mazay
7.2 high memory usage
Mon Apr 25, 2022 12:50 pm
I have RBLtAP with 2 LTE modules/antennas running ROS 7.2.1.
Since the last couple of weeks, I've noticed a weird behaviour which seems to be a memory leak. It doesn't seem to affect the performance yet but memory is definitely leaking to some hole, the graph is attached and the first occurrence correlates with the 7.2.0 upgrade. As you can see memory usage was fine before April 7th, there were no config changes just an upgrade.
https://www.dropbox.com/s/8qjae1l3kkg5g ... 3.png?dl=0
huntermic
Re: 7.2 high memory usage
Mon Apr 25, 2022 12:54 pm
Same issue here on A RB5009 running 7.2.1. Eats memory with a speed of about 500KB to 250KB a day so not a very big problem with 1GB memory.
Does seen to fluctuate a bit.
Users browsing this forum: No registered users and 53 guests
