Public_IP[500] to Remote_Public_IP[500]
Apr/26/2022 15:33:12 ipsec,debug 1 times of 460 bytes message will be sent to Remote_Public_IP[500]
Apr/26/2022 15:33:12 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08102001 f9d74543 000001cc e976daab
Apr/26/2022 15:33:12 ipsec,debug,packet 8b53e4d9 83b969cd 745a2947 2160d800 b5b2de60 78203c0c dcb0599e 20f048eb
Apr/26/2022 15:33:12 ipsec,debug,packet 8ee756b7 f33571d1 59ae3586 66ea06d4 749d750f ff917898 48ab3fe7 c6d1475d
Apr/26/2022 15:33:12 ipsec,debug,packet 9de0e168 6cb3752a 3c9ade14 c7dc44a7 d5c0dae5 06a91b04 5ae07399 51844f7a
Apr/26/2022 15:33:12 ipsec,debug,packet 7aaabda1 82f72dd5 b0308714 c72175b8 6905bfa8 7b008681 ad3112cd e1392572
Apr/26/2022 15:33:12 ipsec,debug,packet 65c86585 2e1983b3 677d05c4 1f2d4172 2f9514ad 8a5c7c74 c1e088b6 9251a6c6
Apr/26/2022 15:33:12 ipsec,debug,packet d1a186dc a5e23c16 00a4e6e9 f1335bd6 508ef7ff 0273b9c8 83566319 5e3b513f
Apr/26/2022 15:33:12 ipsec,debug,packet ce7adb96 c98c6537 21932866 56cf60a6 73a63f2c f65036fa 6e89cde7 3abe5a57
Apr/26/2022 15:33:12 ipsec,debug,packet ccac871b 2969757c 6929a8b9 05dc9c43 c611fa4a 0d540640 9689c140 154cfa60
Apr/26/2022 15:33:12 ipsec,debug,packet 7078216e a7e6662f 24eaa0bf 991b0832 cade0822 1ba6fa34 2bac1619 389045c3
Apr/26/2022 15:33:12 ipsec,debug,packet 6c239b20 7c359002 fb64974c 52d7b152 98d468cd 830ee232 47619774 fef7b40d
Apr/26/2022 15:33:12 ipsec,debug,packet aaff3ea6 8937ec43 92f904d4 df3c4062 9bf3c3bb c044e04f 876169f9 664e433b
Apr/26/2022 15:33:12 ipsec,debug,packet 3259b50d 4cdf4bc5 f6628be7 e6f302bf f828d4a4 3eeb869e 81d0083a 9b195aa5
Apr/26/2022 15:33:12 ipsec,debug,packet 294a545c 4f512102 ab28c970 f7f2865b 91ff7b53 42f069e4 5bc97f91 cc423416
Apr/26/2022 15:33:12 ipsec,debug,packet 2166325a 244860bc 327120fb
Apr/26/2022 15:33:12 ipsec sent phase2 packet Local_Public_IP[500]<=>Remote_Public_IP[500] 51e8e9ce0eb406ee:98bd391ef8c866c3:0000f9d7
Apr/26/2022 15:33:12 ipsec,debug ===== received 476 bytes from Remote_Public_IP[500] to Local_Public_IP[500]
Apr/26/2022 15:33:12 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08102001 f9d74543 000001dc 99539ea0
Apr/26/2022 15:33:12 ipsec,debug,packet 64d93ac6 954f1e53 84c2b23e 9f8d3dd1 f2a9b893 6bf174ad c2a804ed ff119d8a
Apr/26/2022 15:33:12 ipsec,debug,packet e4c5c5ce f7a9172a c19d50fc 10b024df e3fbfd12 9ae51741 ef4f77f9 3e3c8f47
Apr/26/2022 15:33:12 ipsec,debug,packet 7301d15a ff70290f 71827b6d 0983ccaf abd3c294 8a25fea3 9d63f09a 920b3b72
Apr/26/2022 15:33:12 ipsec,debug,packet 1d2705da 414491d5 26d8710b 34bd2cc0 a8e8efb3 e28441d9 02a8c4cf 0a26680c
Apr/26/2022 15:33:12 ipsec,debug,packet 6ab9d133 b9d79e63 40b9b39a e0e9df39 bb589dff 9bab44f1 60461aa5 464b636d
Apr/26/2022 15:33:12 ipsec,debug,packet 76f74298 5260fd93 4551af3a 471b9b7c 1255d388 7e11c762 ac3faf75 978b42e2
