terintamel
ROS V7 BGP Advertisement Question
Thu Apr 21, 2022 5:41 pm
I am working on converting a v6 BGP setup to a new router running V7 and have a question on the advertisements.
Here is the example setup (Using private IPs just for example purposes)
BGP Peer1 (172.16.5.1)->border router eth1 -> border router eth3 -> core router eth1
BGP Peer2 (172.16.10.1)->border router eth2 -> border router eth3 ->core router eth1
Border router
eth1 - 172.16.5.2/30
eth2 - 172.16.10.2/30
eth3 - 172.16.2.1/30
Core router
eth1 - 172.16.2.2/30
eth2 - 192.168.97.1/24
eth3 - 192.168.104.1/24
In v6 I know I put my networks to advertise in the BGP->Networks section. So for an example I have the following. I have changed the IPs so as to not show my public IP ranges.
BGP Network (synchronize set to no)
192.168.96.0/20
192.168.96.0/21
192.168.104.0/21
Routing filter
Out-peer-1 (prefix 192.168.96.0/20; accept)
Out-peer-1 (prefix 192.168.96.0/21; accept)
Out-peer-2 (prefix 192.168.96.0/20; accept)
Out-peer-2 (prefix 192.168.104.0/21; accept)
I have this setup this was as I have two BGP connections with my upstream provider and I manually load balance by advertising my full range out both and then my upper range /21 out one and the lower range /21 out the other using the outbound routing filters . This way incoming traffic will prefer the /21 but if one feed goes down then the other traffic will then use the /20 to find my network.
In my border router routing table I have just the one route towards my core of 192.168.96.0/20 with a gateway of 172.16.2.2. I do not have any routes blackholed. This functions properly with no issue in v6.
In v7 I know to put the advertised networks as an Address list and I have my outbound filtering rules converted as well. My confusion is around the example here (https://help.mikrotik.com/docs/display/ ... g+Examples) where it states that now in v7 routes will not be advertised unless they exist in the routing table. Also they show blackholing their route
So in v7 do I have to put all three advertised routes in the routing table or will just having the single 192.168.96.0/20 route suffice and still allow for the advertisements of both the /21s to be received by the my peers? Also do I have to have the blackhole for my prefixes?
mrz
Re: ROS V7 BGP Advertisement Question  [SOLVED]
Thu Apr 21, 2022 5:51 pm
Currently, you need exact match, so if you are trying to advertise /21 routes then there must be corresponding routes in the routing table. You cannot add one generic /20 route, to advertise /21 routes.
terintamel
Thu Apr 21, 2022 6:24 pm
Got it so in my v7 routing table I would have to have
192.168.96.0/20
192.168.96.0/21
192.168.104.0/21
Do all three routes have to be enabled? Could I put in the /21s and set them 'disabled'?
Also the distance value for each route does not matter for the BGP advertisement, so I could have the /21s at say distance=244 and the /20 at distance=1? Just as long as all three specific routes are in the table.
mrz
Fri Apr 22, 2022 9:08 am
Routes need to be active, disabled routes won't cut.
prawira
Trainer
Trainer
Mon Sep 19, 2022 12:20 pm
so let say we have multiple /30 from 192.168.96.0/20 address space and not all of them allocated yet to customers, how should we advertise 192.168.96.0/20 ?
just put it into loopback on ebgp router ?
afaik, we are not allowed advertise smaller than /24.
mrz
Mon Sep 19, 2022 12:47 pm
add /20 blackhole route
maxwelljk
Wed Aug 23, 2023 12:45 am
about the /20 blackhole route I have this scenario.
Router 1 advertises
100.115.102.0/24
100.115.103.0.24
100.115.96.0/20 *Summarized route for redundancy propose.
Receives
0.0.0.0/0 via BGP
Router 2 advertises
100.115.105.0/24
100.115.107.0/24
Receives
0.0.0.0/0 via BGP
I have a connection metro E between Router 1 & Router 2.
Let say Router 1 goes down, Router 2 then try to reach router 1 routes via the blackhole route, since is the longest match to the destinations 100.115.102/24 & 10.115.103.0/24
How can I avoid this?
Router OS v6 Is not a problem since I don't have to set the blackhole route, this issue is with Router OS v7.
chechito
Wed Aug 23, 2023 12:59 am
Users browsing this forum: No registered users and 54 guests
