I have been using cAP ac for several years now. And since day one I have noticed that the 5 GHz upload speed is much slower than the download speed. I don't use 2.4 GHz at all so I haven't tested the difference between upload and download speeds with 2.4 GHz. And I use cAP ac only as 5 GHz wireless router, the ether2 port is disabled.
Below you can see the difference between download and upload speeds using 5 GHz. And to be absolutely clear, the ISP provides the same upload and download speeds, i.e. if I connect the computer directly to the WAN cable, the upload speed is almost identical to the download speed. Although it does not bother me much, I would like to understand why such a problem exists at all. I have reset the router to default settings several times over time, I have always used the latest version of the RouterOS, but it has never been clear to me whether this is the problem with RouterOS itself or configuration settings, or maybe my router has some hardware problems.
The router is currently running RouterOS v7.2.1 with this configuration, which is basically the default configuration -
Code: Select all
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=XX:XX:XX:XX:XX:XX
set [ find default-name=ether2 ] disabled=yes
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn country=latvia distance=\
indoors frequency=2437 installation=indoor mode=ap-bridge radio-name=wlan1 \
ssid="wlan1" wireless-protocol=802.11 wmm-support=enabled \
wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-XXXX \
country=latvia disabled=no distance=indoors frequency=5220 installation=\
indoor mode=ap-bridge radio-name=wlan2 ssid="wlan2" \
wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk disable-pmkid=yes \
eap-methods="" group-key-update=1h mode=dynamic-keys supplicant-identity=\
MikroTik
add name=dhcp ranges=10.7.7.2-10.7.7.16
add address-pool=dhcp interface=bridge lease-time=2d name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=10.7.7.1/24 comment=defconf interface=bridge network=10.7.7.0
add address=XX.XX.XX.XX/24 interface=ether1 network=XX.XX.XX.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=10.7.7.0/24 comment=defconf gateway=10.7.7.1 netmask=24
set servers=91.198.156.20,194.8.2.2
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=10.7.7.0/24
set ssh disabled=yes
set api disabled=yes
set winbox address=10.7.7.0/24
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Riga
/system identity
set name=Router
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
Does anyone have any ideas that I could change in configuration to improve 5 GHz upload speed?
Thanks!