Apr/26/2022 15:33:12 ipsec,debug,packet 3067780c 09dbf378 88d70231 93b1e73b d3600b99 0b33ee6c 92452022 66c4a8be
Apr/26/2022 15:33:12 ipsec,debug,packet 7c369641 6f0e9bee d7c4fb00 dd0db664 63fa0c74 e1b7fa8d 0fa9c4b3 425d014a
Apr/26/2022 15:33:12 ipsec,debug,packet 6df64de0 3de0c860 1718cdde 5bb9b7a1 b572cfb9 e883b331 087fe43d 9d228fab
Apr/26/2022 15:33:12 ipsec,debug,packet 7badec08 45101c85 808e36fc 758d1de2 24487dd2 7435283e a4148715 f991162f
Apr/26/2022 15:33:12 ipsec,debug,packet 8cd59402 c86a4612 d8657697 683675e5 153a230f f5c8b1ea 6263af03 e9312345
Apr/26/2022 15:33:12 ipsec,debug,packet af43e87d 3fdd12b3 ba7990dd 4b96d43e 17f1bdcf 2a7f46de f671e2e3 bb6fd401
Apr/26/2022 15:33:12 ipsec,debug,packet 3e7d6e6c db719ffc 027391c5 3abd6de5 ab9c1b7b 1bc18d27 e0b4267c 4c2344c6
Apr/26/2022 15:33:12 ipsec,debug,packet 899d3828 05ae4431 07559641 73be2fc4 7aa65ed7 dac51757 e0fbecae
Apr/26/2022 15:33:12 ipsec,debug,packet IV was saved for next processing:
Apr/26/2022 15:33:12 ipsec,debug,packet 73be2fc4 7aa65ed7 dac51757 e0fbecae
Apr/26/2022 15:33:12 ipsec,debug,packet decrypted payload by IV:
Apr/26/2022 15:33:12 ipsec,debug,packet decrypted payload, but not trimed.
Apr/26/2022 15:33:12 ipsec,debug,packet 01000024 a7d8f395 fc12b3d8 541af770 ecb46101 c164ddd1 920ab807 9ae9aefe
Apr/26/2022 15:33:12 ipsec,debug,packet ae9e2e73 0a00003c 00000001 00000001 00000030 01030401 e07c74e8 00000024
Apr/26/2022 15:33:12 ipsec,debug,packet 04000014 f35df282 8fda60e8 c022cd84 49e5d743 05000104 611f9691 7874ee57
Apr/26/2022 15:33:12 ipsec,debug,packet c48d2613 e3fc38ba 30438804 2b13a77c e1587b0b 2554c535 2994fb43 1e4a89c5
Apr/26/2022 15:33:12 ipsec,debug,packet eff22b8c 490d78b7 62fcb49c 32a42fb9 0dd6960e a394638e 191a1f05 388fba15
Apr/26/2022 15:33:12 ipsec,debug,packet b55b06c2 4202134c ed4e4fdd 49d280c6 72c5a4dd edbdbbcd b08ae04b 4890d3f6
Apr/26/2022 15:33:12 ipsec,debug,packet 7d406550 bd248c23 a90e2609 52bf4667 76b332c1 b81b1daa f09c9411 76d0e916
Apr/26/2022 15:33:12 ipsec,debug,packet 6ff9b321 af590ee4 b0104a4a 7d744553 b54fc1c0 2cbbbc3e 7e966b11 9d806e54
Apr/26/2022 15:33:12 ipsec,debug,packet 48544290 97d5de85 4fb7f253 d5717fec 1a1cc50d 0b7cf296 545d2c9a 5ab3c674
Apr/26/2022 15:33:12 ipsec,debug,packet ceecea4a 0fc266ba 8ecb6a9b f55debd8 a121cff6 dd214846 df97de9b 0bba65ea
Apr/26/2022 15:33:12 ipsec,debug,packet 0924ee2f 8a076dcc 956414c7 7e34cd2a 727edd7d 350eac29 05000010 04000000
Apr/26/2022 15:33:12 ipsec,debug,packet c0a80100 ffffff00 0b000010 04000000 0a151400 ffffff00 0000001c 00000001
Apr/26/2022 15:33:12 ipsec,debug,packet 03046000 e07c74e8 80010001 00020004 0000a8c0 99fa6068 2c631952 916d750b
Apr/26/2022 15:33:12 ipsec,debug,packet padding len=12
Apr/26/2022 15:33:12 ipsec,debug,packet skip to trim padding.
