FranCruzarianick
loop in python not working for all line in text file
Thu Apr 21, 2022 1:34 pm
Hi
this code for get identity of mikrotik device. after run this code. only work for last IP
lines in ip.txt
192.168.3.6 --> NET_6
192.168.3.8 --> NET_8
192.168.3.10 --> NET_10
import os
filename = 'ip.txt'
with open(filename, 'r') as f:
for line in f:
pq = os.popen('plink -batch admin@' + line + ' -pw 123456@ "/system identity print"')
line = pq.readline()
print(line)
Using username "admin".
Buckeye
Forum Veteran
Forum Veteran
Re: loop in python not working for all line in text file
Sat Apr 23, 2022 1:25 am
indentation is significant in python. specifically loops in your case.
rextended
Sat Apr 23, 2022 1:49 am
is indented, simply html do not show significant spaces (I do not check if is indented rightly)
new user do not know the use of [ code] blocks
python code
import os
filename = 'ip.txt'
    for line in f:
        print(line)
Users browsing this forum: Dude2048, mkx, raiser and 38 guests
