martinpm
OVPN Mikrotik TLS failed
Wed Apr 20, 2022 5:59 pm
Hello, I have Ubuntu as server openvpn, mikrotik is client.
Configuration file from server .ovpn i have imported to mikrotik
In mikrotik log is ovpn-out: terminating... - TLS failed.
I have RouterOS 7.2.1. I have tried tcp and udp.
From windows connect to ubuntu is ok.
Could you help my?
stek
Re: OVPN Mikrotik TLS failed
Sat May 28, 2022 11:27 am
Hi, I have the same with OpenVPN cloud
DO you solved it?
regards
Stefano
pgotze
Fri Jun 10, 2022 10:32 am
you are probably using not same cipher, check that its correctly set in you Client config on mikrotik.
I use mikrotik as OVPN client, i am able to make connection properly, anyway i have other issues, its not routing properly, would be nice to see somebody with functioning scenario.
Pavel
own3r1138
Long time Member
Long time Member
Fri Jun 10, 2022 2:24 pm
@pgotze
Source:
https://help.mikrotik.com/docs/display/ROS/OpenVPN
Since RouterOS does not support route-push you need to add manually which networks you want to access over the tunnel.
pgotze
Tue Jun 14, 2022 10:50 am
@own3r1138
Hi, i am not sure, because if i enable my VPN client on mikrotik, Route List is updated automatically, which is something i dont really want/can influence, so unfortunately i have 2 issues:
- it starts routing of all traffic to VPN (0.0.0.0 --> 10.8.0.5) - this i dont want, i want route only remote network traffic (to 192.168.2.0/24)
- anyway remote network is not accessible, the traceroute ends on local address of mikrotik (192.168.4.1) and does not continue to remote (10.8.0.5, 192.168.2.*)
You can see on my screenshots situation, when VPN client is enabled/connected or disabled. The change in routing list is done automatically, i do not make any manual change
own3r1138
Long time Member
Long time Member
Tue Jun 14, 2022 4:29 pm
disable the default route if you don't wish to route 0.0.0.0/0.
I can see the routes but I do not know how they came to be.
pgotze
Tue Jun 14, 2022 5:53 pm
i can disable, true, i tried, but if connection is reconnected, its back again.
The ovpn connection i tried both, with or withoutch checkbox, but it does not make reall difference, the remote network is not available.
I am not sure, if its not the problem of 7.4beta2 version i use, dont know. It just does not route traffic at all.
own3r1138
Long time Member
Long time Member
Tue Jun 14, 2022 6:20 pm
@pgotze
So what is the OVPN server appliance or the OS? Does it have these routes configured in the server endpoint?
pgotze
Tue Jun 14, 2022 10:46 pm
Server side is TP-link AX55, tested with Windows Desktop and OpenVPN Connect windows app as client and works with no problem.
With mikrotik ovpn client i am able to connect, connection is created, but no routing, even if what i see in route list looks OK
own3r1138
Long time Member
Long time Member
Tue Jun 14, 2022 11:05 pm
RouterOS is very different from a Windows OVPN connect client. Seeing the routes means they are there. But, it doesn't mean that the MT router knows what you want to pass through your OVPN tunnel. or maybe you didn't add any src-nat for that traffic so it will exit your router with your LAN IPs, or even if your router doesn't know what to do with it, and Firewall rules. All of these will break your communication.
pgotze
Wed Jun 15, 2022 1:07 pm
well, i have masquerading done in Firewall, this should not be the problem.
I know, MT openvpn is a bit specific, then standard, anyway, i am trying to find the way , how to trace, where exactly my packets ends. I tried to mark communication with Mangle, so i think it should reach server side, but i am not sure.
So may be problem is in compatibility of MT OpenVPN Client versus TP-Link OpenVPN Server, also possible.
own3r1138
Long time Member
Long time Member
Wed Jun 15, 2022 1:55 pm
It's better to set up a lab MT OVPN server with an MT client.
If your client successfully connected and communicated with the OVPN server and your LAN IPs, Then try to move it over to your TP.
Users browsing this forum: Bing [Bot], Qanj72, raiser, slimmerwifi and 165 guests