Apr/26/2022 15:33:12 ipsec,debug,packet decrypted.
Apr/26/2022 15:33:12 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08102001 f9d74543 000001dc 01000024
Apr/26/2022 15:33:12 ipsec,debug,packet a7d8f395 fc12b3d8 541af770 ecb46101 c164ddd1 920ab807 9ae9aefe ae9e2e73
Apr/26/2022 15:33:12 ipsec,debug,packet 0a00003c 00000001 00000001 00000030 01030401 e07c74e8 00000024 010c0000
Apr/26/2022 15:33:12 ipsec,debug,packet 80010001 00020004 00015180 80040001 80060100 80050005 8003000e 04000014
Apr/26/2022 15:33:12 ipsec,debug,packet f35df282 8fda60e8 c022cd84 49e5d743 05000104 611f9691 7874ee57 c48d2613
Apr/26/2022 15:33:12 ipsec,debug,packet e3fc38ba 30438804 2b13a77c e1587b0b 2554c535 2994fb43 1e4a89c5 eff22b8c
Apr/26/2022 15:33:12 ipsec,debug,packet 490d78b7 62fcb49c 32a42fb9 0dd6960e a394638e 191a1f05 388fba15 b55b06c2
Apr/26/2022 15:33:12 ipsec,debug,packet 4202134c ed4e4fdd 49d280c6 72c5a4dd edbdbbcd b08ae04b 4890d3f6 7d406550
Apr/26/2022 15:33:12 ipsec,debug,packet bd248c23 a90e2609 52bf4667 76b332c1 b81b1daa f09c9411 76d0e916 6ff9b321
Apr/26/2022 15:33:12 ipsec,debug,packet af590ee4 b0104a4a 7d744553 b54fc1c0 2cbbbc3e 7e966b11 9d806e54 48544290
Apr/26/2022 15:33:12 ipsec,debug,packet 97d5de85 4fb7f253 d5717fec 1a1cc50d 0b7cf296 545d2c9a 5ab3c674 ceecea4a
Apr/26/2022 15:33:12 ipsec,debug,packet 0fc266ba 8ecb6a9b f55debd8 a121cff6 dd214846 df97de9b 0bba65ea 0924ee2f
Apr/26/2022 15:33:12 ipsec,debug,packet 8a076dcc 956414c7 7e34cd2a 727edd7d 350eac29 05000010 04000000 c0a80100
Apr/26/2022 15:33:12 ipsec,debug,packet ffffff00 0b000010 04000000 0a151400 ffffff00 0000001c 00000001 03046000
Apr/26/2022 15:33:12 ipsec,debug,packet e07c74e8 80010001 00020004 0000a8c0 99fa6068 2c631952 916d750b
Apr/26/2022 15:33:12 ipsec,debug begin.
Apr/26/2022 15:33:12 ipsec,debug seen nptype=8(hash) len=36
Apr/26/2022 15:33:12 ipsec,debug seen nptype=1(sa) len=60
Apr/26/2022 15:33:12 ipsec,debug seen nptype=10(nonce) len=20
Apr/26/2022 15:33:12 ipsec,debug seen nptype=4(ke) len=260
Apr/26/2022 15:33:12 ipsec,debug seen nptype=5(id) len=16
Apr/26/2022 15:33:12 ipsec,debug seen nptype=11(notify) len=28
Apr/26/2022 15:33:12 ipsec,debug succeed.
