labiol
Port speed, Access Point MikroTik wsAP ac lite RBwsAP-5Hac2nD
Sat Apr 16, 2022 11:02 am
Anyone knows what is the ports speed (PoE on back of this device) of Access Point MikroTik wsAP ac lite RBwsAP-5Hac2nD.
Documentation is referring to the 3 ports on the front of the device that are 100mbps.
But what will be the speed between the router and the AP in case I have router 1Gpbs port?
In other words what is the speed of the PoE ports on the back of the device?
mfrommel
Re: Port speed, Access Point MikroTik wsAP ac lite RBwsAP-5Hac2nD
Sat Apr 16, 2022 11:35 am
wsAP has a total of 3 ethernet ports. 2 at the front 1 at the back.
All have 10/100
The one at the back has "PoE in 802.3af/at" and is the only way to power the device.
Additionally there is a phone-line passthrough from back to front.
anav
Sat Apr 16, 2022 1:38 pm
@labiol ???????????
Quoting from the product page
The wsAP has three Ethernet ports: one on the back side for easy PoE-in, and two LAN ports behind the front door. The device provides Dual concurrent 2.4 GHz and 5 GHz WiFi coverage, it supports 802.11ac, as well as legacy standards. A USB 2.0 port is provided, to charge mobile devices or for storage.
I even checked the brochure and it says the same thing?
Can you please point me to where it says anything different??
holvoetn
Sat Apr 16, 2022 4:04 pm
Does it matter where they are located ?
If they are 100mb max, you will get 70-80 towards other 100mb or better ports.
mkx
Sat Apr 16, 2022 4:13 pm
It does. If they are pointing downwards, then gravity helps to move those bits faster on egress ...
holvoetn
Sat Apr 16, 2022 4:28 pm
Ah yes, totally forgot about that.
labiol
Sun Apr 17, 2022 4:29 pm
The phone line confused me. Thanks for the explanation. Btw that is fantastic that Mk has such active community.
Thread closed.
Users browsing this forum: No registered users and 56 guests
