markos222
CVE-2021-41987
Thu Apr 21, 2022 12:08 pm
What is about this CVE?
Guntis
Re: CVE-2021-41987
Thu Apr 21, 2022 12:18 pm
This issue was first fixed in 6.48.6, 6.49.1, 7.1, as such, subsequent versions, and current releases are not affected by it.
markos222
Re: CVE-2021-41987
Thu Apr 21, 2022 12:28 pm
Hi Guntis
The question is how the attacker acts, do you have to have the web port? winbox? or how this cve affects us
With firewalled ports we are safe?
markos222
Re: CVE-2021-41987
Thu Apr 21, 2022 12:58 pm
Hi
Do I need to have a certificate installed for this attack to occur?
Guntis
Re: CVE-2021-41987
Thu Apr 21, 2022 1:10 pm
SCEP has to be configured, and the attacker needs to know the path name, furthermore its a somewhat complex attack with a low probability of success: https://teamt5.org/en/posts/vulnerabili ... 021-41987/
markos222
Re: CVE-2021-41987
Thu Apr 21, 2022 1:39 pm
Ok , thanks!
suran
Re: CVE-2021-41987
Wed May 18, 2022 2:39 am
Guntis - do you know when the vulnerable code was first introduced? Is the list of versions supplied complete, or are there other versions? I note the CVE says 6.46.*, does that mean all 6.46 versions? What about 6.45, etc?
rextended
Re: CVE-2021-41987
Wed May 18, 2022 11:19 am
"CVE says"?
https://nvd.nist.gov/vuln/detail/CVE-2021-41987
Current Description
In the SCEP Server of RouterOS in certain Mikrotik products, an attacker can trigger a heap-based buffer overflow that leads to remote code execution.
The attacker must know the scep_server_name value. This affects RouterOS 6.46.8, 6.47.9, and 6.47.10.
But you do not have any reason to not upgrade/update to latest long-term 6.48.6
suran
Re: CVE-2021-41987
Wed May 18, 2022 8:11 pm
CVE actually says:
cpe:2.3:o:mikrotik:routeros:6.47.9:*:*:*:*:*:*:*
cpe:2.3:o:mikrotik:routeros:6.46:*:*:*:*:*:*:*
cpe:2.3:o:mikrotik:routeros:6.46.8:*:*:*:*:*:*:*
cpe:2.3:o:mikrotik:routeros:6.47.10:*:*:*:*:*:*:*
https://www.opencve.io/cve/CVE-2021-41987
I completely agree with your statement about upgrading. That said, a complete list of affected versions is a reasonable and normal request.
rextended
Re: CVE-2021-41987
Thu May 19, 2022 1:54 am
You read all the page?
Like the Values Removed?
But the point is: upgrade/update it instead to search an excuse to not upgrade it.
There are also UNpublished bugs, you know?...
suran
Re: CVE-2021-41987
Thu May 19, 2022 2:24 am
This has nothing to do with updating or not.
I am obligated to report on what devices (all of which were immediately upgraded) were impacted by the CVE. In order to do that I must know which versions are affected. It's as simple as that. The exploit code that was published specifically targets the listed versions, but that does NOT mean the vulnerable code was introduced in those versions.
Larsa
Re: CVE-2021-41987
Thu May 19, 2022 9:04 am
This may only happen if you both expose http and enable SCEP ("/certificate scep-server add...") to the internet thus the attack vector is probably very low in general. And even if you do, the probability of a regular crash is significantly higher than that of a successful remote code execution (RCE) because it all depends on an exact configuration and dynamic memory allocation.
Users browsing this forum: Google [Bot], GoogleOther [Bot] and 108 guests