Apr/26/2022 15:33:12 ipsec,debug Remote_Public_IP Notify Message received
Apr/26/2022 15:33:12 ipsec Remote_Public_IP ignore RESPONDER-LIFETIME notification.
Apr/26/2022 15:33:12 ipsec,debug IDci matches proposal.
Apr/26/2022 15:33:12 ipsec,debug IDcr matches proposal.
Apr/26/2022 15:33:12 ipsec,debug HASH allocated:hbuf->l=472 actual:tlen=424
Apr/26/2022 15:33:12 ipsec,debug HASH(2) received:
Apr/26/2022 15:33:12 ipsec,debug a7d8f395 fc12b3d8 541af770 ecb46101 c164ddd1 920ab807 9ae9aefe ae9e2e73
Apr/26/2022 15:33:12 ipsec,debug,packet f9d74543 ac9f93fe 27ed240c 9356469f 4553151d 59a9bb02 e7236990 0a00003c
Apr/26/2022 15:33:12 ipsec,debug,packet 00000001 00000001 00000030 01030401 e07c74e8 00000024 010c0000 80010001
Apr/26/2022 15:33:12 ipsec,debug,packet 00020004 00015180 80040001 80060100 80050005 8003000e 04000014 f35df282
Apr/26/2022 15:33:12 ipsec,debug,packet 8fda60e8 c022cd84 49e5d743 05000104 611f9691 7874ee57 c48d2613 e3fc38ba
Apr/26/2022 15:33:12 ipsec,debug,packet 30438804 2b13a77c e1587b0b 2554c535 2994fb43 1e4a89c5 eff22b8c 490d78b7
Apr/26/2022 15:33:12 ipsec,debug,packet 62fcb49c 32a42fb9 0dd6960e a394638e 191a1f05 388fba15 b55b06c2 4202134c
Apr/26/2022 15:33:12 ipsec,debug,packet ed4e4fdd 49d280c6 72c5a4dd edbdbbcd b08ae04b 4890d3f6 7d406550 bd248c23
Apr/26/2022 15:33:12 ipsec,debug,packet a90e2609 52bf4667 76b332c1 b81b1daa f09c9411 76d0e916 6ff9b321 af590ee4
Apr/26/2022 15:33:12 ipsec,debug,packet b0104a4a 7d744553 b54fc1c0 2cbbbc3e 7e966b11 9d806e54 48544290 97d5de85
Apr/26/2022 15:33:12 ipsec,debug,packet 4fb7f253 d5717fec 1a1cc50d 0b7cf296 545d2c9a 5ab3c674 ceecea4a 0fc266ba
Apr/26/2022 15:33:12 ipsec,debug,packet 8ecb6a9b f55debd8 a121cff6 dd214846 df97de9b 0bba65ea 0924ee2f 8a076dcc
Apr/26/2022 15:33:12 ipsec,debug,packet 956414c7 7e34cd2a 727edd7d 350eac29 05000010 04000000 c0a80100 ffffff00
Apr/26/2022 15:33:12 ipsec,debug,packet 0b000010 04000000 0a151400 ffffff00 0000001c 00000001 03046000 e07c74e8
Apr/26/2022 15:33:12 ipsec,debug,packet 80010001 00020004 0000a8c0
Apr/26/2022 15:33:12 ipsec,debug total SA len=56
Apr/26/2022 15:33:12 ipsec,debug 00000001 00000001 00000030 01030401 06e3239b 00000024 010c0000 80010001
Apr/26/2022 15:33:12 ipsec,debug 00020004 00015180 80040001 80060100 80050005 8003000e
Apr/26/2022 15:33:12 ipsec,debug seen nptype=2(prop) len=48
Apr/26/2022 15:33:12 ipsec,debug proposal #1 len=48
Apr/26/2022 15:33:12 ipsec,debug seen nptype=3(trns) len=36
Apr/26/2022 15:33:12 ipsec,debug transform #1 len=36
Apr/26/2022 15:33:12 ipsec,debug type=SA Life Type, flag=0x8000, lorv=seconds
Apr/26/2022 15:33:12 ipsec,debug type=SA Life Duration, flag=0x0000, lorv=4
Apr/26/2022 15:33:12 ipsec,debug type=Encryption Mode, flag=0x8000, lorv=Tunnel
Apr/26/2022 15:33:12 ipsec,debug type=Key Length, flag=0x8000, lorv=256
Apr/26/2022 15:33:12 ipsec,debug type=Authentication Algorithm, flag=0x8000, lorv=hmac-sha256
Apr/26/2022 15:33:12 ipsec,debug type=Group Description, flag=0x8000, lorv=14
Apr/26/2022 15:33:12 ipsec,debug pair 1:
Apr/26/2022 15:33:12 ipsec,debug 0x1895f0: next=0 tnext=0
Apr/26/2022 15:33:12 ipsec,debug proposal #1: 1 transform
Apr/26/2022 15:33:12 ipsec,debug 00000001 00000001 00000030 01030401 e07c74e8 00000024 010c0000 80010001
Apr/26/2022 15:33:12 ipsec,debug 0x189610: next=0 tnext=0
Apr/26/2022 15:33:12 ipsec,debug begin compare proposals.
