Rockyboa
dhcp server sending host-name
Mon Apr 25, 2022 2:00 am
looking at the different way to change all the hostname of my servers that are booting using PXE, I'm trying to leverage the isc- dhclient https://kb.isc.org/docs/isc-dhcp-44-man ... cp-options that handle host-name. I build a script that use host to do reverse DNS, but I have some issue doing so.
It seems to be part of the dhcp rfc https://www.rfc-editor.org/rfc/rfc1533#section-3.14
Is there a way to leverage such thing in the Mikrotik dhcp server?
Maritn
smyers119
Re: dhcp server sending host-name
Wed May 04, 2022 7:00 am
"This option is only honored if the hostname for the client machine is not set."
Rockyboa
Fri May 27, 2022 3:20 pm
Thank for taking time to reply to my question. It is actually the case and when using a Linux machine running dnsmasq with this configuration line
dhcp-host=00:e0:66:59:88:8b,client1,192.168.78.51,set:diskless
it does assign the client1 to my device.
So trying to achieve similar behavior with the built-in customer Mikrotik DHCP,
Or I'll try to setup etckeeper just to manage hostname. By I doubt there is no way to achieve this with Mikrotik DHCP server.
Rocky.
Users browsing this forum: fibracapi, FurfangosFrigyes, hatred, hendry, Michiganbroadband, pajapatak, raiod and 79 guests
