ejenk
Problems connecting to Internet through cAP ac and RB960PGS
Mon Apr 18, 2022 6:09 pm
I have a cAP ac plugged into a RouterBOARD 960PGS. Some of my devices (Apple devices, Kindle) can connect to the cAP and access the Internet. Other devices (Android tablet, ecobee thermostat) will connect, but cannot access the Internet. Additionally, my Mac has an issue where, if I'm waking it from sleep, it can't connect to the Internet until I either manually renew the DHCP lease or disconnect and reconnect the wifi. I tried disabling RSTP in the Bridge interface, but this did not solve the problem.
Other possibly relevant details:
  • I don't have any problems with devices connected directly to the 960PGS via ethernet
  • I have a second 960PGS connected to the first in bridge mode
Any ideas about what might be wrong would be greatly appreciated.
[admin@MikroTik] > export compact
# apr/18/2022 09:57:09 by RouterOS 6.49
# software id = FTTW-2WN5
# model = RB960PGS
# serial number = D5300E07BD64
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz name=2.4
add band=5ghz-a/n/ac control-channel-width=20mhz name=5
add admin-mac=2C:C8:1B:D9:52:CC auto-mac=no comment=defconf name=bridge protocol-mode=none
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security1 passphrase=***REDACTED***
/caps-man configuration
add channel=2.4 country="united states3" datapath.bridge=bridge distance=indoors hw-retries=4 name=2.4-cfg security=security1 ssid=***REDACTED***
add channel=5 country="united states3" datapath.bridge=bridge distance=indoors hw-retries=4 name=5-cfg security=security1 ssid=***REDACTED***
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/caps-man manager
set enabled=yes upgrade-policy=suggest-same-version
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=2.4-cfg name-format=prefix-identity
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=5-cfg name-format=prefix-identity
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.88.229 client-id=1:90:9c:4a:b6:43:b2 mac-address=90:9C:4A:B6:43:B2 server=defconf
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system clock
set time-zone-name=America/Chicago
/tool mac-server
/tool mac-server mac-winbox
Users browsing this forum: Google [Bot], GoogleOther [Bot], qatar2022, unhuzpt and 111 guests