Apr/26/2022 15:33:12 ipsec,debug pair[1]: 0x189610
Apr/26/2022 15:33:12 ipsec,debug prop#=1 prot-id=ESP spi-size=4 #trns=1 trns#=1 trns-id=AES-CBC
Apr/26/2022 15:33:12 ipsec,debug peer's single bundle:
Apr/26/2022 15:33:12 ipsec,debug (proto_id=ESP spisize=4 spi=e07c74e8 spi_p=00000000 encmode=Tunnel reqid=0:0)
Apr/26/2022 15:33:12 ipsec,debug my single bundle:
Apr/26/2022 15:33:12 ipsec,debug (proto_id=ESP spisize=4 spi=06e3239b spi_p=00000000 encmode=Tunnel reqid=11:11)
Apr/26/2022 15:33:12 ipsec,debug matched
Apr/26/2022 15:33:12 ipsec,debug HASH(3) generate
Apr/26/2022 15:33:12 ipsec,debug,packet 00f9d745 43ac9f93 fe27ed24 0c935646 9f455315 1d59a9bb 02e72369 90f35df2
Apr/26/2022 15:33:12 ipsec,debug,packet 828fda60 e8c022cd 8449e5d7 43
Apr/26/2022 15:33:12 ipsec,debug,packet 19544027 e8bebdd0 23024a36 8e475f6a 8b6f9076 20e5f9a8 c448b8da 85642b6a
Apr/26/2022 15:33:12 ipsec,debug add payload of len 32, next type 0
Apr/26/2022 15:33:12 ipsec,debug,packet pad length = 12
Apr/26/2022 15:33:12 ipsec,debug,packet 00000024 19544027 e8bebdd0 23024a36 8e475f6a 8b6f9076 20e5f9a8 c448b8da
Apr/26/2022 15:33:12 ipsec,debug,packet 85642b6a b0bacac6 f8ffb0a4 effca90b
Apr/26/2022 15:33:12 ipsec,debug,packet e2bcd0d1 a6c34571 2f39b308 f6dca431
Apr/26/2022 15:33:12 ipsec,debug 76 bytes from Local_Public_IP[500] to Remote_Public_IP[500]
Apr/26/2022 15:33:12 ipsec,debug 1 times of 76 bytes message will be sent to Remote_Public_IP[500]
Apr/26/2022 15:33:12 ipsec,debug,packet 51e8e9ce 0eb406ee 98bd391e f8c866c3 08102001 f9d74543 0000004c 21f328c3
Apr/26/2022 15:33:12 ipsec,debug,packet 63d14e0b 0ae7e719 e932662d 7ea81b1e 233b2d8b 112f0c78 3d0778b4 e2bcd0d1
Apr/26/2022 15:33:12 ipsec,debug,packet a6c34571 2f39b308 f6dca431
Apr/26/2022 15:33:12 ipsec,debug,packet compute DH's shared.
