I am Mikrotik newbie and choose Mikrotik due to known reliability, but now I am having problem with configuration. I already wrote to support which first said that I should upgrade to version 7.2 and after that I got the answer that they don't offer configuration support and should rely on forum. So here is my description:
What am I using:
- RB951G-2HnD router
- cAP Lite
- cAP RBCAP2ND
The configuration is made so that there is a separation between guest LAN, guest WI-FI and home LAN/WI-FI. Guest LAN is on port 5. The reason is that they have an apartment to rent.
First we had cap Lite and was connected to the to Capman through cap mode. All works fine and was provisioned, and also I can switch it between home and guest WI-FI.
"Some days ago" I added RBCAP2ND. It was also added through cap mode. I managed to provision it and also set it for home WI-FI.
The problem I now have is that I try to login and I don’t obtain IP for client devices through that cap.
When looking through configuration I saw that the biggest difference is that cap1 (127.0.0.1) and capLite are “slave” and this new one is “master”. Is this the a possible problem and how can I change it.
I am also attaching the export of the configuration and some screenshots:
- Attached screenshot: cap_interface.png
You can see that “cap pogacar” status is MB, but for the others is SMB.
- Attached screenshot: remote_cap.png
You can see that all devices are at version 7.2.
- Attached screenshot: interfaces.png
You can see that interface “cap pogacar” is missing “S”
- Attached screenshot: bridge_ports.png
You can see that “cap pogacar” is missing.
Thank you for you help, I will really appreciate it.
