nosferatusmg
release port used by serial terminal
Wed Apr 20, 2022 4:48 pm
how to release the serial port.
happens after closing the terminal window before exiting the serial terminal
marcelo@POP-MTL-PPPOE1] > /port/pr
Columns: NAME, CHANNELS, USED-BY, BAUD-RATE
# NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 serial-terminal auto
1 serial1 1 auto
[marcelo@POP-MTL-PPPOE1] > /system/serial-terminal serial0
serial-terminal already running on this port
rextended
Re: release port used by serial terminal
Wed Apr 20, 2022 4:57 pm
To close the terminals left open by mistake:
/system script job remove [find where type=command]
To enable/disable the link between internal console and serial port:
# ENABLE
/system console
set [ find port=serial0 ] disabled=no
# DISABLE
/system console
set [ find port=serial0 ] disabled=yes
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], LookUp, Snooops and 51 guests