Apr/26/2022 15:33:12 ipsec,debug,packet 77624d47 e2fdc520 9916fb91 f4f6315b 956ec902 a6745e24 417cca3b c03d1e29
Apr/26/2022 15:33:12 ipsec,debug,packet 41b21e4e b2d0f761 d772ea0e defb2284 e045cf99 86701023 08c51654 eaa34746
Apr/26/2022 15:33:12 ipsec,debug,packet 493eeff2 6e09c8bd ce6ac58f 1d0994e2 f8eeabc9 c0264399 e6415e96 cd58741d
Apr/26/2022 15:33:12 ipsec,debug,packet 6ddc62cf 95684036 5c243d70 74da3ab3 a1531aab e9fa5969 a09260ae a342815d
Apr/26/2022 15:33:12 ipsec,debug,packet bf47ed2d 440a6323 d988baf4 9cf33b48 e1d45a1e f137ff2f 8ae0672a d733353f
Apr/26/2022 15:33:12 ipsec,debug,packet 8c822b9b 82bb4d57 34ad95e4 d655133c b357c852 2d93cd67 d7a7432b 6a040af7
Apr/26/2022 15:33:12 ipsec,debug,packet 40974bc8 d5b1ae89 844aadc7 b77be598 56ac0b1d ee8b1270 760c2984 c1746312
Apr/26/2022 15:33:12 ipsec,debug,packet 06ffb397 0fda1ed5 5cf1fa1c dc02f1f9 44e8f379 f09ff3c1 f5fd5594 a869dff6
Apr/26/2022 15:33:12 ipsec,debug,packet KEYMAT compute with
Apr/26/2022 15:33:12 ipsec,debug,packet 0306e323 9bac9f93 fe27ed24 0c935646 9f455315 1d59a9bb 02e72369 90f35df2
Apr/26/2022 15:33:12 ipsec,debug encryption(aes-cbc)
Apr/26/2022 15:33:12 ipsec,debug hmac(hmac_sha2_256)
Apr/26/2022 15:33:12 ipsec,debug encklen=256 authklen=256
Apr/26/2022 15:33:12 ipsec,debug generating 1024 bits of key (dupkeymat=4)
Apr/26/2022 15:33:12 ipsec,debug generating K1...K4 for KEYMAT.
Apr/26/2022 15:33:12 ipsec,debug 32cb6bd0 5dab774c c145c105 3180e857 a2ae1fe1 0bc8a0c5 3b88a87f b563cbf8
Apr/26/2022 15:33:12 ipsec,debug f99ae883 e297f9b2 4abbac05 cb481c78 f96d5395 88145b83 1e0cdbe5 c65fc73d
Apr/26/2022 15:33:12 ipsec,debug 94994971 8f9b1031 6289094e aa822b09 534886ae fc5d1de5 a433083d 7bf9a1d4
Apr/26/2022 15:33:12 ipsec,debug 592619c3 4bc32d21 26d2218e 71a7e184 e93cb299 5fc4a857 f72c9608 1f92f721
Apr/26/2022 15:33:12 ipsec,debug,packet 03e07c74 e8ac9f93 fe27ed24 0c935646 9f455315 1d59a9bb 02e72369 90f35df2
What is interesting now, for some reason policy: 192.168.1.0/24 <=> 192.168.31.0/24 always falls to "no phase2" state, but I did not manage to get any logging for it at least trying to establish the PH2
policy.
AndriejusArt
Mon May 09, 2022 9:41 am
Just an update:
When trying to log the issue from the fortigate side: there is what i get:
right after one of the SA's (ph2's) is established, a random previous one drops:
sent IKE msg (quick_r1send): 192.168.1.24:500->80.0.0.1:500, len=444, id=d501b110c25be16b/42e97833497dcdc7:c7183e7c
IPsec SA 03a8c32a/e07cf22d hard expired 10 192.168.1.24:0->80.0.0.1:0 SA count 3 of 3
send IPsec SA delete, spi e07cf22d
sent IKE msg (IPsec SA_DELETE-NOTIFY): 192.168.1.24:500->80.0.0.1:500, len=92, id=d501b110c25be16b/42e97833497dcdc7:27b6f20b
comes 192.168.1.24:500->80.0.0.1:500,ifindex=10....
Any ideas, what does this "hard expired" means? anyone?
Users browsing this forum: 4l4R1, Bing [Bot] and 72 guests
