Torsion
hAP ac2 connection to server within LAN from outside
Sun Apr 24, 2022 2:16 pm
I am developing client-server application; the question is how to properly forward traffic (TCP/UDP) to and from server.
I have created a NAT rule as follows:
Chain: dstnat
Protocol: 6 (tcp)
Dst. Port: 4296 (my server on local machine is listening on that port)
Action: dst-nat
To Addresses: 192.168.88.253 (this is server's address in my LAN).
To test, I launch my client app on mobile (via cellular network, not from local Wi-Fi, to make the test more clean) - and on Rate Graph panel I see bytes incoming. The question is, which rule do I need to add, to make my server able to respond back to Internet? Thanks!
Sob
Re: hAP ac2 connection to server within LAN from outside
Sun Apr 24, 2022 6:50 pm
For start, you should fix dstnat rule, because this one takes all connections to specified port, incoming and outgoing ones. Add either dst-address=<your public address> if you have static one or dst-address-type=local if it's dynamic.
After that, connection must be allowed through firewall filter, and it depends on what you have there now. Factory default firewall already handles it, but if you have something else, you may need:
add chain=forward connection-nat-state=dstnat action=accept
anav
Sun Apr 24, 2022 11:28 pm
Torsion
Sat Apr 30, 2022 7:14 am
Thanks Sob and anav!
Let's elaborate this a little bit more for old fossils like me. If I understand the whole mechanics right, now it looks like this:
1.Mobile (or whatever Internet) client sends packet to WAN.
2.DST-NAT rule substitutes DST with LAN-addressed machine.
3.Server responds with DST copied from arrived packet's SRC.
4.Now my task is to write a rule that substitutes wan.ip as SRC?
This hAP's web interface has so many options when you design a rule so I'm a little bit lost(
(wan.ip == static.ip in this context)
Sob
Sat Apr 30, 2022 1:08 pm
No, this last part is automatic. Router tracks all connections, remembers all their original and new sources and destinations, and recognizes packets that belong together as one connection. You can see this data in IP->Firewall->Connections (WegFig doesn't seem to show everything at once, I have to click on each item; WinBox allows to show all columns). So if there was packet from mobile.ip to static.ip and dstnat changed destination to lan.ip, then when response comes from lan.ip to mobile.ip, connection tracking recognizes that it belongs to that connection, and automatically changes source from lan.ip to static.ip.
Zacharias
Sat Apr 30, 2022 3:07 pm
To add to what @sob said,
Indeed the connection tracking Table keeps track of all the connections that are taking place to the Router.
So it knows if a packet was Source Nated, Dst Nated etc...
In that example, the router knows the packet was dst nated and it will un-nat that connection. The same happens in the case of src nated packets.
Torsion
Mon May 02, 2022 6:05 am
This last automatic part doesn't work, unfortunately. I don't have connection.
anav
Mon May 02, 2022 2:17 pm
Easy to say, but without seeing your config, its impossible to know.
Sob
Mon May 02, 2022 2:33 pm
I'm sure it's not that. When you're testing it, counters for this dstnat rule increase, right? You can add some logging rules to see if server is responding at all:
/ip firewall mangle
add chain=postrouting dst-address=192.168.88.253 protocol=tcp dst-port=4296 action=log log-prefix="to-server"
add chain=prerouting src-address=192.168.88.253 protocol=tcp src-port=4296 action=log log-prefix="from-server"
Torsion
Sat May 14, 2022 10:24 am
According to Wireshark server does respond:
Here IP in filter is mobile IP.
# may/14/2022 10:36:15 by RouterOS 6.48.1
# software id = BIQC-9UQV
# model = RBD52G-5HacD2HnD
# serial number = CDFF0D7F7F0C
add admin-mac=08:55:31:B7:0E:90 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=MikroTik-B70E94 station-roaming=enabled wireless-protocol=\
    802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid="Imperial Network" \
    station-roaming=enabled wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=wlan2
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=accept chain=forward connection-nat-state=dstnat
add action=dst-nat chain=dstnat dst-address=195.91.236.13 dst-port=4296 \
    protocol=tcp to-addresses=192.168.88.253
/system clock
set time-zone-name=Europe/Moscow
/tool mac-server
/tool mac-server mac-winbox
anav
Sat May 14, 2022 4:05 pm
I see nothing that would be blocking your traffic on the MT config, so I have to start thinking about your ISp connection.
Users browsing this forum: No registered users and 21 guests
